Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 07-13-2005, 04:21 PM   #616
Hebiki's Avatar
Originally Posted by TeamMuchMore
Hi Ryan
I change the avatar too~
is this copyrighted? either way i am using it
james
p.s hey arun you want me to make one for you and kumpol?
James.. i sent you an email. please let me know asap. its very important
thank you!
Sponsored by:
REI | Coleman | Patagonia | The North Face | Camping World
http://video.about.com/camping/How-To-Build-a-Campfire.htm
Motto: A sniper who has a grassy knoll on lockdown.
Hebiki is offline   Reply With Quote
Old 07-15-2005, 06:45 AM   #617
Fredda's Avatar
Default Zero peak cutoff !
My mmcm zero peak cutoffs ! Is the Mv set too low when that happens or is it just the batteries ?
Fredda is offline   Reply With Quote
Old 07-19-2005, 07:22 PM   #618
Alex C's Avatar
Smile GP 3700 CTX Charge Profiles
I am currently racing 19 Turn & Stock Foam while utilizing the CTX 3 Step Charge Method on GP3700, I am curious to see if anyone has anything better! Attached below is my current charging method that I am using, any help would be greatly appreciated!!
1/3
3300mA @7.0
Fn
2/3
3350mA @.02
Fn
3/3
4400mA @4.5
Tn Temp@48 Delta Peak@ 10
Repeak 5 Min Delay @ 250mA
Thanks in Advance for all your help
Best Regards
Alex
Alex
RC America - Xray - Hudy - Jaco - SMC / Ko Propo USA / EA Motorsports /
Alex C is offline   Reply With Quote
Old 07-19-2005, 09:25 PM   #619
Arun's Avatar
What value did you set for your delta peak?
Arun is offline   Reply With Quote
Old 07-19-2005, 09:30 PM   #620
Arun's Avatar
1/3
3300mA @7.0
Fn
2/3
3350mA @.02
Fn
3/3
4400mA @4.5
Best Regards
Alex
I am curious; do your batteries "temp cut" or "peak cut" more often? Also, what environment (indoors or outdoors)? If peak cut, what temp do the batteries peak at?
Old 07-19-2005, 10:41 PM   #621
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
1/3
3300mA @7.0
Fn
2/3
3350mA @.02
Fn
3/3
4400mA @4.5
Best Regards
Alex
Ya i also curious that you putting delta peak 10 will it be very hot for your cell?
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 07-19-2005, 11:31 PM   #622
Alex_kipper's Avatar
i just ordered a Cell master and a zero-v and this set up should be awsome!!!
Is there any tips that you guys have for me?
Ill be using Smc IB3800's
And ill be racing Mod class
Alex_kipper is offline   Reply With Quote
Old 07-20-2005, 07:19 AM   #623
Alex C's Avatar
Arun,
I am running Indoors on Foam carpet, temp @ 80*, and I have seen the batteries temp cut more often.
Guo Chean,
My GP3700 cells come of warm while using the 3 step method compared to the peak method.
Alex
Old 07-20-2005, 07:45 AM   #624
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
I just ordered one of these and wanted to know if anyone had a step setup that also utilizes the Much More Battery Heatsinks and still have the cells come off at or near 120*F. If so please post it here so that I can have a head start.
my thoughts were
3300 mah @ 8amps
3350mah @ .5amps
4400mah @ 6amps
Let me know only if you are using the battery heatsinks as I will be using them.
Thanks,
-Shookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 07-20-2005, 10:59 AM   #625
Arun's Avatar
my thoughts were
3300 mah @ 8amps
3350mah @ .5amps
4400mah @ 6amps
Thanks,
-Shookie <><
Shookie,
The heatsinks do not seem to require a drastically different profile, mainly just increases in charging rate or delta peak (as we discussed earlier). I use the heatsink when I am either in a poorly ventilated area during the day or just outdoors in the heat, and I'll usually increase my delta peak and charging rate a little (unless the conditions are very hot).
What kind of batteries will you be using? The profile you listed will probably get your batteries a bit hotter than the typical profiles we have been listing on this thread. If you want to try it, keep your temp cut at 48 (118 deg F).
Old 07-20-2005, 11:10 AM   #626
Nexus Racing's Avatar
Here is the current CTX profile for IB3800 supported by Nexus Racing. It works excellent for mod racing.
Step 1
3050mA 7.0A
Flex off
Step 2
3080 0.2A
Flex off
Step 3
4900mA 4.0A (for more punch, increase to 4.5 or 5.0A)
Flex off
Temp 48
delta peak (depends on ambient temp, 04 or 05 is a safe starting point).
There will be an "Intellect Battery Care" article featured on our web-site soon!
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 07-20-2005, 04:51 PM   #627
I am usign GP 3700's and a few 3300's
I will try the suggested profiles...and keep a close eye on the cells.
I race stock adn 19T so I kind of need that punch...
I already deadshort so will that setup still be a good starting point? or will I need a little more time on the first step?
Thanks in advance.
-Shookie <><
Old 07-20-2005, 06:51 PM   #628
Step 1
3050mA 7.0A
Flex off
Step 2
3080 0.2A
Flex off
Step 3
Flex off
Temp 48
Thats great!!!
What bout a Tx Pack what should i set the delta peak for...
The Tx pack is a 3600 8 cell pack
Old 07-21-2005, 02:07 AM   #629
sosidge's Avatar
For a TX pack you don't need to be getting the final few percent of performance out of the cells. I would just stick to a linear charge, at 3 or 4A.
www.sosidge.com - www.muchmoreracing.com
sosidge is online now   Reply With Quote
Old 07-22-2005, 02:45 PM   #630
Here it is: Intellect Battery Care Using MuchMore Products
If you have any questions, feel free to post them here or contact us through our web site.
NEXUSRACING.com
Forum Jump
FS/FT: TEAM MUCH MORE Motor Master & Cell Master litespeed-dom R/C Items: For Sale/Trade 15 06-15-2006 07:44 PM
Team Orion Advantage w/ LiPo or Team Much More Cell master? RH Customs Electric On-Road 6 04-06-2006 05:05 PM
Team Much More Cell Master FRP R/C Items: For Sale/Trade 4 01-25-2006 02:04 PM
Team Much More Racing CTX Cell Master and CTX Motor Master letitroll R/C Items: For Sale/Trade 7 11-18-2005 10:25 AM
Team Orion Advantage or Team Much More Cell Master charger alana07 Electric On-Road 1 12-18-2004 04:37 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
