Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 07-22-2005, 10:04 PM   #631
DIMO's Avatar
Default Just Wanted TO Know
Hey, im looking into buying one of these chargers. Just wanted to know what rate of amps you can discharge at. And also can the user select the cut off.
DIMO is offline   Reply With Quote
Old 07-22-2005, 10:58 PM   #632
10 amp discharge and of course you can set voltage cut-off!
Rody is offline   Reply With Quote
Old 07-23-2005, 09:58 AM   #633
korevo's Avatar
Unhappy
Any Ctx Profile for GP3700 Mines always temp cut.......Need your help
Will be running 23t motors and 7t motors thanks!
korevo is offline   Reply With Quote
Old 07-24-2005, 06:04 PM   #634
Nexus Racing's Avatar
Try one of the 3800 profiles we posted here: CTX Charging Profiles
Are you temp cutting early, or is your battery still getting a full charge?
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 07-24-2005, 07:00 PM   #635
Alex C's Avatar
How are the IB3800 Charging Profile compared to the recommended charging for GP3700 batteries.
Alex
RC America - Xray - Hudy - Jaco - SMC / Ko Propo USA / EA Motorsports /
Alex C is offline   Reply With Quote
Old 07-24-2005, 08:58 PM   #636
Korey Harbke's Avatar
Send a message via AIM to Korey Harbke
The IB3800's like a lower delta peak
Hot Bodies USA - HPI Racing - Atsushi Hara Racing Products - Team ORCA USA - Thunder Power R/C - Parma PSE - Ko Propo America - PPD Billet - Slapmaster Tools - Turtlemaster Racing - Remote Control Hobbies - Timezone Raceway - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 07-25-2005, 08:27 AM   #637
karlo511's Avatar
anyone have any profiles for outside temps in the high 80' - 90' F?
this would be for 3300's and 3800's.
thanks
karlo511 is offline   Reply With Quote
Old 07-25-2005, 09:53 AM   #638
Arun's Avatar
thanks
I like these profiles for 80-90 deg temps:
IB3800–Nexus Racing–Standard
GP3300–Surikarn–Modified Racing
GP3300–Nexus Racing–19t/Stock High Power Competition
I think that these profiles are ideal for that temperature range. As temps rise higher, sometimes you have to run a little milder on the settings, but these should be perfect for 80-90 degrees.
Arun is offline   Reply With Quote
Old 07-25-2005, 01:31 PM   #639
karlo511's Avatar
thanks, i'll give them a try.
Old 07-26-2005, 09:00 AM   #640
Fredda's Avatar
What delta peak value should i set for charging Transmitter and Reciever packs ? The charger peak cuts all the time when im trying to charge these batteries.
Fredda is offline   Reply With Quote
Old 07-26-2005, 02:04 PM   #641
Arun's Avatar
I charged one last night at 06 (.006v), and it didn't cut until it was fully charged (1A charging rate).
It peaked at 44 degrees C (111 deg F).
If you keep having problems with that particular pack, you can always just run a high delta peak and set your temp cut around 44.
Old 07-26-2005, 02:09 PM   #642
Fredda's Avatar
Thanks will try i tomorrow !!!!!
Old 07-31-2005, 07:12 PM   #643
Default discharging capacity
With the same battery,I've got a higher discharging capacity in my cell master than in my lrp pulsar competition. Do you guys have higher discharging capacity in cell master,too.why would this happen?Is the capacity indication correct?
Thanks.
gallagher is offline   Reply With Quote
Old 08-01-2005, 07:40 AM   #644
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Just had my first experience with the Cell Master this weekend at the Hitec race......well first ecperience with two Cell Masters but that is besides the point....
I am very happy with them, they don't false peak my dead short packs and they are keepign the packs in great shape...Can not wait till I do some more packs....I am going to up the amps though as I am using the MM battery heatsinks and the packs were coming off a little cooler than I am use to...so I am going to up the first and third stage .5-1.0 amps and see where it all plays out at...So far soooooooooo good....
-SHookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 08-02-2005, 04:38 PM   #645
Thanks.
If anything, the CM's readings will be the actual values. Based on our discussions with Ryan Lee, every stride was made by MuchMore to make EVERY value given by the CM as accurate as possible. Basically, the way the CM operates is what should be the industry standard .
NEXUSRACING.com
Forum Jump
FS/FT: TEAM MUCH MORE Motor Master & Cell Master litespeed-dom R/C Items: For Sale/Trade 15 06-15-2006 07:44 PM
Team Orion Advantage w/ LiPo or Team Much More Cell master? RH Customs Electric On-Road 6 04-06-2006 05:05 PM
Team Much More Cell Master FRP R/C Items: For Sale/Trade 4 01-25-2006 02:04 PM
Team Much More Racing CTX Cell Master and CTX Motor Master letitroll R/C Items: For Sale/Trade 7 11-18-2005 10:25 AM
Team Orion Advantage or Team Much More Cell Master charger alana07 Electric On-Road 1 12-18-2004 04:37 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
