good day!!! anyone tried opening their cell masters? i'm having problems with my buttons some of them doesnt seem to respond well i would need to press down harder for them to work...
i'm thinking about cleaning them do you guys have any suggestions??? anyone having the same problems???
it would be very much appreciated thanks!!!
i had same problem... i had to push and hold for the button to work, when my one was new.
MM sugessted i try come contact cleaner spray. they are in your electrical store.
if i did its just the four or so phillips screws on the outside, then you can half open it and you can see the buttons. or just spray from the outside.
Will this charger charge the new Peak 3200 LiPo's ok?
No, it has a 1amp max charging rate and only a 4.1v/cell cutoff voltage in Lithium mode.
For the Peak/Orion 3200, you should use a charger with at lease a 3A charging rate and 4.2V/cell cutoff.
By cutoff, I mean the highest voltage that the charger will allow the battery to achieve before reducing the charging rate to maintain that voltage.
im after a charging profile to use with my GP3300's, IB4200's and a couple of GP4300 packs i have. These are used in 2WD truck and 4WD buggies with 27t stock motors. anyone have any suggestions? Is there a website where i can download these etc?
Jaki, all your base are belong to us, Jaki
Here is what I use, Charge Capacity 0000mha (the reason behind this is if you enter 4200 or whatever your batteries are they may and often do peak higher than that, with the value set at 0 they will naturaly peak, this also helps with getting rid of faulse peaks), I charge at 6 amps but it depends on how much time you have, I set the Delta Peak at 14 the book recomends 10 I go up a little to stop faulse peaks, Delay timer is up to you. Also I set the long lockout at 15min. Hope this helps, also here is a link to nexus racings
question though, why do you set the delta peak so high? doesnt it hurt the cells? I was told to set it at 03 (hot day) or 05 (cooler day) for the 4200's. any higher and they will be damaged. can you comment on this?
i'm currently using my ctx to charge my TX lipo battery... its a VXR 800mah 3 cell pack for M8/Stylus...
current CTX setting is set at 3-cell, charge current .8A... can i bump the charge current to 1.0A without damaging the pack? problem with the .8A current is that it just freakingly takes too long to charge my pack...
also, i've recently encountered temp cutoff problems when charging the TX pack... problem is i don't use the temp probe to charge lipo... seems to be a problem not only with my CTX (i have 2)... same problem comes up even when i try my friend's CTX.
Thanks!
Team Petiks Racing - Sarap pumetiks!
