Tires?
Tires?
What do you guys think is the best non-foam tire to use on an indoor carpet oval? We all run 4WD cars. Im running the HPI Pro Compound X-Pattern Radials (26mm) and they seem to hookup really well. (The track was smooth concrete before we carpeted it). Its a real short D-shaped oval.
We have decided for everyone to NOT use foams, but are thinking about having all cars run the same tires. We have decided on the HPI's as one possibility, but id like to research more. (preferably radials).So besides the HPI's that I mentioned, what other tires can you guys reccommend ?
IF you guys want quality tires at a good price. IT dont get any easier then to run TAKEOFF premounted CS27 tires. Or CS22.
Xpatterns are heavy and suck. For carpet racing run takeoff or sorex. I like the idea of everyone running the same tire so to make things easier(eliminating voodoo rims and insert combos) run premounted rubber tires.
tires
How long do the CS27's last ?
Should last a long time since they are a harder compound. Between sorex and takeoff the takeoff tires should last longer.
I dont run rubber or sedans on our oval track so im only going by my sedan road racing experince. We would get a long life running them on sedans with stock motors on carpet
Super Moderator
Yeah, on carpet, a set of TakeOff CS-27's will last a LOOOONG time before you notice any real wear. If it tells you anything, at the last Novak US TC Champs(on carpet), CS-27's were the handout tire for rubber tired classes, & the one set that you got with your paid entry would last the ENTIRE event, I only needed one extra pair for myself that weekend(which was practice on Wednesday, all day Thursday, qualifying on Friday & Saturday & the mains on Sunday), & only then because I wanted to try applying some CA to a bit of the fronts' contact patch to reduce grip & take away some steering(had GOBS of grip all weekend). I didn't even wear off the little seams on them that you see when they're brand new......
grip
You wanted to REDUCE grip??? Wow. So am I to assume they hookup on carpet REAL good right out of the box?
grip/carpet
The carpet we have is brand new, and the HPI tires are hooking up great. The stock Pro-Line V-Rage tires are getting gummed up real bad and are starting to shred.
So we definately have the HPI X-Pattern radials as one option, but Im definately interested in another. So far I like what I hear about these CS27's...
Super Moderator
Re: grip/carpet
