Old 11-20-2004, 02:59 PM   #1
Default brake cleaner
I have been using brake cleaner to clean motors, brushes, nitro engines. Someone on the track told me that my chorinated brake cleaner is corrosive to plastic, and hence not good for cleaning engine and motor. My question is whether nonchorinated brake cleaner is good for cleaning motor and engine? Is there any specific chemical in the brake cleaner that I need to watch out for?
raceblast is offline   Reply With Quote
Old 11-20-2004, 04:36 PM   #2
hpipro321's Avatar
Thumbs down
i have no clue, but why in the first place are you using brake cleaner. If your gonna clean something like that just use simple motor spray that you can get at any local hobbyshop(electric). Or use nitro or buggy blast for nitro. Or even simple green will work.
hpipro321
d[-.-]b d[-.-]b
d[-.-]b d[-.-]b can you feel the bass? d[-.-]b d[-.-]b
d[-.-]b d[-.-]b
hpipro321 is offline   Reply With Quote
Old 11-20-2004, 04:49 PM   #3
Blakesrc's Avatar
Send a message via AIM to Blakesrc
Hpipro321,
I know some people that use it because it is only 2 dollars a can instead of 5 for the stuff we get at the hobby shop.
Raceblast,
Some brands are ok to use on some items. The brad CRC is what i see people use around my local track. It does seem to be stronger than the hobby shop stuff, i have seen it remove/cause chipping of the anodizing on motor cans and also discolor and kind of melt some chassis/plastic so if you choose to keep using it, be careful.
Blake
Blakesrc is offline   Reply With Quote
Old 11-20-2004, 04:58 PM   #4
motor spray is 2 to 3 times more expensive than brake cleaner. Most racers use brake cleaner to clean motors, brushes, bearings and nitro cars. Since the next race will be 3 weeks away, I just try to see whether I can get an answer here sooner.
Old 11-20-2004, 05:17 PM   #5
Speedie's Avatar
Napa sells "brake and electric motor cleaner". Thats what I use. Motor spray is just a non corossive brake cleaner as motor spray doesnt need to try and remove brake dust.
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Old 11-20-2004, 05:25 PM   #6
burbs's Avatar
Send a message via AIM to burbs Send a message via Yahoo to burbs
i use a brake cleaner called next dimension.. it is used by alot of motor builders.. i buy it at a home improvement store called menards.. it is 1.59 a can.. it is not corrosive or bad smeeling.. it dries faster then any motor spay ive ever used.. and it works... i clean my lexan bodies with it all the time and it doesnt do any damage to them....
some smaller companies that sell motor spray use this type of cleaner.. they just put there own lables on it...
burbs is offline   Reply With Quote
Old 11-20-2004, 05:27 PM   #7
burbs,
have you heard the menards joke?
You can kick me in target, you can kick me in walmart but you cant kick me in me-nards.
mtc3od is offline   Reply With Quote
Old 11-20-2004, 05:30 PM   #8
burbs's Avatar
Old 11-20-2004, 06:43 PM   #9
Registered User
I use the CRC non chlorinated. It is very good for all metal parts, very cheap way to rinse out bearings. I've noticed however it will eat the epoxy coating the windings of some motors, take the finish off cans, and melt some plastics.
I don't use it on anything other than full metal, unfinished parts. I used it to rinse my Monster Stock and P2K motors and it removed much of the gold coating from the end bells, it removed all of the paint from my Fantom Monster.
If you can find the stuff mentioned for electric motors and brake cleaning, use that, it will be less caustic.
Desolas is offline   Reply With Quote
Old 11-21-2004, 03:43 AM   #10
You want to get hold of some "Electrical contact cleaner". It is not as harsh as brake cleaner, and to my knowledge is exactly the same as the stuff under RC brand names. Jonathan.
jonny69 is offline   Reply With Quote
Motor Cleaner /Brake cleaner PRO 2 RACER Australian Racing 9 10-10-2006 03:44 AM
Can brake cleaner be used as motor spray? revzalot Electric On-Road 44 01-20-2006 05:00 PM
Brake dust cleaner or Nitro Cleaner? TurboLancer Electric Off-Road 10 12-04-2004 04:47 AM
ECS- Auto brake/Neutral Brake/Drag brake RC12L3a Electric On-Road 6 11-21-2004 09:10 PM
drag brake, brake and reverse imjonah Rookie Zone 3 07-24-2004 06:20 PM
