What is the proper way to use a tweak station
Help !
what is the proper way to adjust your car on a MIP Tweak Station.
when i put the car on the tweak station, i put the front of the car on the end that has the bubble for balance.
Do you adjust the rear shocks or do you adjust the front shocks to balance the car.
Do you adjust only the front or rear or both.
i tried to adjust both ends. lol i made the car worst. lol
Help !!!
thanks
Help !!!
thanks
Well, first I make sure I have everything in the can that it is going to run with, battery, electronics, ect. Then I set the ride high, then the droop, then off to the tweak station we go!!!!!!!! Start with one end. make small adjustments to the shocks, all of them if you have to get the end you are working on to balance. Then do the other end the same way. Then check the other end to see what the other end went to and fix it. Recheck your ride height, make sure it is were you want it still and after that your ready to hit the track. Some cars are easy, JRXS, some are not so easy, TC3 rtr with shocks with shims. You get the picture. I hope this helps.
Originally Posted by baih
Help !
Help !!!
thanks
Help !!!
thanks
Tooo funny, googled for the thread, posted, then re-read and seen it is 6 years old. Still good info though.
Last edited by dug44; 10-08-2011 at 07:46 AM. Reason: Only 6 yrs late on getting in on the conversation..... Figures
