Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 07-08-2005, 03:35 PM   #601
TeamMuchMore's Avatar
Default Logo
Hi Ryan
I change the avatar too~
is this copyrighted? either way i am using it
james
p.s hey arun you want me to make one for you and kumpol?
TeamMuchMore is offline   Reply With Quote
Old 07-08-2005, 03:52 PM   #602
s2
s2's Avatar
Thumbs up
Originally Posted by Arun
The higher the amp rate, the more power. It is safer to charge at a higher amp rate in the beginning, as the battery will not overheat. Most CTX profiles also have a very low amp rate in the second phase, such as .2 amps. This acts as a slight "cool down" period to prepare the battery for peaking. When CTX enters the third phase, the same rules then apply...higher amp rate will equal more power. When you combine high and low amp rates in a CTX profile, you are able to achieve superior power and run-time.
short answer: the higher amp rate in the last step will give you more punch .
cheers fella
s2 is offline   Reply With Quote
Old 07-10-2005, 02:16 PM   #603
Shop Owner
nnick's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
Today I tried the following setup on a very old GP3300 (very hot day)
7A 2500
0.2A 2530
4A 4000
The charge was stopped and the message was Zero Cut.
Any ideas why? What that mesage really means (I've read the manual but why the voltage stayed for 7 seconds the same?) What is the meaning of that?
I didn't try it again, used linear 5A for the rest of my batteries since I wanted to find a steup on my car.
Next Saturday I'll try the charger setup again
One more thing.
Suddenly when I was charging the display characters were dissappeared! The blue was there, the charger was working but no charcters! I lifted the charger and put it over a box, removed the plugs from the ps and put them back and it worked again. Is everything ok? I guess today's heat was too much!
Nick
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
nnick is offline   Reply With Quote
Old 07-10-2005, 02:21 PM   #604
TFR
TFR's Avatar
7A 2500
0.2A 2530
4A 4000
Nick
What delta peak did you set at? If it is 0mV, that is the zero cut I believe.
Muchmore l AHRP l Xenon l Futaba
TFR is offline   Reply With Quote
Old 07-10-2005, 02:25 PM   #605
Shop Owner
nnick's Avatar
Forgot that 15mv was delta peak
Nick
Nikolakopoulos Nick
RC RING
Enjoy RCing....
R/C Tech #82
IRT #123
Old 07-10-2005, 05:29 PM   #606
Son In-Kwon's Avatar
My first reply at this forum..
Nick..
If you select 0mV, your CM message Zero peak.
But If you select 15mV, I think that CM tell you Peak cut.
When you chrage by using CTX mode,
working Long-lock-out till the second step(2/3).
Long-lock-out means no stop(cut off) by peak detecting.
When start the third step,
CM detects your batteries` delta peak that you set up.
I think, you set zero peak(0mV),
or you stored 15mV at peak charge mode.
Each charge mode has each set-ups.
If you use 0V discharger likes Zero-v discharger by Muchmore,
You have to set Long-lock-out
about 20minutes in peak charge mode
When you push the start button in peak charge mode,
you push the button during 3 seconds!
Then your CM display Key-icon instead of 15mV.
Key icon means Long-lock-out is functioning.
I hope my coach ryan tell you more things about Cell Master.
Cell Master is my best weapon in race
Sorry for my poor english..
Son In-Kwon,
from korea.
Son In-Kwon is offline   Reply With Quote
Old 07-10-2005, 11:16 PM   #607
Mopar's Avatar
Originally Posted by speedxl
If you cant find it get in touch with Kumpol or Arun at www.nexusracing.net
They will ship anywhere. They are the main dealer here in the US.
Thanks, Got one coming in a few days from Nexus. Can anyone suggest a CTX profile for stock racing, Please! Would be much appreciated. Using six month old GP3300's.
Mopar is offline   Reply With Quote
Old 07-10-2005, 11:34 PM   #608
Shop Owner
nnick's Avatar
Son In-Kwon I will check it out. I think that I have set it 15mv but maybe you are right!
Any cooment on this issue?
Nick
Nikolakopoulos Nick
RC RING
Enjoy RCing....
R/C Tech #82
IRT #123
Old 07-11-2005, 08:14 AM   #609
Nexus Racing's Avatar
Step 1
2600mA 7.0A
Fn
Step 2
2630 0.2A
Fn
Step 3 4200mA 5.5A
Tn, Temp 55, Delta Peak 25
This profile should work good for Stock and 19T. Oh, you should put your pack on discharge tray for an hour first.
Let us know how it goes.
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 07-11-2005, 01:00 PM   #610
Mopar's Avatar
Thanks, I'll give that a try.
Old 07-11-2005, 02:28 PM   #611
DirtyDog3375's Avatar
Trader Rating: 26 (100%+)
Send a message via MSN to DirtyDog3375
Originally Posted by Nexus Racing
Step 1
2600mA 7.0A
Fn
Step 2
2630 0.2A
Fn
Step 3 4200mA 5.5A
Is this ctx setup okay for charging ib3600 cells that are relatively new???
DirtyDog3375 is offline   Reply With Quote
Old 07-12-2005, 03:13 AM   #612
komkit's Avatar
Send a message via ICQ to komkit Send a message via AIM to komkit Send a message via Yahoo to komkit
Step 3 4200mA 5.5A
The 3rd step is probably way too rough for the IB3600s.
I'd increase the 4200mA cap to around 5000mA @4A (to prevent the capacity cut off). Drop the Temp cut off to 47~49 and Delta peak to 04~05.
Hot Bodies - HPI Racing - CFX Paintworks - The Track
Peelsmanship is The Art of Wheelsmanship
komkit is offline   Reply With Quote
Old 07-12-2005, 03:21 AM   #613
thanks for the info mate. Much appreciated.
Old 07-12-2005, 08:22 AM   #614
speedxl's Avatar
No prob enjoy the charger. Its the schiznet! Kumpol and Arun have the best customer service!
Remember if you need anything Much More give them a shout! www.nexusracing.net
Team PRC / Team Power Push / Team Bandit / Corally USA / Rc4Less
speedxl is offline   Reply With Quote
Old 07-12-2005, 08:56 AM   #615
komkit's Avatar
Did I hear the echo? Yeah - I have to 2nd that on the charger and the Nexusracing's crews
Forum Jump
FS/FT: TEAM MUCH MORE Motor Master & Cell Master litespeed-dom R/C Items: For Sale/Trade 15 06-15-2006 07:44 PM
Team Orion Advantage w/ LiPo or Team Much More Cell master? RH Customs Electric On-Road 6 04-06-2006 05:05 PM
Team Much More Cell Master FRP R/C Items: For Sale/Trade 4 01-25-2006 02:04 PM
Team Much More Racing CTX Cell Master and CTX Motor Master letitroll R/C Items: For Sale/Trade 7 11-18-2005 10:25 AM
Team Orion Advantage or Team Much More Cell Master charger alana07 Electric On-Road 1 12-18-2004 04:37 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
