Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 01-09-2006, 05:30 PM   #901
Default /
I have good setting for 6cell, 1,200mAh battery pack for Mini 18T.
New battery pack tends to false-peak for the first few times.
LongLockOut will prevent false peak. 20minutes will work fine.
Try 1.2A, 6mV Temp cut 40deg.C
Dishcharge, try 0.5A cut off at 4.8V.
Thanks,
Ryan
Originally Posted by Fervidsea
Using the cell master to charge the mini packs that come with the 18T. What settings/mode should I use. Also can I discharge using the CM? If so what setting for that?
SweepRacing ProSpec TOP GSracing enRF Hudy Futaba
Ryan Lee is offline   Reply With Quote
Old 01-24-2006, 12:52 PM   #902
TFR
TFR's Avatar
I just received my second Much More Cell Master which I believe is the latest version as it came factory with a magnet on the temperature sensor!
Good job Ryan, now where I can get that replacement magnet for my old cell master?
Muchmore l AHRP l Xenon l Futaba
TFR is offline   Reply With Quote
Old 01-24-2006, 01:02 PM   #903
Joep's Avatar
Originally Posted by TFR
....Good job Ryan, now where I can get that replacement magnet for my old cell master?
I Want two
Xray T2'009 Sponsored by: Myself and my wife.
Joep is offline   Reply With Quote
Old 01-24-2006, 03:55 PM   #904
BringItOn's Avatar
hi anyone know what the extra wire that goes to each of the output aligator clips?
BringItOn is offline   Reply With Quote
Old 01-24-2006, 04:30 PM   #905
Nexus Racing's Avatar
Those wires are for measuring voltage. MMR, as well as a few other manufacturers, keeps this wire seperate from the main wire with the charging current.
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 01-24-2006, 10:55 PM   #906
Shop Owner
nnick's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
Is this the only change to the charger?? Or the version is also changed?
Nick
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
nnick is offline   Reply With Quote
Old 01-25-2006, 01:36 AM   #907
Other functions are same.
We put magnet on temp rprobe only.
Ryan
Nick
Old 01-25-2006, 05:04 AM   #908
duckman996's Avatar
Ryan
Are those magnets available to upgrade older temp probes?
I had a chance to use a friends charger and they do make things a little easier.
Hobby Hobby / FastCats / XXX Main
duckman996 is offline   Reply With Quote
Old 01-25-2006, 07:36 PM   #909
pucho's Avatar
Send a message via AIM to pucho
I Just got 2 of the cell masters, and I'm thankfull for the articles on Nexus site. However I'm still wondering what is the best way to atach the temp prove to the cells if yours didn't come with magnets?
pucho is offline   Reply With Quote
Old 01-25-2006, 07:54 PM   #910
BringItOn's Avatar
would muchmore make available those little magnets? i tried to find some at electronics store, but was a little too thick....
Old 01-25-2006, 08:10 PM   #911
TFR
TFR's Avatar
For me, I place the temp sensor under the battery pack when charging. Another method for me is to place a small piece of strapping tape on the sensor and stick it to the battery. I can use that piece of strapping tape whole day.
Old 01-25-2006, 08:14 PM   #912
Regional Moderator
ImGoinRCn's Avatar
Send a message via Yahoo to ImGoinRCn
I usually just rest mine under a cell. It works fine that way but never did the tape...thanks for the idea!
ImGoinRCn is offline   Reply With Quote
Old 01-25-2006, 08:31 PM   #913
TFR
TFR's Avatar
I may have not explained too well so I attached a picture for you guys.
Second picture is the cell master with the magnet on the temp sensor.
team-much-more-cell-master-v1-cimg1156.jpg   team-much-more-cell-master-v1-cimg1157.jpg
Old 01-26-2006, 01:10 AM   #914
pucho's Avatar
Thanks guys!
Also I bought 2 CM's It seams that when I checked the temp readings with my IR temp gun One is very close to the same readings the other is of by like 10deg ( it reads cooler than the temp gun) I was wondering if anyone had experienced this?
Old 01-26-2006, 02:34 PM   #915
Casper's Avatar
I have just been sticking the temp sensor between cells. I have my batteries side by side and just wedge it between the two middle cells. I am planning on adding a magnet though. Need to see what Radio Shack has since that has ben suggested earier.
Losi | Xcelorin | Spektrum | JBRL | Kolor Koncepts
XXX-CR, XXX-TCR, Spektrum DX3R
Casper is offline   Reply With Quote
Forum Jump
FS/FT: TEAM MUCH MORE Motor Master & Cell Master litespeed-dom R/C Items: For Sale/Trade 15 06-15-2006 07:44 PM
Team Orion Advantage w/ LiPo or Team Much More Cell master? RH Customs Electric On-Road 6 04-06-2006 05:05 PM
Team Much More Cell Master FRP R/C Items: For Sale/Trade 4 01-25-2006 02:04 PM
Team Much More Racing CTX Cell Master and CTX Motor Master letitroll R/C Items: For Sale/Trade 7 11-18-2005 10:25 AM
Team Orion Advantage or Team Much More Cell Master charger alana07 Electric On-Road 1 12-18-2004 04:37 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
