Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 10-06-2005, 12:58 AM   #721
Hey Guys,
Ive just upgraded to a cell master charger and was wondering if someone could please give me advise/programmes on charging my batts. Im using the following
Trinity team matched gp Ni-MH 3300s
Trinity team matched sanyo Ni-MH 3000s
Sanyo unmatched Ni-CD 1500s (I know these suck but its a stock rule and I need to get the most outta them)
Any advise will be much appreciated.
Thanks in advance,
G
Floss_LUC is offline   Reply With Quote
Old 10-06-2005, 02:46 AM   #722
TeamMuchMore's Avatar
please check profiles on www.nexusracing.net
they have most updated profiles being used by most racers
thanks
james
TeamMuchMore is offline   Reply With Quote
Old 10-06-2005, 04:48 AM   #723
Hi
I have one question:
How big must the powersupply be to use both the motormaster and the cell master at the same time. Charging around 6 amp, and run in/test motors at around 5 volt...
sturla is offline   Reply With Quote
Old 10-06-2005, 05:07 AM   #724
hi
if i do step charge to get extra puch, if i 3 step charged it a few hours before the race at home and i just repeak at the track, would the benifit be lost or still retained?
i only got 1 charger and i can't do a full 3 step charge at the track 60minutes before the race as each heat is 30minutes a cycle....
cheers
qwerty is offline   Reply With Quote
Old 10-06-2005, 12:03 PM   #725
thanks
james
Great, thanks for that. They have profiles for 3300-3800 batteries but what about profiles for 3000s and 1500??? If anybody can help Id be for ever greatfull.
Thanks,
G
Old 10-06-2005, 12:42 PM   #726
Batteries always perform the best when you use it right after the charging.
you can charge it with peak charge at high amperage or get another cell master .
You don't always have to use CTX mode, it will give you little bit of extra but peak charge will still give you good performance out of your battery with CM.
The technology behind CM is the super accurate delta peak detection, which allows battery to perform better(more punch), charge cooler and it won't hurt your battery.
thanks
Originally Posted by qwerty
hi
cheers
Old 10-06-2005, 12:47 PM   #727
charging at 6amp will draw more amp then 6, let say it draws maximum 7. so you need at least 14 amp for chargers only. i saw some motors pull 10 amp at 5 volts. then you will be needing minimum 24 amp.
by the way CM has it's auto restart function, if the power is not sufficient, it will wait until power comes back and resume the charging. user won't have to touch anything when this happens.
thanks
james
Originally Posted by sturla
Hi
Old 10-06-2005, 05:41 PM   #728
Default Service
Originally Posted by Nexus Racing
I have seen some confuse the flex setting with the fan setting; are you certain that it says "Fn" in every phase?
The only time I have ever seen this happen is when Flex was accidentally activated when charging at a very low amp rate (such as 0.2A in phase 2).
Hi,
I think your CM's main IC has trouble, pls call for service at your LHS.
It hardly happens, I guess your IC was broken by some static electricity.
Pls include the symtom when you ship the unit.
thanks,
SweepRacing ProSpec TOP GSracing enRF Hudy Futaba
Ryan Lee is offline   Reply With Quote
Old 10-06-2005, 05:45 PM   #729
Matt Howard's Avatar
Ryan, I lost the Team Much More hat you gave me during my move. Who do I have to contact to get another one?
Team Losi, Horizon Hobby, Express motorsports, BMI racing, Hobbytown Hobbyplex-home of the 2008 carpet nats and 2009 electric offroad nats
Official member of The Guild of Calamitous Intent
Matt Howard is offline   Reply With Quote
Old 10-07-2005, 08:59 AM   #730
tranced's Avatar
What is the discharge rate (in Amps) on the Zero-V Discharge Tray?
tranced is offline   Reply With Quote
Old 10-09-2005, 03:55 AM   #731
Retard's Avatar
hey guys need some help here..my cellmaster is working properly but the fans are not moving at all any idea whats happening? if the fans are spoil is it possible to change it myself instead of sending it over for a fix?
Retard is offline   Reply With Quote
Old 10-09-2005, 04:44 AM   #732
DIMO's Avatar
Default dropped
Have you dropped it, being serious, couldve seized the fans... if ure game while ure charging and the fans are meant to come on try and spin them some home....maybe they need a bit of momentum to get going....also you could open it to see if a connection has been dislodged somewhere, but u will void the warranty and it can be a risky procedure....the only other think i can think of is the software has somehow cancelled out the fan feature
DIMO is offline   Reply With Quote
Old 10-09-2005, 04:47 AM   #733
Retard's Avatar
Previously my power supply blown while i was charging..ive tried to spin it to make it move but it moves at a very low speed. Any idea? thanks.
Old 10-09-2005, 06:39 PM   #734
tornado's Avatar
Originally Posted by Ryan Lee
Hi,
thanks,
Thanks Ryan !!
Finally some light has been shed. .......... I'm located in Kuala Lumpur, Malaysia. May I know where to ship my CM for repairs ? Straight to Korea ?
BTW, I've tried the same 3 phase charge setup with 4 cells, it did completed the charge process BUT during the 2nd phase the CM continuously playing the tune when you start the charge.
tornado is offline   Reply With Quote
Old 10-09-2005, 07:10 PM   #735
ooge's Avatar
Send a message via ICQ to ooge
Originally Posted by tornado
Thanks Ryan !!
Bryan,
Hobby Haven sells this charger here. Didn't you get it from them?
ooge is offline   Reply With Quote
Forum Jump
FS/FT: TEAM MUCH MORE Motor Master & Cell Master litespeed-dom R/C Items: For Sale/Trade 15 06-15-2006 07:44 PM
Team Orion Advantage w/ LiPo or Team Much More Cell master? RH Customs Electric On-Road 6 04-06-2006 05:05 PM
Team Much More Cell Master FRP R/C Items: For Sale/Trade 4 01-25-2006 02:04 PM
Team Much More Racing CTX Cell Master and CTX Motor Master letitroll R/C Items: For Sale/Trade 7 11-18-2005 10:25 AM
Team Orion Advantage or Team Much More Cell Master charger alana07 Electric On-Road 1 12-18-2004 04:37 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
