Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 11-03-2005, 12:54 PM   #826
Is there a way to re-name the individual profiles?
I'd like to re-name then so they are easy to distinguish between GP3300's, GP3700's, and 5 cell receiver packs.
Tony Vega is offline   Reply With Quote
Old 11-03-2005, 01:03 PM   #827
Shop Owner
nnick's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
Check page E3 from the manual at the bottom
At the profile you wish to change hold 3secs button ->
The first character starts to flash. With up and down button change letters/chars with <-, -> change position
Hope that helps
Nick
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
nnick is offline   Reply With Quote
Old 11-08-2005, 07:07 AM   #828
jas
jas's Avatar
Default Fan noise
Are the fans seem excessively loud on this charger?
I mean I've used other chargers including LRP Pulsar2, Duratrax ICE, CDC/Integy (also has dual fans), none of them make such loud noise as my Cell Master.
jas is offline   Reply With Quote
Old 11-08-2005, 07:53 AM   #829
Merciless's Avatar
Send a message via ICQ to Merciless
Just got mine today , Playing with the CTX charge mode . Anyone got a good CTX profile for GP3700's when using them in 1/12th.
I think the NEXUS profile might well be alittle aggressive when trying to get an 8t motor to go 8mins with 4 cells .... (i usually go with a straight 4amp linear)
I have to agree those fans are well noisey but there small to need the high rpm to move the amount of air a larger fan can at a lower rpm. I guess it was all about keeping it all in a small package that lead to the small high speed fans being used .
Oh well just testing and playing with it at the moment ........
Merciless is offline   Reply With Quote
Old 11-08-2005, 09:42 AM   #830
Shop Owner
nnick's Avatar
Oh yes they are loud
Try to discharge a fully charged battery
Other than that it's a great charger.
Nick
Nikolakopoulos Nick
RC RING
Enjoy RCing....
R/C Tech #82
IRT #123
Old 11-14-2005, 04:35 AM   #831
acutts's Avatar
Has anyone used the battery warming tray with the CELL MASTER? Is this to warm the cells before charging in cold temps???
acutts is offline   Reply With Quote
Old 11-14-2005, 05:45 AM   #832
sosidge's Avatar
Although I haven't used one, that is what the tray is for.
www.sosidge.com - www.muchmoreracing.com
Old 11-14-2005, 08:30 AM   #833
Mr. Shookie's Avatar
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Yes,,,,,it works great...
But read the Cell Master instructions so You don't over heat...
-SHookie <><
Its almost cold enough now but not quite yet...
Another month and it the warmer will be needed...
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 11-15-2005, 02:59 AM   #834
hi.
anyone know if we can power tire warmers or a rayspeed discharger from the output outlet?
also i lost my manual, the delta peak figure, is that refer to "mv per cell" or total?
Doomah is offline   Reply With Quote
Old 11-15-2005, 01:03 PM   #835
Shop Owner
nnick's Avatar
You can download the manual from here
You can power up much more warming tray and much more fan, I'm not sure if it's adequate for tire warmer
Nick
Nikolakopoulos Nick
RC RING
Enjoy RCing....
R/C Tech #82
IRT #123
Old 11-15-2005, 06:44 PM   #836
hi my charger is false peaking. here are the details
Gp3300 matched cells. I have dishcarged and trayed them.
I charge at 5.5amps delta peak at 3mv.
I set time lock out to 1:00, so it doesnt flase peak within the first minute.
I go to charge at 5.5amps, the voltage of the pack goes to about 8.5v and the voltage drops for about 5 seconds. (can see the arrow pointing down). it then says *Peak Cut* and stops charging
I have change Time Lock out to the default 10:00 but it still false peaks within the first 5 seconds.
ANy Ideas?
Old 11-15-2005, 07:10 PM   #837
JasonC's Avatar
Trader Rating: 48 (100%+)
anyone know what the diffrence between softe ware version 1.0 and 2.0 on the MM CTX charger is ??
#60 of the Original 100
Support your local Track, if not support MY local Track http://www.westcoastrcraceway.com/
Park on Alondra and ill Call the Tow Truck Myself. =)
JasonC is offline   Reply With Quote
Old 11-15-2005, 07:34 PM   #838
wah... ctx2 is out? i just bought a ctx-c. is it upgradable?
Old 11-15-2005, 07:35 PM   #839
Alex_kipper's Avatar
you have to hold the > key till you see a key sign on the charger, this means there is a lock out...
I didnt know there was a V2.0 cell master
Alex_kipper is offline   Reply With Quote
Old 11-15-2005, 10:50 PM   #840
Shop Owner
nnick's Avatar
If you want to use the lockput function you should use way more than 1 min!! It's no use if you set it so little. Usually is 10 minutes
CTX ver 2??? That's new.. Are you sure about this?
Nick
Nikolakopoulos Nick
RC RING
Enjoy RCing....
R/C Tech #82
IRT #123
Forum Jump
FS/FT: TEAM MUCH MORE Motor Master & Cell Master litespeed-dom R/C Items: For Sale/Trade 15 06-15-2006 07:44 PM
Team Orion Advantage w/ LiPo or Team Much More Cell master? RH Customs Electric On-Road 6 04-06-2006 05:05 PM
Team Much More Cell Master FRP R/C Items: For Sale/Trade 4 01-25-2006 02:04 PM
Team Much More Racing CTX Cell Master and CTX Motor Master letitroll R/C Items: For Sale/Trade 7 11-18-2005 10:25 AM
Team Orion Advantage or Team Much More Cell Master charger alana07 Electric On-Road 1 12-18-2004 04:37 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
