Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 10-20-2005, 08:09 PM   #781
Nexus Racing's Avatar
Originally Posted by EAMotorsports
Arun you coming up this weekend still?
EA
Yup, I'm leaving tomorrow night. See ya Sat.
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 10-20-2005, 08:12 PM   #782
Originally Posted by yellow15
so what is a good temperature when the charging is finished?
slightly warm? 40degree C +? or ??
that's for the GP3300 or 3700..
A good stopping point is around 48 degrees. This is not too cool for racing and not too hot.
The cells will actually raise a little in temp after charging has stopped (up to around 50-51 degrees)
NEXUSRACING.com
Old 10-20-2005, 08:13 PM   #783
Son In-Kwon's Avatar
yellow15..
I think.. 42~45degree C is good..
When you race, 45~48degree C is also good.
If you start charge at 25~30degree C,
your Cell Master end charge approximately about 45degree C..
Of course, Stopping temp depends on outside temp.
Sorry for my poor english..
Son In-Kwon
from In-cheon, Korea.
Son In-Kwon is offline   Reply With Quote
Old 10-20-2005, 08:26 PM   #784
EAMotorsports's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to EAMotorsports
Cool...See you then. I think we'll have some bite this weekend
EA
RCAmerica | Xray | Hudy | EAMotorsports | SMC | Jaco | PRS | Killer Concepts | TNT-FX.COM | Futaba | P1 Brand | JConcepts | Parma.
EAMotorsports is offline   Reply With Quote
Old 10-20-2005, 09:58 PM   #785
Korey Harbke's Avatar
Send a message via AIM to Korey Harbke
Originally Posted by litespeed-dom
So since we are in the same region, about the same temperature, use same IB's, run the same car.... use the same charger.... what's your starting point Sush!?
Dom
I use the nexus racing profiles when step charging, and adust the last step charging amps for punch as needed. For the liniear charge I put it at 07 or 08 with the lock out on, with a temp cut of 48-49 deg.
-Korey
Hot Bodies USA - HPI Racing - Atsushi Hara Racing Products - Team ORCA USA - Thunder Power R/C - Parma PSE - Ko Propo America - PPD Billet - Slapmaster Tools - Turtlemaster Racing - Remote Control Hobbies - Timezone Raceway - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 10-21-2005, 12:45 PM   #786
Bluecow's Avatar
Default orion advantage
i was thinking og getting one of thease , some questions .
1) the orion one looks a copy of this , which one is better and why ?
2) is there any new upto date profiles for the ctx charge for
5mins, 6 cells, GP 3700 ,
3) do the orion profiles work or can they be used on this ?
i see hara uses the orion version and sets it to 5 cells !
do you have to / or can you use this profile on the much more ?
just not to sure one which one to buy , honest answer would be nice
and not just because its a much-more thread, thanks...
Bluecow is offline   Reply With Quote
Old 10-21-2005, 03:38 PM   #787
Alex_kipper's Avatar
-Korey
From what people are saying bout the NEXUS settings for the IB3800s ON CTX i found that i have to set the peak setting WAY higher...but that is just me....
Alex_kipper is offline   Reply With Quote
Old 10-21-2005, 03:43 PM   #788
Andrew_Carter's Avatar
Send a message via MSN to Andrew_Carter
You really dont want the Orion charger,it looks like somthing from the earlier learning centre!
Hot Bodies ~ HPI Racing ~ Orion ~ Nosram ~ Atsushi Hara Racing Products ~ Edit ~ Hudy ~ Ninja Graffix ~
Andrew_Carter is offline   Reply With Quote
Old 10-22-2005, 04:00 AM   #789
badboy's Avatar
No problem, James .
It has been said that NiCDs perform best with a linear charge. The charging rate is entirely up to you...just don't melt your connectors .
As a general rule:
Lower charging rate=more run-time, less power
Higher charging rate=more power, less run-time
NiCD's also like higher delta peak settings. I would start with an 09 or 10 setting.
Additionally, a stick pack has more resistance in its connections. This can cause a false peak, especially in combination with lower delta peak settings, so you will probably want to set a long-lockout for the first 10-15 minutes of charge.
thanks nexus. . . 09 or 10 for the pack or per cell? will this be 0.009 and 0.010 respectively?
badboy is offline   Reply With Quote
Old 10-22-2005, 04:39 AM   #790
Formula1fan's Avatar
I just picked up a integy 16X8 charger. I tried step charging and it seems like my batteries are not taking the MiAh that they did when I charged with a constant amps. Has anyone noticed a drop like this?
Formula1fan is offline   Reply With Quote
Old 10-22-2005, 05:14 AM   #791
Rob Phillips's Avatar
I haven't had those results with my CTX. The Miah has been cosistant from what I have seen. I not to familar with the Integy chargers though.
Rob Phillips is offline   Reply With Quote
Old 10-22-2005, 05:43 AM   #792
Thanks for you input. I just asked here, because the only other guy that has a step charge i know of has the much more charger.
Old 10-24-2005, 01:31 AM   #793
Mr. Shims's Avatar
Would anyone have some inputs or profiles for Stock 27/23turn specific ctx charging?
GP3300
IB3600
IB3800
(loose cells)
Any tips would greatly be appreciated
Mr. Shims is offline   Reply With Quote
Old 10-24-2005, 01:57 AM   #794
Is anyone experiencing problems with just a normal peak charge?
Whenever I use the CTX charge it seems to work fine and my battery packs take a good charge, however if I just use the peak charge it always cuts off at between 500mah - 800mah
Dan Reynolds is offline   Reply With Quote
Old 10-24-2005, 02:02 AM   #795
B&O
B&O's Avatar
I have tested with 15V supply. The Li/Po charger still stop charging at half way. I don't really know what to do anymore.
B&O is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
nsgland
Forum Jump
FS/FT: TEAM MUCH MORE Motor Master & Cell Master litespeed-dom R/C Items: For Sale/Trade 15 06-15-2006 07:44 PM
Team Orion Advantage w/ LiPo or Team Much More Cell master? RH Customs Electric On-Road 6 04-06-2006 05:05 PM
Team Much More Cell Master FRP R/C Items: For Sale/Trade 4 01-25-2006 02:04 PM
Team Much More Racing CTX Cell Master and CTX Motor Master letitroll R/C Items: For Sale/Trade 7 11-18-2005 10:25 AM
Team Orion Advantage or Team Much More Cell Master charger alana07 Electric On-Road 1 12-18-2004 04:37 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
