Okay need a little help here. So I've had my Cell Masters for under a month now and on one of them it would every now and again stop charging immediately after I start the charge and display a message saying "ERR 0001 *OVER VOT* I could sometimes power cycle it and it would be fine, charge that is. Now everytime I start a charge it displays that same message. I attached a pic of the error message from a session a couple days ago. Any thoughts? Thanks!
OVER VOT - is stands for Over voltage error.
If output voltage goes over input voltage, CM makes Over volt error.
Here's some tips for charge of 8cells.
1.set input voltage higher.
2.Discharge batteries before charge. (1A 0.1V cut in Dischage mode)
3.set lower charge amp. (0.5~0.8A)
Thanks,
Ryan
SweepRacing ProSpec TOP GSracing enRF Hudy Futaba
If you charge 8cells at 5amp, out put voltage will exceed input voltage. so Cell master will make OVER VOLTAGE error "OVER VOT" on the display.
8cell charging by the CM is for 8cell(0.5~1.0A) transmitter batteries.
Thanks,
Ryan
Thanks for your honest reply Ryan, so basically since "CM 8-cell charging is for transmitter batteries" I can never get a maximized "racing" charge for my monster truck's 8-cell Intellect 4200s. Too bad for me then, time to sell my newly bought CM.
hey guys ! heard some rumours bout a new version of ctx-c is coming out in april...got new features in it.....anybody out there got any info bout it....?
MuchMore is set to release two new chargers very soon...but neither of these is intended to replace the Cell Master.
One will be a specialized Lipo-only charger, and the other will be a charger apparantly ideal for nitro racing (Lipo, receiver pack, starter box, dual charging, etc).
Is there any one other than Andrew that I can contact at MMUSA? I understand he is at nats and I need to find out the tracking info on a replacement that was sent to me on 3/7.
Here's just some suggestions,
I would like to see a charger from MMR that can charge 1-12 cells at full current ratings because we are a group of robotic-hobbyist and we sometimes uses 12 cells battery packs. Or perhaps is it possible to flash the current cell master with a new firmware so that it can charge higher cell count battery pack?(now sure if that is possible without changes in components)
I own a cell master myself and i love it so the ball is in your court guys..
I dont know of many (any really) chargers that can do 8 cells at a high rate of charge on a standard 12-13VDC source w/o some sort of issue. My suggestion, if you really dont want to sell the charger, is to split the pack into two four cell packs... and charge them separately. You really dont even have to split them up, if you are using battery bars to hold your cells together, then you can just clip onto the battery bar in the middle of the pack, orient +/- accordingly to which end of the pack you start charging, adjust the CM for 4 cell, and charge away. After one side of the pack is done, switch the leads up for the other side observing polarity, and charge the second side of the pack. Its a little bit of an inconvenience, but it could keep you from losing $$$ by selling your new charger as a used item. The CM is a great charger for your IB4200's, and will ensure long life/great power from your cells.
The futaba cdr-5000 is supposed to be able to charge between 1-36 cells. I charged 8 AA's and your normal 6 cell sub-c packs. I understood that this is to handle some speciality packs that you may find in drag racing. I'm not sure how they handle the voltage issue.
let me know if you want to sell. i will buy
if you want to charge 8cell packs at such a high rate, you really need a charger that does up to 10cells or even more.
also have you tried putting the charge rate down a little bit? maybe to 5.0amps? or 4.5amps. that should be sufficient. otherwise it may be easier to get a PS that can be set to 15v.
BTW I have this charger and 2 cell masters.
You are correct, it's able to charge TX packs w/o a problem
Thanks for your input DaveW will look into it. So far what I discovered was to step charge my 8-cell pack at 6 amps till 2500mah, then 3 amps till 3500 and 1.8 amps till 4300. Seems to be okay until it "peak cuts." Thanks for the advise and offer noobie I live in Manila so am not sure selling it to you will be "cheap"
