Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 11-27-2005, 06:27 PM   #856
Fred Perkins's Avatar
Trader Rating: 100 (100%+)
Send a message via AIM to Fred Perkins Send a message via Yahoo to Fred Perkins
What is your peak drop back set at?
-- Team Driver for: Hot Bodies USA, Integy, TQ Racing Tires, BBT Hobbies --
Fred Perkins is offline   Reply With Quote
Old 11-27-2005, 06:35 PM   #857
nino_pohan's Avatar
My delta peak is 06
nino_pohan is offline   Reply With Quote
Old 11-27-2005, 06:36 PM   #858
Try raising it up to 09 and go from there.
Old 11-27-2005, 06:42 PM   #859
nino_pohan's Avatar
I already try delta peak with 24 and peak cut too
Old 11-27-2005, 07:21 PM   #860
Alex_kipper's Avatar
are the batteries discharged and trayed?
Alex_kipper is offline   Reply With Quote
Old 11-28-2005, 02:44 AM   #861
nino_pohan's Avatar
yes, i dis 25A and tray with rayspeed
Old 11-28-2005, 03:01 AM   #862
Originally Posted by nino_pohan
My delta peak is 06
that is wayyyy to high for any battery,you shouldn't need to be any higher than .03 maybe .04.I use .02 and my batteries come out at 130 degrees.You've got something else wrong.
Hyper1 is offline   Reply With Quote
Old 11-28-2005, 04:12 AM   #863
this worked on my old IB3300 and IB3600s...
try to fully discharge to 0V each cell then do a slow charge @ 1A only, 06 delta, LLO 15mins...then discharge @ 20A then tray to 0v....3 cycles at least and when your done with cycling ur bats, do the Nexus Racing's method of charging either linear or ctx. It should give you better numbers now...
Edgarski is offline   Reply With Quote
Old 11-28-2005, 11:39 AM   #864
Nexus Racing's Avatar
06 on the Cell Master is 0.006V, NOT 0.06V. The delta peak settings are different on the CM due to the super linear current. For more info on this, you can go here:
http://nexusracing.net/newsdesk_info.php?newsdesk_id=29
Why my cm always peak cut charge IB3600 at 3200mah and GP3300 SMC at 3000 and my battery temp always 38C never reach 45-50C. Please help me....
How old are your packs (how many cycles, how long have they been stored, etc.)?
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 11-28-2005, 01:29 PM   #865
hI qUICK qUESTION.. if i charge at constant 6Amps for IB 3600's what delta peak value do i use? 03, 04, 05 ? thanks.....
Doomah is offline   Reply With Quote
Old 11-28-2005, 02:10 PM   #866
05 (0.005V) is a good starting place. You can increase it based on ambient conditions (cooler ambient temperature => higher delta peak setting). Also be sure to set the long lockout for about 15 minutes when using a standard linear charge.
Set your temp cutoff at 48-49 (~118-120F). After charge, the battery's temperature will increase...so 48-49 is a good temp cutoff setting.
NEXUSRACING.com
Old 11-28-2005, 06:27 PM   #867
nino_pohan's Avatar
Is a new batt i buy 2 weeks ago and use only one race.
Old 11-28-2005, 06:37 PM   #868
thanks nexus... i read your website...
http://nexusracing.net/newsdesk_info.php?newsdesk_id=7
good info
cheers
Old 11-28-2005, 11:47 PM   #869
Default discharging capacity and time errors
I have noticed the discharging capacity does not match with the discharging current times elapsed time.
For instance,I have 2.4A constant discharging current , but I only get about 2.2mah after 60 minutes.
Moreover,I have noticed the elapsed time is not accurate.I have about 4 minutes errors in 60 minutes .I forgot it is faster or slower.
Do you guys have this kind of problems?
Who can explaine this?
gallagher is offline   Reply With Quote
Old 11-29-2005, 12:01 AM   #870
Post correction:
For instance,I have 2.4A constant discharging current , but I get about 2.6mah after 60 minutes.
Forum Jump
FS/FT: TEAM MUCH MORE Motor Master & Cell Master litespeed-dom R/C Items: For Sale/Trade 15 06-15-2006 07:44 PM
Team Orion Advantage w/ LiPo or Team Much More Cell master? RH Customs Electric On-Road 6 04-06-2006 05:05 PM
Team Much More Cell Master FRP R/C Items: For Sale/Trade 4 01-25-2006 02:04 PM
Team Much More Racing CTX Cell Master and CTX Motor Master letitroll R/C Items: For Sale/Trade 7 11-18-2005 10:25 AM
Team Orion Advantage or Team Much More Cell Master charger alana07 Electric On-Road 1 12-18-2004 04:37 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
