Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 11-15-2005, 11:39 PM   #841
ark
I hope this is not a silly question but if I'm looking for 3mv peak detect per cell do I set the charger value to 18mv for a six cell pack
ark is offline   Reply With Quote
Old 11-16-2005, 06:34 AM   #842
Swampracer's Avatar
Trader Rating: 29 (97%+)
Default MUCH MORE motor master
I have a new MUCH MORE Motor Master Surikarn V3.0C dyno for sale. $140 shipped includes a Much More motor mate stand.
Please check out my listing under items for sale forum.
Swampracer is offline   Reply With Quote
Old 11-16-2005, 07:16 AM   #843
dag32's Avatar
Trader Rating: 36 (100%+)
Originally Posted by JasonC
anyone know what the diffrence between softe ware version 1.0 and 2.0 on the MM CTX charger is ??
Ver. 2.0...... I don't think there is one.
dag32 is online now   Reply With Quote
Old 11-16-2005, 02:31 PM   #844
Nexus Racing's Avatar
There is currently no v2.0...
The input value for delta peak on the CM is for the entire pack. For value per cell, divide the input value by the # of cells (06=6mV per pack=1mV per cell).
Keep in mind that the CM utilizes lower delta peak values than other chargers. If you set a .03 on a Turbo 35, you will probably set around a .006 (06 setting) on the CM. For a detailed explanation of why this is true, see our article here:
Delta Peak and Super Linear Current on the Cell Master
Any time you tray/dead-short a battery, or if it has been stored for an extended period, it is more likely to false peak.
The CTX mode is locked against delta peak in its first two phases, so no long lockout is neccessary. If you use the regular peak charge mode, set the long lockout up to 10-20 minutes. Any false peak after 20 minutes would be due to a bad connection or bad cell.
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 11-16-2005, 02:33 PM   #845
Fred Perkins's Avatar
Trader Rating: 100 (100%+)
Send a message via AIM to Fred Perkins Send a message via Yahoo to Fred Perkins
I e-mail Nexus a couple of weeks ago and got no response.
I am looking for a CTX setup for 4 cell 3800's
-- Team Driver for: Hot Bodies USA, Integy, TQ Racing Tires, BBT Hobbies --
Fred Perkins is offline   Reply With Quote
Old 11-16-2005, 02:43 PM   #846
mike ivy's Avatar
Trader Rating: 21 (100%+)
Hey Freddy ygpm it about the Much More Charger
[-- eXpress motorsports --] [-- Irrgang Racing Service --] [-- BMI Racing --]
BMI DB12RR
1/12th scale fo' Life !!!
mike ivy is offline   Reply With Quote
Old 11-16-2005, 03:05 PM   #847
Alex_kipper's Avatar
Is much more Curenty working on a V2.0?
Alex_kipper is offline   Reply With Quote
Old 11-16-2005, 04:53 PM   #848
Im having problems charging with the Cell Master I can charge 1-2 packs (3300s) then with the next pack I put on to charge it stops half way through, I get an error message "low vol". Im using a 12v car battery as my powersupply, maybe the car battery is stuffed?? Are other people using 12v car batteries?? This even happens after the car battery has been charged over night. Thanks in advance for the input.
G
Floss_LUC is offline   Reply With Quote
Old 11-16-2005, 05:16 PM   #849
Hebiki's Avatar
G
yah.. sounds like your car battery is running out of juice. pick up a power supply. Much more, radio shack and pyramid has some that do 20amps at 13.5v more than enough to power two chargers.
if you can afford it.. get the much more racing one. it comes in 3 different trick colors. LOTS OF BLING!
here's a thread where different supplies are discussed and where to shop for them: Power Supplies for Chargers
Sponsored by:
REI | Coleman | Patagonia | The North Face | Camping World
http://video.about.com/camping/How-To-Build-a-Campfire.htm
Motto: A sniper who has a grassy knoll on lockdown.
Hebiki is offline   Reply With Quote
Old 11-16-2005, 09:00 PM   #850
anyone know if the fan can be swithced off... seems unecessary when charging at a low rate.
Doomah is offline   Reply With Quote
Old 11-17-2005, 01:43 AM   #851
sosidge's Avatar
No, the fan IS necessary, without it the charger will overheat. I believe it is temperature controlled anyway.
www.sosidge.com - www.muchmoreracing.com
Old 11-18-2005, 09:47 PM   #852
Paladin's Avatar
Hi, have had my CTX cell master for about 3 weeks.
Today I turned on to charge a pack, and an error message popeed up that read " bat sensor open, check connection ". Whilst charging I noticed the temp was not being registered.
Any ideas?
Is this a warrany issue? or can I resolve myself?
Paladin is offline   Reply With Quote
Old 11-23-2005, 02:42 PM   #853
hi was wondering what the muchmore battery heatsink is for? is it used for charging? coz i thought a warm battery was good for batteries when it is charging, hence we have battery warmers?
Old 11-23-2005, 02:56 PM   #854
Shop Owner
nnick's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
Heat is only good up to point. You will usually use the battery heatsink on very HOT days in order to anticipate the heat
Another reason is because it looks cool
Nick
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
nnick is online now   Reply With Quote
Old 11-27-2005, 06:01 PM   #855
nino_pohan's Avatar
Default CM peak cut
Hi, Nexus
Why my cm always peak cut charge IB3600 at 3200mah and GP3300 SMC at 3000 and my battery temp always 38C never reach 45-50C. Please help me....
nino_pohan is offline   Reply With Quote
Forum Jump
FS/FT: TEAM MUCH MORE Motor Master & Cell Master litespeed-dom R/C Items: For Sale/Trade 15 06-15-2006 07:44 PM
Team Orion Advantage w/ LiPo or Team Much More Cell master? RH Customs Electric On-Road 6 04-06-2006 05:05 PM
Team Much More Cell Master FRP R/C Items: For Sale/Trade 4 01-25-2006 02:04 PM
Team Much More Racing CTX Cell Master and CTX Motor Master letitroll R/C Items: For Sale/Trade 7 11-18-2005 10:25 AM
Team Orion Advantage or Team Much More Cell Master charger alana07 Electric On-Road 1 12-18-2004 04:37 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
