Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 02-22-2007, 03:08 PM   #1516
TheTurtleMan's Avatar
Trader Rating: 30 (100%+)
Just got done w/ my friends charger today. What do ya think?
team-much-more-cell-master-v1-green-much-more2.jpg   team-much-more-cell-master-v1-green-much-more.jpg
CLICK HERE FOR ALL YOUR RADIO AND MORE SKINZ!!!!
http://www.rctech.net/forum/showthread.php?t=184104
WWW.BUSTOUTBMX.COM
TheTurtleMan is offline   Reply With Quote
Old 02-22-2007, 03:19 PM   #1517
Swamp Rat's Avatar
Guys temp probe does not appear to work what is the best way to test them
Or where can i get a replacement ??
ORRCA QLD Committee
Secretary and Interclub Rep LCRCCC. inc.
Visit : www.lcrccc.org
Corally F1, RDX Phi's x 3 (one for sale), SMC 4000,5200 LIPOs, LRP SPX,NOVAK GTB SS, NOVAK GTB & 4.5 13.5,17.5, SP 10.5, LRP 10.5, 3xMini's for sale
Swamp Rat is offline   Reply With Quote
Old 02-22-2007, 03:30 PM   #1518
hierog's Avatar
Originally Posted by The8BitHero
Lol thanks, I was looking at them trying to justify the price jump. Not worth it IMHO. Each to their own.
-Jim
NO, that's not the only difference. Because it costs more, it charges the batteries better. At least that's what i told the wife!
hierog is offline   Reply With Quote
Old 02-22-2007, 03:30 PM   #1519
wallyedmonds's Avatar
the turtleman edition
coooooooooooool
/RB-5/LRP SPHERE/CRC-GEN-X/NOVAK 10.5/SMC/PARMA BODY'S/LOSI 8 2.0/GRP 21 BUGGY TUNED/OS/
FROM BRAMPTON ONT CANADA.
WWW.FASTCATS.CA
the red dot sucks, there i said it
wallyedmonds is offline   Reply With Quote
Old 02-26-2007, 07:02 PM   #1520
YR4Dude's Avatar
Default Muchmore Battery Cooler
I'm considering to buy the Muchmore battery heatsink/cooler but before I do, tell me, is it worth the cost and trouble to have one? Would I get a better charge with my battery's temp being controlled by the cooler? Please help.
Heres the link if you don't know what I'm talking about.
Got My 733 From Kamikaze. Great Car. Great Service
YR4Dude is offline   Reply With Quote
Old 02-27-2007, 12:48 AM   #1521
Stein Tumert's Avatar
Originally Posted by YR4Dude
I'm considering to buy the Muchmore battery heatsink/cooler but before I do, tell me, is it worth the cost and trouble to have one? Would I get a better charge with my battery's temp being controlled by the cooler? Please help. .
From my experience I would say it depends on the temperature you have in the room/air when you charge. If it it is hot, 30 degrees celcius or more it may be useful... If you have 20-25 degrees celcius I would say no need to cool the batteries when charging, you want to batteries to have a certain temparature at the end of the charge (~46 to 48 degrees celcius at end of charge, please note that temp will still increase a bit after charge is finished normally...)
Any other opinions?
Stein Tumert
Tamiya TRF, Futaba, SpeedPassion, Much More, Hudy, LRP
Stein Tumert is offline   Reply With Quote
Old 03-01-2007, 03:48 PM   #1522
Bryan D's Avatar
I have just got one of these chargers and I was wondering if any body has the settings for step charging IB 4200's??
Bryan D is offline   Reply With Quote
Old 03-01-2007, 05:31 PM   #1523
mike ivy's Avatar
Trader Rating: 21 (100%+)
Hello There Bryan D,
What you want to do is Use the Linear Charge Mode the Step charge I dont recommend you use them on IB 4200's hope this helps bro,
[-- eXpress motorsports --] [-- Irrgang Racing Service --] [-- BMI Racing --]
BMI DB12RR
1/12th scale fo' Life !!!
mike ivy is offline   Reply With Quote
Old 03-01-2007, 05:32 PM   #1524
i cant even get the step to work
i just charge at 6A thats it.
WWW.FASTCATS.CA
Old 03-12-2007, 08:18 PM   #1525
Big B's Avatar
Hey Guys
I recently bought the MMR CTX C Andy Moore edititon, along with the Battery heatsink II, I was wondering what is a good temp to have the heatsink kick in at, I know you shouldnt let them get too hot, and they take a better charge at certain heat. I mostly have IB 4200 cells, also some charging setups would help, I have been using the Peak Charge 1, setting the cells at 4600, 5a, and the delta peak at 03. And some info on what the Long Lockout means and how to use it would be great.
Xray 007 Euro, Much More Racing Andy Moore Edition Pit Equipment, Futaba 3pks 2.4ghz Fasst System, Novak, Team Brood Motors
Big B is offline   Reply With Quote
Old 03-12-2007, 10:26 PM   #1526
VooDooPH's Avatar
Trader Rating: 14 (100%+)
Send a message via Yahoo to VooDooPH
this is what i use for IB4200 WC:
5000
5, 5.5, or 6A charging
3mV cutoff
40deg fan on (note: i live in a hot, humid tropical country. you may not need to use the fan in your area)
50deg temp cutoff
30min long lockout
you set the long lockout to make sure the charger doesn't stop when you false peak (usually happens early during charging especially if you brought your cells down very low during discharge/equalizing). to engage the lockout, press the right key (>) long untill a key icon appears instead of the mV cutoff. engaging the long lockout will make the charger continue charging even if the pack voltage drops below what you set. Temp cutoff will still be active though. after the lockout duriation is done, you mV cutoff will then be active again.
Team Petiks Racing - Sarap pumetiks!
VooDooPH is offline   Reply With Quote
Old 03-12-2007, 11:03 PM   #1527
Big B's Avatar
Thanks, I think I had the long lockout too low and faulse peaked the first time using the CTXC, I also have the Andy Moore CTXD2 and I pulse discharge them to .9 which is what the batts say to do
Old 03-12-2007, 11:20 PM   #1528
VooDooPH's Avatar
would suggest equalizing with the 5A discharge mode down to .9V (after pulse discharge) before charging as well.
Old 03-13-2007, 01:41 PM   #1529
Big B's Avatar
Thanks I will try that next time
Old 03-13-2007, 04:26 PM   #1530
RC MARKET's Avatar
RC MARKET is offline   Reply With Quote
Forum Jump
FS/FT: TEAM MUCH MORE Motor Master & Cell Master litespeed-dom R/C Items: For Sale/Trade 15 06-15-2006 07:44 PM
Team Orion Advantage w/ LiPo or Team Much More Cell master? RH Customs Electric On-Road 6 04-06-2006 05:05 PM
Team Much More Cell Master FRP R/C Items: For Sale/Trade 4 01-25-2006 02:04 PM
Team Much More Racing CTX Cell Master and CTX Motor Master letitroll R/C Items: For Sale/Trade 7 11-18-2005 10:25 AM
Team Orion Advantage or Team Much More Cell Master charger alana07 Electric On-Road 1 12-18-2004 04:37 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
