Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 10-24-2005, 07:24 AM   #796
Nexus Racing's Avatar
Originally Posted by Dan Reynolds
Is anyone experiencing problems with just a normal peak charge?
Whenever I use the CTX charge it seems to work fine and my battery packs take a good charge, however if I just use the peak charge it always cuts off at between 500mah - 800mah
When using peak charge mode, you sometimes need to set the long lockout (locks charger from delta peak cutoffs, but not from temperature or capaicty cutoffs). A battery can initially be unstable if has been trayed or dead-shorted, or if it has been stored for a little while.
To set the long lockout time, access the main menu by holding down "<". I set mine at 15-20min. By that time, even a dead-shorted battery will have stabilized to the incoming current. To activate the lockout, hold down "<" after starting the charge until you see the "key" symbol.
The CTX charge is already locked against peak detect for the first two phases, so setting long lockout is never neccessary.
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 10-24-2005, 07:28 AM   #797
Originally Posted by Mr. Shims
Would anyone have some inputs or profiles for Stock 27/23turn specific ctx charging?
GP3300
IB3600
IB3800
(loose cells)
Any tips would greatly be appreciated
We keep an updated list of CTX profiles here. When you click on some of them, they have different settings for 19t/Stock and Modified racing.
NEXUSRACING.com
Old 10-25-2005, 01:16 AM   #798
Paladin's Avatar
Just received my brand new CTX!
I too am after setting for IB3600.
The nexus site has GP3300 and IB3800.
Cheers
Paladin is offline   Reply With Quote
Old 10-25-2005, 06:50 PM   #799
MAD916's Avatar
Timezone Racing, Battle Ground Wasington Timezone Raceway Park " on-road outdoor european style road course. Timezone II 60'x100' indoor carpet track. info at www.timezoneracing.com
Tekin Racing, Corally USA, SMC, JACO, Top Racing, EDS Tools,APS Racing,Wolf Hobbies,
MAD916 is offline   Reply With Quote
Old 10-25-2005, 07:31 PM   #800
wallstreet's Avatar
Trader Rating: 18 (95%+)
Send a message via AIM to wallstreet
is the cell master the same as the orion charger ? they both look exactly the same
can someone please fill me in on the differences if there are any ?
wallstreet is offline   Reply With Quote
Old 10-26-2005, 02:18 PM   #801
Arun's Avatar
Cheers
Paladin,
We were never able to test profiles (nor did we receive any) for the IB3600 because the 3800's were released so quickly after the 3600 became popular.
Because they have a similar chemical makeup, I can only assume that a proportioned 3800 profile would work well. Try using one of the 3800 profiles, but with these mAH limits:
2850-2880-5000
Arun is offline   Reply With Quote
Old 10-26-2005, 02:46 PM   #802
Arun's Avatar
The Orion charger and Cell Master are very different (and made by different manufacturers).
Some unique features to Cell Master:
-Super Linear Current
-CTX step-charging (combination of Super Linear Current and step-charging)
-16 Bit AD delta peak detection (allows for very fine adjustments to delta peak)
-Li-Po charge
-output pin for charging accessories (warming tray, fans)
Unique features to Orion Advantage:
-Motor Run feature (13A max)
-standard step-charging
-Battery Tray and internal clock
-Some sort of lap counting system
Other than these differences, some say that it is difficult to charge trayed and dead-shorted packs with the Advantage becuase it has minimums for starting voltage.
There are more differences, but not all are worth mentioning in order to get the big picture accross.
Woops...meant to sign in as Nexus Racing...oh well .
Old 10-26-2005, 03:27 PM   #803
I have owned and used both Cellmaster and Orion Advantage charger.
And i definitely prefer the Cellmaster as i find it's much easier to use. Oh and it looks much better than the orion "plastic" charger too.
So i sold my orion and bought another cellmaster
yellow15 is offline   Reply With Quote
Old 10-26-2005, 07:27 PM   #804
Paladin's Avatar
Originally Posted by Arun
Paladin,
2850-2880-5000
Thanks Arun,
Will run with that.
I happened to buy 12 Sets when they first came out
Cheers
Old 10-26-2005, 10:46 PM   #805
Mr. Shims's Avatar
Thanks Arun. Will try immediately and give you feedback. - Cholo
Mr. Shims is offline   Reply With Quote
Old 10-27-2005, 02:07 AM   #806
Bluecow's Avatar
Default cable
i just got my cell master and its looks very nice ,
one question WHY are the cables for going to the power source so short !
i use a 12v battery for power and its never going to reach !
is there a better / best way to extend them , or i am i just better cutting
them and extending them !
thanks.
Bluecow is offline   Reply With Quote
Old 10-27-2005, 06:25 AM   #807
thanks.
It's meant to be used with a 12v power supply like the one Much-More sells or any other 12v power supply on the market with at least 10amps. Short wires and the really compact size of the Much-More power supply really helps to keep your pit area nice and tidy especially at large races when pit-spaces are at a minimal. You can cut your wires or better yet, make an extenstion cable so if you ever get a compact power supply, your original length cables will be intact.
Tony Vega is online now   Reply With Quote
Old 10-27-2005, 08:00 AM   #808
litespeed-dom's Avatar
thanks.
Get a MR power station!!!
Dom
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 10-27-2005, 10:52 AM   #809
Buyer Beware
is this charger good?
HELLOkitty is offline   Reply With Quote
Old 10-27-2005, 11:20 AM   #810
It's awesome. Nice and compact and now im looking at buying a second one once I get rid of the Turbo 35BL.
Forum Jump
FS/FT: TEAM MUCH MORE Motor Master & Cell Master litespeed-dom R/C Items: For Sale/Trade 15 06-15-2006 07:44 PM
Team Orion Advantage w/ LiPo or Team Much More Cell master? RH Customs Electric On-Road 6 04-06-2006 05:05 PM
Team Much More Cell Master FRP R/C Items: For Sale/Trade 4 01-25-2006 02:04 PM
Team Much More Racing CTX Cell Master and CTX Motor Master letitroll R/C Items: For Sale/Trade 7 11-18-2005 10:25 AM
Team Orion Advantage or Team Much More Cell Master charger alana07 Electric On-Road 1 12-18-2004 04:37 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
