Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 12-21-2004, 07:50 PM   #166
Kenneth Tan's Avatar
So what is a good delta peak value on the cell master for the GP3300 to peak at 52degrees? Sanyo 3600? Thanks!
ps. need to know this just as a precaution to the temp sensor becoming unattached to the battery when charging....
Kenneth Tan is offline   Reply With Quote
Old 12-23-2004, 07:07 PM   #167
Default Delta peak
4mV~12mV always works fine,
If your want to terminate charging by Temp Probe, 8~12mV will be ok. Pls test then let me know the result!
For sanyo3600, I recommend to set lower value than GP3300.
2mV~6mV.
Merry Christmas!
Ryan Lee is offline   Reply With Quote
Old 12-23-2004, 10:17 PM   #168
Shop Owner
nnick's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
I finally got yesterday and my power supply and sterted doing some charges
I charged 1 battery with CTX (conservative though 6 for 1500MAh - 5.5 for 500 - 5 for the rest). Then discharge the battery.
I got 2904 capacity and 59 IR Are they good? What numbers should be considered good?
I disharge another battery charged with Pulsar 2 at 5A ans got 3004Mah but no IR!! Why is that?
Something that is annoying is the sound of the fans when charge/disharge starts! Is it possible the fans to operate only when needed and not all the time. They make a lot of noice!!
Nick
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
nnick is offline   Reply With Quote
Old 12-23-2004, 11:38 PM   #169
lee82gx's Avatar
Pulsar 2 does not have feature to show IR??
your numbers look ok but i suspect your pack is quite used already? i can get 3300 from very new packs, about 40-50 IR.
you should tray them before charge/discharge also.
lee82gx is offline   Reply With Quote
Old 12-23-2004, 11:43 PM   #170
Shop Owner
nnick's Avatar
Oh no I disharge it with the CTX not Pulsar (Pulsar doesn't show IR anyway)
Yes it is quite used!
Any comment why I didn't get an IR number?
Nick
Nikolakopoulos Nick
RC RING
Enjoy RCing....
R/C Tech #82
IRT #123
Old 12-23-2004, 11:55 PM   #171
lee82gx's Avatar
i can only say, yes i have also experienced that before. got a --- for IR.
I'm not sure why or how, but i do get the IR after another discharge with the same pack.
Ryan:
To check the IR of a pack or cell, is it necessary to discharge it all the way from full charge? I sometimes discharge a half empty( or half full ) pack for 300-600mAh and i also get the IR reading. Is it as accurate or the same as when discharged from full charge?
Old 12-24-2004, 12:31 AM   #172
Default IR
If you discharge battery under hot(over 27degrees C) ambient, CM may stop discharging because inside's temperature is too hot.
In that case, IR cannot be shown.
I recommend to move CM to cooler place when you test(cycle) barrery packs.
When you want to get IR value, reference is very important.
Always discharge your packs from fully charged, with same charing and disch rate.
Ryan:
Old 12-24-2004, 12:39 AM   #173
Shop Owner
nnick's Avatar
Ok undestantable but the time that didn't get IR was when I had a fan blowing on the CTX!!
Let me outline what I did
1. I charged a battery
2. discharge battery (IR OK)
3. wait for 5 minutes for the other battery to bet charged
4. disharge second battery (IR not OK)
Nick
Nikolakopoulos Nick
RC RING
Enjoy RCing....
R/C Tech #82
IRT #123
Old 12-30-2004, 01:31 AM   #174
Ryan, is the delta peak setting in the Cell Master for a single cell or the whole pack, eg if I set it at 3mV, does it actually cutoff at 3mV or 18mv (for a 6 cell pack)?
If it is for a single cell, can I presume it will be affected by the no. of cells setting.
I find it very confusing as the instruction manual did not explain it clearly. As I used to set the delta peak in by CDC at 3mv per cell (18mv per pack), the dilema is I'm not sure if 3mv setting in the Cell Master will correctly charge my cell (if the setting is actually for the whole pack)
On the otherhand, I'm afraid I'll overcharge my battery if I assume the setting is for the whole pack (ie set it at 18mv) but turns out to be for a single cell (which the cutoff will then be 18mv x 6cell and I'll definitely overcharge by pack)
Please help to clarify.
Kitsiu is offline   Reply With Quote
Old 12-31-2004, 08:02 AM   #175
Raul Garcia's Avatar
Default where
WHo has much more chargers in stock, please.???
Schumacher USA, Speed Passion, Redline Hobbies.
ERA1FX Customs
2009 ROAR Region 1 10.5 Champ
2009 Vintage National 4wd Champ @ RCHR
Raul Garcia is offline   Reply With Quote
Old 12-31-2004, 06:53 PM   #176
Default Fan
Ryan...
I just got my batch of MM, CM and 20amp Power supply .. very nice gear!!!
I also got a batt cooling fan ... but the shop shipped me the fan with aligator clips and not the small clip for the left side of CM.. do u guys distribute them seperately as spares? Let me know i can get it off my local supplier in Australia..
My main question ... is do i put the fan on over the batts as it is charging?? Cos it'll keep the batts cool .. that's my thinking but i may be wrong .. so please let me know to use a fan on the batts while charging or not .. thank you =)
Happy New Year
hapiya is offline   Reply With Quote
Old 01-03-2005, 01:58 AM   #177
Hi
There are some stock of the Cell master , hurry to go purchase from the shop, the shop owner said just limited qty.
http://shop.go2best.com/product_info...roducts_id=328
good luck
Loman is offline   Reply With Quote
Old 01-04-2005, 07:06 PM   #178
Default Ultra exact deltapeak
3mV from CM means whole pack.
CM shows the voltage as 9.XXX, 3mV meand 0.003V
so you can check if CM can terminate at your set value(delta peak value).
Watch voltage display when arrow(near by voltage display) indicates downside. You'll be suprised how CM can terminate the charging exactly. Please try.
FYI, CDC charges the battery pack 55seconds then rest 5 sec.
If u see the battery voltage, it goes up and down, goes up and down, repeatedly, I can't tell this way is good or not, but you can imagine.
CDC's 3mV =CM's 18mV
Ryan
Old 01-04-2005, 07:13 PM   #179
Default Re: Fan
Receiver's connector also fit.
you can replace, but pls make sure the polarity.
I recommend the fan blows battery indirectly.
I mean place your battery under the fan stand if it blows upside.
I hope you could understand what I mean.
Because if fan blows battery pack directly, negative delta peak may be much delayed-it cause overcharging.
I saw the case it charges all day without nega.delta peak!
And set "Fan start temp" around 40~45 which works fine and not hurt your battery packs.
Ryan
Originally posted by hapiya
Ryan...
Happy New Year
Old 01-05-2005, 12:08 AM   #180
Shop Owner
nnick's Avatar
Is there a way to program when the charger's fans start to operate?
Also, are everyone's are so loud?
Nick
Nikolakopoulos Nick
RC RING
Enjoy RCing....
R/C Tech #82
IRT #123
Forum Jump
FS/FT: TEAM MUCH MORE Motor Master & Cell Master litespeed-dom R/C Items: For Sale/Trade 15 06-15-2006 07:44 PM
Team Orion Advantage w/ LiPo or Team Much More Cell master? RH Customs Electric On-Road 6 04-06-2006 05:05 PM
Team Much More Cell Master FRP R/C Items: For Sale/Trade 4 01-25-2006 02:04 PM
Team Much More Racing CTX Cell Master and CTX Motor Master letitroll R/C Items: For Sale/Trade 7 11-18-2005 10:25 AM
Team Orion Advantage or Team Much More Cell Master charger alana07 Electric On-Road 1 12-18-2004 04:37 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
