Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 06-21-2005, 11:01 PM   #511
You will get an error on your GFX as well,I think CE has an update that let's you charge from zero.
Hyper1 is offline   Reply With Quote
Old 06-21-2005, 11:24 PM   #512
danjoy25's Avatar
R/C Tech Charter Subscriber
Peak charging from 0 volts might false peak as the voltage is too low and does not have the locked out function the step charging has.
Venom GPV-1 R/C Bike / Top Racing Photon / M03 racer
danjoy25 is offline   Reply With Quote
Old 06-22-2005, 02:06 AM   #513
sosidge's Avatar
If you're suggesting that you want to start charging a battery pack that is wired permanaently into a short circuit, that is not something I would recommend at all. In fact it could be very dangerous.
www.sosidge.com - www.muchmoreracing.com
Old 06-22-2005, 07:24 AM   #514
Alex C's Avatar
Originally Posted by kumpol
Step 1
2600mA 7.0A
Fn
Step 2
2630 0.2A
Fn
Step 3 4200mA 5.0A
Tn 48 10 R1
repeak 1 delay 5min. repeak capacity 250mAh
This profile is from Ryan Lee. He set this for a couple people in 19T class at the Reedy 2005. And I found out this was very good for 19T class at the Reedy.
Question, IS this for GP3300 or GP3700
Alex
RC America - Xray - Hudy - Jaco - SMC / Ko Propo USA / EA Motorsports /
Alex C is offline   Reply With Quote
Old 06-22-2005, 07:25 AM   #515
speedxl's Avatar
We where using this profile for 3300's. Once you use it you will be impressed the way the batteries run.
Team PRC / Team Power Push / Team Bandit / Corally USA / Rc4Less
speedxl is offline   Reply With Quote
Old 06-22-2005, 01:05 PM   #516
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
does any new setting for GP3700 and IB 3800 cell charging mode for touring car???
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 06-23-2005, 01:42 PM   #517
Hi Cell Master Owners!!!!
I will be charging my first Lipo pack soon on the Cell Master, its a 3 cell, is there anything special I should know or setup on the charger before I charge the Lipo?
Now that I will be charging Lipos it makes me love this thing even more, actually I wouldnt have tried Lipos if I didnt a have the Cell Master
Thanks!!
Tbevofreak is offline   Reply With Quote
Old 06-23-2005, 06:40 PM   #518
Default Zero delta peak
CTX CHG mode has Long Locked Out function.
You will see double key marks on the screen if you push the start button and hold for few second.
20minutes LLO works fine always,
According to my test,
Most false peak after 20minutes are caused by bad contact or in case some shock interrupted.(dropping you wrench etc.)
Zero-delta peak has algorithm which terminates charging if batteries' voltage stay for 7 seconds.
It will prevent overcharging, would not hurt your expensive batteries.
Low charging amp or cell no. may cause false peak.
Thanks,
Ryan
Ryan Lee is offline   Reply With Quote
Old 06-24-2005, 09:11 AM   #519
Capacity compared with other chargers
I am new to CTX cell master.While testing ,I found the charger seems to have lower charging capacity compared with my Lrp pulser competition.
Guys,what about your cell master charger?Will you have the same situation?
gallagher is offline   Reply With Quote
Old 06-24-2005, 09:24 AM   #520
Gallagher, the Cell Master is actually more precise on the amount of capacity your cells are taking.The LRPs dont calculate the mahs the same way and are not as acurate, its normal to see a 200\400mah difference depending on the chargers...
So dont worry its normal, actually will soon realize how much the Cell Master is better compared to the LRP, I know I had both
The LRP isnt a real super linear charger like the Much more
Old 06-24-2005, 02:06 PM   #521
TeamMuchMore's Avatar
Thanks!!
One thing you need to know when you use lipo.
USE THE LIPO MODE TO CHARGE LIPO
TeamMuchMore is offline   Reply With Quote
Old 06-24-2005, 03:02 PM   #522
stikman's Avatar
Well said, Master Lee
I wonder what will happened if someone try to CTX charge the LiPo
Nospoom S.
stikman is offline   Reply With Quote
Old 06-25-2005, 06:41 AM   #523
Hi,
Thanks for the reply, I got the PCM guard to charge my Polyquest 1800 but it doesnt work when I use it with the Cell Master, is it normal?
I can charge the pack fine without the PCM guard though.BTW, the PCM is a little device thats in between the charger and the pack, it balances the voltage of eatch pack to avoid an unmatched pack, it prevents from over charging too
Thanks!
Old 06-25-2005, 07:31 AM   #524
speedxl's Avatar
As tbevofreak said these chargers are accurate. On my Lrp's I would get anywhere from 3800 to 4100 mahs charged into the batteries. Mind you I dead short. With the cell master in ctx mode I'll get just about the same on the lower side. 3800 to 3900.
Though when I charge four cell packs on regular peak charge(none ctx) I'll get 3300 to 3700 mah in. I discharge the cells on a zero discharger before charging. Thus the batteries will have more punch and have longer run time. Dont think your batteries are falling off. The chargers and power supply have the cleanest voltage you'll ever use. This truely is linear.
The performance shows on the track.
Old 06-26-2005, 07:14 AM   #525
Default repeak??
Thanks for the replies. I will try more times.
Guys, do you have easier way to repeak a charged battery?
I reset long lock out time to 0 min and enter an uncertin battery capacity every time.It's annoying.
I wonder is there any bettery way to repeak(not to repeak right after the battery is charged )?
Thanks.
Forum Jump
FS/FT: TEAM MUCH MORE Motor Master & Cell Master litespeed-dom R/C Items: For Sale/Trade 15 06-15-2006 07:44 PM
Team Orion Advantage w/ LiPo or Team Much More Cell master? RH Customs Electric On-Road 6 04-06-2006 05:05 PM
Team Much More Cell Master FRP R/C Items: For Sale/Trade 4 01-25-2006 02:04 PM
Team Much More Racing CTX Cell Master and CTX Motor Master letitroll R/C Items: For Sale/Trade 7 11-18-2005 10:25 AM
Team Orion Advantage or Team Much More Cell Master charger alana07 Electric On-Road 1 12-18-2004 04:37 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
