Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 01-09-2008, 07:57 AM   #1636
right just bruogh one of these charger the platnum vertion and i discharged aa set of east power 4200 cells and then chargerd them up again 0mah 5.5amps and 14mv and i only managed to to peak cut at 3600 does any one know what has happend with this charge and can any noe help me
thaks
alex-34 is offline   Reply With Quote
Old 01-09-2008, 08:10 AM   #1637
turboxrayt1fk05's Avatar
i tried setting my chargers @ 0mah with same results peaking lower , try setting
mah @ 4800 for 4200 packs and mv/per pack @ 06 and you will see your packs peaking around 9.42 ,, usually when you charge a pack for the first time (not new) it will peak sometimes lower or higher than its cap
XRAY 808
EXTECH .21 TMOD RACING
GRP .21 TUNED
NINJA 2053 PIPE
FUTABA 3PK
TRINITY MONSTER PLATINUM %30
SPONSOR:
UPGRADE/RCID
TMOD RACING
turboxrayt1fk05 is offline   Reply With Quote
Old 01-09-2008, 08:12 AM   #1638
Originally Posted by miccal View Post
I just got myself one of these chargers. The fans are quite noisy, is this normal?
sure is normal , they get loader when discharging
XRAY 808
GRP .21 TUNED
NINJA 2053 PIPE
FUTABA 3PK
SPONSOR:
UPGRADE/RCID
TMOD RACING
Old 01-09-2008, 08:51 AM   #1639
ok so i should set it to 4800mah but i 06 is to low as the cell master measures them as a hole pack no individual cells well im trying a different pack at the moment to see how that turns out. any other suggestions on what could be wrong or is it just the set up on the charger
thanks
Old 01-09-2008, 11:37 AM   #1640
right discharged a pack and then charged a pack and it only charged them to 2200mah on the same charge as before could it be the battery's or the charger
Old 01-09-2008, 12:33 PM   #1641
When the battery is done charging, hit the down key, and it will tell you the voltage it peaked at. Ideally it should peak at 9.1~9.4 volts. If the number is much lower, then the battery is out of balance. If this is the case, you can either use a cell balancer like the Novak Smart tray or Tekin Battery Doctor, or you can individually peak charge each cell with 6 mV peak detection. Each cell should peak at 1.5~1.51 volts.
edlan is offline   Reply With Quote
Old 01-09-2008, 12:44 PM   #1642
mikeygar's Avatar
subscribing
mikeygar is offline   Reply With Quote
Old 01-09-2008, 12:45 PM   #1643
Also, if your 4200 has been sitting at the shop discharged for a while, it will lose capacity, so it wouldn't be surprising if it only charged up to 3800. If it's a fresh pack, then it should be able to charge up to 4200~4400.
Old 01-09-2008, 01:43 PM   #1644
ok thanks i will try that and see what happens and the batterys were second hand hardly use so they should of be fairly charged. but thanks for the help and if that doesnt help then i will come back to you lot
Old 01-09-2008, 02:45 PM   #1645
right i have just charged them on my mates pro trak and it charge a set to 3800mah which is much better so could it be the charger
Old 01-09-2008, 02:59 PM   #1646
It's probably the battery. If your charger gets 3600 and another gets 3800, that's not much difference, so the battery either is pretty old, or has been allowed to self discharge to 0v.
Old 06-01-2008, 04:34 AM   #1647
mac853's Avatar
Could somebody tell me the charging profile(linear and step charge mode) to be most safety and also good performance if i wonder charge 5 cells ib4600 shv battery pack with my Cell Master.
And also for discharge, what about the profile if i wonder discharging my batteries with my CTXD2?
Best regards
Racing with less troublesome
mac853 is offline   Reply With Quote
Old 09-17-2008, 09:26 AM   #1648
Send a message via MSN to Fernando_PaNeTo
Tell me the charging profile to my brand news IB4200WC. I run a Silver Can class championship here on Brazil. I have the CTX- Andy Moore Edition with heatsink.
Tks,
Fernando - PaNeTo
Fernando_PaNeTo is offline   Reply With Quote
Old 03-11-2009, 10:29 AM   #1649
Arno's Avatar
Default Temp
Whats up guys I have a question, I just want to know if I can change the temp from celcius to fahrenheit on the cell master? Also I have 8AA 2300mah rechargeable batteries in my radio and I was wondering if I can charge them while in the battery tray of the radio? And if yes what setting should I charge them at.
Motonica-USA.com / Beltran Racing / Jr Propo / J-Go Paintz / Picco / JP Racing
Arno is offline   Reply With Quote
Old 03-11-2009, 03:14 PM   #1650
sosidge's Avatar
Well, I can't answer the Fahrenheit question, but for the AA's, I wouldn't go any higher than 1A linear with a normal delta as they tend to false peak (most AAs are not designed for a fast charge), and at that rate you should be able to charge them in the tray with no concerns.
www.sosidge.com - www.muchmoreracing.com
Forum Jump
FS/FT: TEAM MUCH MORE Motor Master & Cell Master litespeed-dom R/C Items: For Sale/Trade 15 06-15-2006 07:44 PM
Team Orion Advantage w/ LiPo or Team Much More Cell master? RH Customs Electric On-Road 6 04-06-2006 05:05 PM
Team Much More Cell Master FRP R/C Items: For Sale/Trade 4 01-25-2006 02:04 PM
Team Much More Racing CTX Cell Master and CTX Motor Master letitroll R/C Items: For Sale/Trade 7 11-18-2005 10:25 AM
Team Orion Advantage or Team Much More Cell Master charger alana07 Electric On-Road 1 12-18-2004 04:37 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
