Team Much-More cell master v1
#1336
Originally Posted by Nexus Racing
Like A. Rhodes said, 120 deg (48-49 deg C) is an ideal peak temp...after charge, the battery temp will rise closer to 130 deg, which is spot on for IB's.
No problem, Carl .
No problem, Carl .
thanks
vic
#1337
Originally Posted by Runin Ronin
I didn't get mine today, I gotta pick it up at the Post Office in the morning
#1338
another question: will i be doing the batteries an injustice by using a fan while they are charging? i have noticed that when i am charging using the new battery heatsink with the fans, the temps on the pack hover around 83 deg F. As soon as the cycle completes, the temps rise (i didn't use a temp gun the last time i charged, but i am waiting for the current cycle to finish up,and i'll post the temps)
i know heat is the enemy, but i remember somebody telling me that you want the batteries to heat up, just not to the extreme
thanks again
vic
thanks again
vic
#1339
sorry for the multi posts!
my 4200's cut out at 3988 (when charging on my GFX, i was getting about 45-4600mah)
i'm guessing it was because the delta peak was at 3 - should i bump this up to 10 or so?
also, after sitting for 5 minutes after the peak, the temp only went up to 97 degrees.
thanks for the help guys
vic
vic
#1340
the diff b/w 3mv and 10mv peak is prob about 30secoinds of extra charging, so wont make muchh diff.
the diff in charege level is effected by how empty the cells was when u started.
anyway i hope you mean your cells r at 90deg F (not celcius), if so then yes you can increase the delta peak more....
#1341
Tonight when I was at the track, one of my two purple cell masters went bad. I tried to hit the stop button when the pack is done and there was a static spark when I touch the case, the screen went balastic. I shut it off and turn it back on and all was normal again BUT the voltage reading, it is reading a 4 cells pack at 80.xxx volts. What to do?
#1343
Originally Posted by Casper
Try and factory reset first. See if that fixes the problem.
#1344
MAY BE A BEST PRICE IN THE WORLD--CELL MASTER SPECIAL EDITION
http://www.racing11.net/shop/product...oducts_id=2062
#1345
Originally Posted by TFR
Did that many times, everything else works fine and it charges fine too. Just the voltage reading that is messed up, I think something is burnt up inside? Anybody have this problem before?
#1347
i don't know why my CTX-C won't fully charge up my 4200's
any suggestions?
thanks
vic
#1349
Tech Legend
Trader Rating: 51 (100%+)
Abit too much blue in this thread. Come on, no love for purple?
