Old 09-27-2011, 04:34 PM   #1
RahjahDat's Avatar
Trader Rating: 101 (98%+)
Default throttle and brake curves
Hey guys! Im a newbie to electric racing and i wanted to learn some stuff on throttle and brake curves. Here is the thing, i am programming my mamba monster system via castle link and i want to know if anyone knows where i can find info on throttle and brake curves. any advice is worth alot to me
RahjahDat is offline   Reply With Quote
Old 09-27-2011, 07:26 PM   #2
TryHard's Avatar
It's pretty simple really.
Normally, the relationship between the throttle and brake will be linear. I.e. When you move the stick/trigger you get the exact same response on the ESC.
Move the trigger 5%, the esc will respond with 5%.
Now for some situations, the initial response can be too much for the grip level, causing the wheels to spin up (under throttle) or lock up (under brake). So you can use the curves to smooth out the response. Using a little bit of negative curve (the curve starts off flatter before getting steeper), means that for 5% throttle, you may only get 2% on the ESC.
It can really help to smooth the response of the car out, and can be a useful tool to help maintain traction around the centre of the throttle stick.
Personally, I tend to prefer to tune this setting on the transmitter (if it's available) rather than the ESC, as it allows more rapid adjustment on the rostrum. If you haven't got that option on the tranny, than by all means use it on the ESC.
Also, don't rely on it too much... training your throttle finger is part of the skill for going fast
Which 6s for Buggy and Tekin 1400kv? Muggydude Electric Off-Road 30 02-15-2011 08:51 AM
Castle Link / Mamba Max / Throttle Brake Curves / Electric Off-Road rearviewmirror Electric Off-Road 11 02-09-2011 09:24 AM
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 10:26 AM
Need Help w/ Li-Po Cells, Discharge Rate? And My BL Motor... J Smith Electric On-Road 13 07-03-2005 04:00 AM
SEO by vBSEO 3.5.0
