Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 12-16-2004, 09:42 AM   #136
Send a message via AIM to Roberto Falcon
how much does that charger go for?
CorallyUSA / Superior Hobbies / RC3 Grafix
Roberto Falcon is offline   Reply With Quote
Old 12-16-2004, 11:48 AM   #137
Shop Owner
nnick's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
At the Hong Kong's on-line store around 110 USD
Nick
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
nnick is online now   Reply With Quote
Old 12-16-2004, 11:50 AM   #138
Cole Trickle's Avatar
Nick
Gotta link? Thanks.
Tamiya DF-03 w. slipper clutch, 18x1.
Schumacher Mi2 - HPI Pro2. Both racing indoor carpet, stock class.
Cole Trickle is offline   Reply With Quote
Old 12-16-2004, 11:52 AM   #139
JDXray's Avatar
Send a message via AIM to JDXray
Nick
wow, where!?! i was told it was like 230+ in HK
JDXray is offline   Reply With Quote
Old 12-16-2004, 12:35 PM   #140
TFR
TFR's Avatar
Nick
$140 you mean? Most HK shops sold out their first batch. I got mine from RC Model.
TFR is offline   Reply With Quote
Old 12-16-2004, 12:41 PM   #141
Shop Owner
nnick's Avatar
Ooups, you are right it's 140USD!! I bought mine for RCModels too.
110USD is the power supply which I also bought it from HK!
Try also www.hobbymania.com.hk
Sorry
Nick
Nikolakopoulos Nick
RC RING
Enjoy RCing....
R/C Tech #82
IRT #123
Old 12-16-2004, 05:32 PM   #142
Default Re: Re: Cut off temperature
For race, I recommend to set 48~52degree C for GP3300 under 18-25 degrees Celcious ambient.
That seems a bit overcharging, but always show much punch during race.
Atsushi, Karn and Jilles also set 52degree for GP3300 in Thai(Reedy race of Asia).
Temp sensor comes with Cell master is very accurate than any other ones because it is based on the cell' surface temp.
If you check each cell's temperature with Infrared thermometer when charging terminating is closing, You'll see each temperature is not much different.
The difference of temp between each cell is only 0.5~2degree always(if your battery pack has good condition).
I can say that the difference of temperature 0.5~2 degrees C is "nothing". You don't have to be serious about that.
Battery maker always suggest safe charging way(1C charge 45C temp cut etc..), but racers want "result".
In cold ambient, charging is always terminated by Peak cut.
But in hot condition, battery pack gets hot easily, so you should make sure temp sensor always meets on cell's surface. Then you can expect charge terminating by Peak cut or Temp cut (which one reach first).
Ryan
Originally posted by Cole Trickle
Hello Ryan
I really appreciate to see a company reprensative talking about charging here - there so many myths and ghost, when it's about charging.
Now, I'm curious about where the above temperatures came from?
Do you have the same numbers, when ambient temperature is around 18-25 degrees celsius?
Also, what about GP cells? I tend to say most people are using GP's...
Thanks.
Ryan Lee is offline   Reply With Quote
Old 12-16-2004, 05:46 PM   #143
Default Cut off way
I recommend peak cut always, but under hot condition, capacity limits and temp limit should be set for safety.
In general Ryan, you recommend usign the temp cut off instead of peak detect right?
Why is that?
Nick
Old 12-16-2004, 07:28 PM   #144
Hi Ryan
Would you pls to confirm the next batch shippment date to Hong Kong.
Kind Regards
Anthony
Go2best
G2B Anthony is offline   Reply With Quote
Old 12-16-2004, 08:00 PM   #145
Default Next batch
Next batch will be started in the middle of Jan.
For exact shipping date, pls contact Mr.Samuel Chiu at International Hobby.
Thanks,
Originally posted by G2B Anthony
Hi Ryan
Kind Regards
Anthony
Go2best
Old 12-16-2004, 08:03 PM   #146
OK , Thanks for your info.
Anthony
Go2best
Old 12-16-2004, 11:58 PM   #147
These guys got a crystal clear definition on warranty: They directly claim, that there aint such thing. Once the box is opened, you have to rely on the manufacturer, if any problems occur. But at least, they are honest about it. Take it or leave it.
Old 12-17-2004, 12:57 PM   #148
mushu's Avatar
I've got a question about the charger...
It's only capable of discharging at 10 amps and most of the battery threads will tell you that discharging below 20amps isn't any good. I've always been suspicious about why you have to discharge at 20amps or more and I'm curious if Hara and company are just using the 10 amps or if they have another discharger they use.
I love the size / features of the Much More charger and power supply and would seriously consider them if only the 20amp or more myth could be debunked. I don't want to buy a seperate discharger because I could just pick that and a couple of Novak chargers for less.
mushu is offline   Reply With Quote
Old 12-17-2004, 05:45 PM   #149
Default Discharging
Many people want to discharge their battery at high rate over 20A, what do they want to see? AVERAGE VOLT.
But I don't think higher average V always means "Punch".
Each cell has different discharging characteristics, so you can't say "same Average V cells mean same charateristics"
If you discharge one battery pack with different dishcharging amp,
you'll see capacity is almost same but average volt changing.
That's why many people want buying high amp dischager.
According to our test, Internel resistance is muchmore reliable.
Lower IR shows always much punch.
Cell master shows very accurate IR.
Low IR means "the voltage recovering speed is very fast"
If two cell's IR are same, that means both has same volt recovering speed.
When I cycle my packs, now I see only capacity and IR.
We doubled the original IR value for showing much differences between each cell.
also I don't have to kill my battery packs with high amp discharging for just seeing "data"
CM's 10A dishcharging never kill your battery, show right capacity and how much punch your pack has with "IR".
If we make CM as 30A discharger, the size will be triple!
Ryan
Old 12-17-2004, 05:51 PM   #150
Default Re: Discharging
Ryan
Forum Jump
FS/FT: TEAM MUCH MORE Motor Master & Cell Master litespeed-dom R/C Items: For Sale/Trade 15 06-15-2006 07:44 PM
Team Orion Advantage w/ LiPo or Team Much More Cell master? RH Customs Electric On-Road 6 04-06-2006 05:05 PM
Team Much More Cell Master FRP R/C Items: For Sale/Trade 4 01-25-2006 02:04 PM
Team Much More Racing CTX Cell Master and CTX Motor Master letitroll R/C Items: For Sale/Trade 7 11-18-2005 10:25 AM
Team Orion Advantage or Team Much More Cell Master charger alana07 Electric On-Road 1 12-18-2004 04:37 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
