New CRC Gen Xi 12th car..... >
Old 05-04-2012, 09:22 AM
  #586
gijoe64's Avatar
Trader Rating: 30 (100%+)
Originally Posted by AOD
We run 13.5 blinky on this track.
Sweet!!
gijoe64 is offline
Old 06-03-2012, 07:54 PM
  #587
tazfam2's Avatar
Trader Rating: 54 (100%+)
does anyone have gearing for an asphalt track with a 225 straight and a good setup also The track is the one for the 2012 nats thanks
tazfam2 is offline
Old 06-04-2012, 06:00 AM
  #588
masterhit's Avatar
Trader Rating: 16 (100%+)
Which motor?
At Leisure Hours with the full straight my fastest set-up was;
Revtech stock rotor, 4.79" roll-out, centered on the third timing dash.
For the car I would start with Andrews nats set-up from last year.
Definitely have a white center and blue sides handy....
Paragon and tweak, or Paragon and SPF 50 are good tire preps. 20+10-20 minutes rear and 10 + 10 minutes front. <---- Huge tuning aid and lots of personal preference here....
Mike Slaughter
masterhit is offline
Old 07-09-2012, 02:25 PM
  #589
Wow this thread hasn't seen action in awhile...ok well lets bump this up!
I just ordered me a Gen Xi and plan to run it in 13.5 blinky at the IIC. Anyone have a good setup for this track? I imagine it will probably be somewhere between last year's 13.5 boost setup and 17.5 blinky setup.
InspGadgt is offline
Old 07-09-2012, 07:27 PM
  #590
Just wanted to let everyone know about our new 12th and 10th scale pan car tire truing adapter. This really helps get a true running tire by clamping the wheel the same way as when the wheel is attached to the hub with the mounting screws. Check it out at www.teamtamale.com.
team_tamale is offline
Old 07-09-2012, 09:13 PM
  #591
andrewdoherty's Avatar
Trader Rating: 49 (100%+)
I've been using these on my Gravity and Jaco tires since Carpet Nats in both WGT and 12th. Amazing quality, and a perfect cut. I didn't realize how much runout I had on my tires until I trued a set with Larry's pieces. I won't true without them now!
andrewdoherty is offline
Old 07-17-2012, 01:00 AM
  #592
Default short question
Hi, i started building my Xi yesterday. And just have the problem that the rear pod does not move completely free. damper, side-bars,... are "loose" on the kingpins. any ideas? Thank you
pedro77 is offline
Old 07-17-2012, 02:23 AM
  #593
Put the chassis flat on a setup board and loosen the nuts on top of the center pivot. Make sure it is sitting flat and tighten them again. See the part on page two on "Setting the One-piece links". If that doesn't do it check the center pivot itself and make sure you haven't over tightened the screws that capture the pivot ball. The center pivot should pivot easily with very little slop in it.
Old 07-17-2012, 01:09 PM
  #594
Default ..
thank you! problem is solved. i have another question: has anyone ideas how to fix an sanwa/airtronics srg-hr servo? is there a bulletproof method?
pedro77 is offline
Old 07-17-2012, 03:29 PM
  #595
Are you saying the servo is broken or that you are having a hard time getting it mounted correctly on the chassis?
Old 07-17-2012, 04:48 PM
  #596
nashrcracer's Avatar
I hear things.......
nashrcracer is offline
Old 07-17-2012, 05:05 PM
  #597
I guess that's better than seeing dead people
So what are you hearing?
Old 07-17-2012, 07:46 PM
  #598
Nash draws in yet another victim...
Let me pop some popcorn...LOL
Bill
Still Bill is offline
Old 07-17-2012, 08:02 PM
  #599
GMartinez's Avatar
Trader Rating: 91 (100%+)
is the site down
GMartinez is offline
Old 07-17-2012, 09:59 PM
  #600
Bill
Well at least it brought Bill back out...haven't seen you around in awhile!
