Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 03-20-2006, 01:46 AM   #991
XrayFK's Avatar
You could always use two chargers to charge the same pack so you can get a high enough current.
XrayFK is offline   Reply With Quote
Old 03-20-2006, 06:50 PM   #992
mudguard's Avatar
hmmm....that's one idea XrayFK...but a rather expensive one...Got rid of it, no more 8-cell sub-c IB4200 step-charge problems with my current one Good riddance!
mudguard is offline   Reply With Quote
Old 03-20-2006, 07:08 PM   #993
Send a message via AIM to g_bruin Send a message via Yahoo to g_bruin
I just wanted to give mad props to James at Much More for the awesome Customer Service! The On/Off button on my Power Master had popped off and he immediately sent me a replacement switch.
I am a firm supporter now and keep up the good work.
g_bruin is offline   Reply With Quote
Old 03-25-2006, 07:57 PM   #994
hierog's Avatar
can somebody post a good profile to use for 7 cell gp3300's? i have an emaxx running on 14 cells and want to use the Cell Master's for them.
thanks
vic
hierog is offline   Reply With Quote
Old 03-27-2006, 08:25 AM   #995
Casper's Avatar
I would use the same 3300 profile on the NEXUS site but change the cell setting from 6-7. The charge profile should not change for additional cells.
Losi | Xcelorin | Spektrum | JBRL | Kolor Koncepts
XXX-CR, XXX-TCR, Spektrum DX3R
Casper is offline   Reply With Quote
Old 04-05-2006, 02:32 PM   #996
EricF's Avatar
Nexus (or anyone),
Are there any potential problem with setting the mah high enough to charge a 4200 pack and use the same mah setting to charge a 3800 pack?
I don't think that there would be, since the pack is only going to hold what its rated for.
The reason I ask is I'd like to set a profile to charge...
1. 4200 4 cell
2. 3800/3300 6 cell
3. 4200 & 3800/3300 (4/6 cell) pack for storage at 600 mah
I just don't want to cook any battery packs.
Thanks,
E
EricF is offline   Reply With Quote
Old 04-05-2006, 03:36 PM   #997
EricF-
There isn't a problem for setting the mah high for both especially for IB3800's and IB4200's assuming you want the voltage dropback and amprage to be the same. I would recommend using the temprature probe on the pack (especially the 3800's) to make sure it doesn't get too hot.
I would be concerned about setting a charging profile for both 4cell and 6cell. You don't want to charge a 4cell pack on a 6cell setting or vice versa.
A_Cartwright is offline   Reply With Quote
Old 04-05-2006, 06:45 PM   #998
Nexus Racing's Avatar
Eric,
We pretty much leave ours set to 5000 to prevent a capacity cut. Like Andrew said, this will allow you to utilize your temp and delta peak settings for peaking.
For storage charge, we set the capacity cutoff to 450-500 at 6.0amps.
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 04-06-2006, 08:55 AM   #999
EricF's Avatar
Thanks guys. Actually the charger will not charge a for cell pack if its set for 6 cell. It gives a low cell error message.
Any recommendations on the temp setting? I currently have it set at 42*. I race at an indoor track with inside temps in the low 80's high 70's.
Thanks,
E
Old 04-06-2006, 10:27 AM   #1000
Thanks,
E
48 (~118 deg F) is a good temp cutoff for GP and IB cells for optimal power and safety. You want a little room on the peak temperature, because the cells' temp will rise a little after peaking.
NEXUSRACING.com
Old 04-06-2006, 12:46 PM   #1001
EricF's Avatar
48 huh... I'll try that out this weekend.
Thanks,
E
Old 04-11-2006, 05:30 AM   #1002
mitchsterbrau's Avatar
dissapointed in much-more racing's customer service
i have a faulty charger [1ithin 14 days of purchase]
showing bad LCD lines, top row completely missing!
i'm seeing this fault pop-up a few times, will much more racing
replace my faulty charger if i send it back to korea>?
or should i return it to the place of purchase [online store rcmart].
not happy. any help would be great, no replies to my mails after 10 days.
i can't recommend their product with no support.
mitchsterbrau is offline   Reply With Quote
Old 04-11-2006, 06:47 AM   #1003
BringItOn's Avatar
hey rcmart is great for cheap stuff, but dont expect prompt warranty service. its the risk i have accpeted to take when buying from Overseas. Hopefully teammuchmore on this forum can help... otherwise here is a little trick. do you have a friend that bought his one locally? if so get your friend to take it back to the store he bought it from
BringItOn is offline   Reply With Quote
Old 04-11-2006, 07:28 AM   #1004
Will this charge the new orion 4800 lipos
bear27 is offline   Reply With Quote
Old 04-11-2006, 07:45 AM   #1005
cheers for the info fella! don't rcmart suck!???
have had trubs with em b4.
fortuntately, the team much more support guy, Ryan Lee [LEGEND!]
got back to me about 10mins after i had posted to this thread.
WOW! feeling much happier now......ALWAYS go here first for support
with this charger, their email replies are kind non-existent.
shame is though, i have to pay the return postage, at 30US it's not cheap.
[and it's still under warranty]
happier when i get it back......finally i'll be racing again!!!! woot
Forum Jump
FS/FT: TEAM MUCH MORE Motor Master & Cell Master litespeed-dom R/C Items: For Sale/Trade 15 06-15-2006 07:44 PM
Team Orion Advantage w/ LiPo or Team Much More Cell master? RH Customs Electric On-Road 6 04-06-2006 05:05 PM
Team Much More Cell Master FRP R/C Items: For Sale/Trade 4 01-25-2006 02:04 PM
Team Much More Racing CTX Cell Master and CTX Motor Master letitroll R/C Items: For Sale/Trade 7 11-18-2005 10:25 AM
Team Orion Advantage or Team Much More Cell Master charger alana07 Electric On-Road 1 12-18-2004 04:37 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
