Old 06-12-2002, 11:32 PM   #16
Matt Howard's Avatar
The owner of Sorex, Mr. Saiki, was the person responsible for the first generation of Pit tires a couple of years ago when he worked for Pit Shimizu. The new Pits and the Sorex tires have nothin in common other than they're both tires for TC's. I'm not 100% sure but I believe that Dunlop is the one that provides the rubber for the Pit tires now.
Matt Howard is offline   Reply With Quote
Old 06-13-2002, 08:01 AM   #17
sonneteer's Avatar
Over here on the tyre wall of the Pit 26mm wet tyres they got Dunlop stamped on it...
sonneteer is offline   Reply With Quote
Old 06-13-2002, 06:45 PM   #18
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Thats because the Pit treaded tire is molded with the same tread pattern just like a real Dunlop tire.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 06-13-2002, 07:27 PM   #19
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Originally posted by maski
Bigdog> will Take-Off 32 good in asphalt about 50 degrees C? i usually use Sorex 36R.
Maski- I've found there's a split temp there. In other words, a CS27 wil work well in the first half of the Srox 36r temp range, and the CS32 picks up from there.
I would say CS27 up to 120 deg F and the CS32 from there on up. Of course, different tracks will be different. Our track is a little corse compared to say a smooth finish fresh asphalt, so our track requires moving to the next tire compound earlier in the temp range simply because the corse track generates more heat and begins to overheat the tire before the 5 minutes is up.
The best way to tell is to watch for feathering on the contact patch. If it begins to look feathered, then move up a compound and see how they work.
For those racers who aren't sure what is meant by feathering- Feathering looks similar to tiny wrinkles that go the same direction as the outside of the tire. Thy generally occur in the center of the wear pattern and move out from there. Feathering occurs when the compound begins to overheat and get too soft. Those drivers who have a good "feel" of the car when it's on the track will usually notice a slight push as the tire begins to overheat. A very balanced car that doesn't overheat the front tires before the rear will notice the car beginning to "float" to the outside especially in the sweepers.
While we're at it- blistering is the next step of overheating. You can't miss blistereing- It looks as if someone peeled the "skin" off part of the contact patch of the tire. Blistering is exactly what it says- a blister or really hot spot (area) forms on the tires' surface and literally peels off. It won't come off in a big chunk, but there will be a noticable difference between the blistered area and the nonblistered area as opposed to a feathered tire where there isn't really any area of the contact patch missing, it just has that fine wrinkly look.
I should note that driving has a lot to do with heat generation in a tire. If you're running the "perfect" compound for your temperature and track which is the softest possible compound you can run without overheating or losing traction before the end of the run, you can actually overheat the tire with driving style where another guy might not overheat his (same) tires. This happens especially when you "overdrive" the car. Pitching the car into turns is one very serious example of overdriving the car. Quick direction changes and turning the steering wheel further than the car is actually turning are two more examples. Most of you have read the information on tire traction and the adhesion circle which dictates the most traction a given rubber tire can generate. Any time you surpass that circle, you force excessive heat generation. So if you have never understood why the "fast" guys preach smooth driving, gradual corner transitioning and "slower is faster", now you know a huge part of it.
One last thing- I'm certainly not a pro or sponsored driver, so if anyone who has more knowledge of these aspects of racing wants to add or correct me, please feel welcome. I'm merely trying to help those who want to help themselves....
BigDogRacing is offline   Reply With Quote
Old 06-13-2002, 08:28 PM   #20
Joe's Avatar
While we're on the subject of tire temps, does anyone know a relative measurment of Proline H13 slicks compared to a temp rated tire? I got a good deal on them on eBay ($5 a pair) and I plan to use them as practice tires.
Joe is offline   Reply With Quote
Where to get Pit Shimizu tires online? nnick Electric On-Road 10 10-18-2012 07:32 AM
Pit Shimizu 27rs and 24rs kaizen Electric On-Road 4 10-26-2005 03:37 AM
Shimizu racingtires Troubled R/C Items: For Sale/Trade 4 11-06-2004 05:54 AM
Sorex 28R or Pit Shimizu D24R MrRolla Australian Racing 3 03-30-2004 05:42 AM
Pit Shimizu, Yokomo, Pro-Line jwwu R/C Items: For Sale/Trade 1 03-30-2002 12:24 AM
SEO by vBSEO 3.5.0
