Charger/Charging question
I am looking at getting a new charger. The two I have it narrowed down to have different max discharge rates. What I would like to know is, is it better to discharge packs at 20amps or 30amps?
Thanks |
Depends on the type of racing you do. If you run 12th scale 30 is over kill. If you are running strait TC 6 cell packs than 30 is better. But I would be more concerned about charge rate than discharge rate. I can make a 80amp discharger if a I want but I can not built my own charger. So if you are serious about racing than I would look at chargers that at least go uyp to 6amp charge rate.
Hope this helps, Stephen <>< |
Originally posted by Mr. Shookie Depends on the type of racing you do. If you run 12th scale 30 is over kill. If you are running strait TC 6 cell packs than 30 is better. But I would be more concerned about charge rate than discharge rate. I can make a 80amp discharger if a I want but I can not built my own charger. So if you are serious about racing than I would look at chargers that at least go uyp to 6amp charge rate. Hope this helps, Stephen <>< So, TC discharge rate sould be 30amps and 1/12 should be 20amps?? Or is that still overkill for 1/12? |
no 20 is great for 12th IMO
Stephen <>< |
