Team Much-More cell master v1
#1441
Originally Posted by drivingpro
sorry to dig up an old thread....
But i am trying some different things with my IB4200s.
Like on the SMC website they say to charge 4cell with a 5mv cut off per cell 20mv in total (0.02v delta peak) and for some reason i can't set the charger to 0.02, it either goes 0.00, then jumps to 0.03v, can anyone see if their cellmaster does this? as it is quite annoying
#1442
Hi there matt,
To get a 20mv cut off set it to 20. your trying to set it to 2mv which is 0.002 but you want 0.02 which is 20 mv. The mv settings on the cell master are for the entire pack.
#1443
Originally Posted by shift
Hi there matt,
you say it is the Mv setting for the entire pack (which i thought) and the dude above you said that the cell master displays it per cell.
Time to dig up the manual. Cheers for the help anyway
#1444
AHHhhhh, I see now lol, cheers!!!!
#1446
What do you mean by capcity? do you mean the amount its capable of charging up to? if so thats 9900 or 9.9a or do you mean charging amps if so that 10a
#1448
yeah i try to set it to 0.02 but it doesn't like it, it either goes 0.00 then straight to 0.03.
#1449
Originally Posted by Tek Nickal
The cell master displays the delta peak setting per the total number of cells. If you want a 5mV delta peak per cell, multiply that by how ever many cells you have, 20mV total for a 4 cell pack and 30mV for a 6 cell pack. Hope this clears things up for you.
#1450
Originally Posted by VooDooPH
anyone know if the fan output on the side of the charger is for 12V or 5V fans? also what's its capacity in Amps? thanks!
If you're going to use your own 40mm fans i suggest getting thick ones. the thin ones move hardly any air
#1451
Originally Posted by floodo1
Much more charger output plug is for 12v fans.
#1452
great! thanks! planning to use a couple of 80mm fans that i have. they're currently running off the PS, but was thinking my pit area would be cleaner if it were attached to the CTX. btw, does anyone know where i can get the connector that mates with the side output?
one thing that you must remember is that the output port on the ctx is temperature controlled. you must first set the option to fan (not battery warmer), and then whenever the temperature exceeds the fan temp you set for whatever profile you are in, the fans will kick on.
If you still need the plug PM me and i can find the molex part number. you should be able to order it as samples from molex, so you would get it for free
#1453
Originally Posted by Stroker Ace
I just had a charge terminate, the blue light is blinking twice per second and there is a message that says SUP on top row just to the left of the charge capacity number. What does SUP mean? Thanks.
#1454
as i recall its a molex connector.
great! thanks! called a local electronics supplier and they have the part (2-pin male/female). cost is very minimal so i guess i'll just get a few sets from them. many many thanks for the lead.
#1455
on an added note, reading through some of the other battery charging threads here, it seems that its not a good idea to run fans while charging my batts. i live in a hot, humid and tropical country so afternoons can get pretty nasty especially during the summer. would it still be a good idea to run fans while charging my IB4200s? Says it increases internal resistance of the bats. I'm currently set at 6A @ 6mV delta. Or should i run the fan blowing away from the battery instead?
Thanks!
Thanks!
