Old 11-20-2004, 03:36 AM   #1
Default Traction Compounds Questions
Hi to all.
Ive seen in these forums that you are using a traction compound called Wintergreen. I know that the base of wintergreen is methyl salycitate. I think that salycilate must be mixed with other "ingredients". Can anyone tell me what are these components and what are the proportion of these I must use?
Once you have the wintergreen "mixed" and ready to use...How do you aplly it? (drying times, how many time before the start, ect...).
Thank you to all.
DiegoVVRacing is offline   Reply With Quote
Old 11-20-2004, 04:35 AM   #2
raving-monkey's Avatar
Send a message via MSN to raving-monkey
i think wintergreen was used in additives (traction compounds as you call them) that had a smell to them..which aren't allowed at most races.
i use lrp additive (which is odorless and doesn't contain wintergreen) and on the tub it says for rubbers put it on 30 mins before your heat and wipe off 10 mins before...for foams put it on 50 mins before and dont wipe it off.
raving-monkey is offline   Reply With Quote
Old 11-20-2004, 05:15 AM   #3
fatdoggy's Avatar
R/C Tech Charter Subscriber
Paragon ground effects and corally's tc3 compound use wintergreen. How long you have it on depends on what kind of track you run on. On a high traction track(foam tyres) you may only put it on for 5-10 minutes where as on a low traction track you may leave it on for 20 minutes. If you leave traction compound on for too long it will slow the car down.
fatdoggy is offline   Reply With Quote
Old 11-23-2004, 01:14 AM   #4
POOKYT's Avatar
Many many moons ago, like in the 80's, we used to mix oil of wintergreen with WD-40. 1 to 1 and we had good results. The paragon does work better and you don't have to mix anything. LOL Smell on the other hand is debatable.
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Traction Compounds srs64 Electric On-Road 1 09-13-2007 03:25 PM
Traction Compounds : Health Risks : what can we do about this? Martin Crisp Electric On-Road 785 06-11-2007 02:49 PM
Tyre Traction compounds etc Got Xray? Australian Racing 29 08-13-2006 05:24 AM
what ingredients go into traction compounds ark Electric On-Road 0 05-05-2004 06:49 AM
Traction Compounds for Parking Lots Jared Kirkwood Electric On-Road 16 06-05-2002 08:06 PM
SEO by vBSEO 3.5.0
