Old 01-31-2012, 06:44 PM   #1381
HarryLeach's Avatar
Send a message via AIM to HarryLeach
Originally Posted by haywood View Post
One piece mount part #?
30 2048-O
Privateer racing lots of stuff.
Remember kids, racing isn't fair!
HarryLeach is offline   Reply With Quote
Old 02-01-2012, 01:50 AM   #1382
shio's Avatar
Trader Rating: 20 (100%+)
Originally Posted by HarryLeach View Post
30 2048-O
What is the difference between 302048-O and 302045-O
shio is offline   Reply With Quote
Old 02-01-2012, 05:37 AM   #1383
Skiddins's Avatar
302045 is for the front of the front suspension and the rear of the rear suspension.
I believe 302048 is the optional one piece version for the front of the rear suspension instead of the kit two piece.
http://www.rcdisco.com/part-info.php?partNo=XR302048-O
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 02-01-2012, 07:12 AM   #1384
HarryLeach's Avatar
30 2045-O are the Forward Front suspension mounting block and the Rearward Rear suspension mounting block
30 2047-O is the one piece Front Rearward mount [originally a 2 piece on the mount on the T3, standard on the T3'11 and T3'12]
30-2048-O is the optional one piece Forward Rear mount
Old 02-02-2012, 05:21 AM   #1385
Send a message via AIM to Matt W
Default Front rollbar mounts
Hi,
Ive noticed there is a fair amount of diagonal movement in the front rollbar mounts, i tightened the grub screw so that the rollbar drops freely but there still seems alot of movement. Its a brand new kit so the mounts can't be worn. I didnt know if perhaps i was just unlucky and got a bad set or perhaps i need to buy the rollbar collars?
Any ideas.....?
Matt W is offline   Reply With Quote
Old 02-02-2012, 08:45 AM   #1386
Skiddins's Avatar
Originally Posted by Matt W View Post
Hi,
Any ideas.....?
Do you mean the side to side movement at the actual mounts on the bulkheads?
Mine have very little play at that point.
Remember to disconnect the ends of the bars from the 'ball ends' and links to check that they are just loose enough to drop under their own weight.
Skiddins
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 02-02-2012, 09:39 AM   #1387
ByteStream's Avatar
Hi,
Any ideas.....?
The grub scews are meant to eliminate the up/down play, while still alowing them to drop freely.
However, there is a little play in them side to side.
If you feel it is too much for you, you can get the xray collars ...
An inexpensive option is something like this .. (double check the size as you'll probably want to size them for the thickest swaybar you would use .. maybe 1.6mm).
http://www3.towerhobbies.com/cgi-bin...&I=LXD832&P=SM
RCAmerica | Xray | Hudy | KO Propo | Hobbywing HWNA | R1Wurks | BSR Tires
5280 Raceway - www.5280raceway.com
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
ByteStream is offline   Reply With Quote
Old 02-02-2012, 10:44 PM   #1388
rc-goods's Avatar
Default Zero Force X Ray T3 Bearing Set (12 pcs)
www.rcgoods.com
rc-goods is offline   Reply With Quote
Old 02-02-2012, 10:51 PM   #1389
jake95's Avatar
Trader Rating: 27 (100%+)
Hi,
Any ideas.....?
i have modified serpent s411 sway bar holders to fit the xray it is allot more free and less slopy
XRAY✯NOSRAM✯SANWA
jake95 is offline   Reply With Quote
Old 02-03-2012, 12:01 AM   #1390
Attachment 872558
www.rcgoods.com
Hardly a bearing set? I could swear mine has more that 12 bearings
Mb3195 is offline   Reply With Quote
Old 02-03-2012, 01:05 AM   #1391
silvalis's Avatar
Trader Rating: 29 (100%+)
I count 20
silvalis is offline   Reply With Quote
Old 02-03-2012, 04:44 AM   #1392
Ariel Reds's Avatar
will have my first ever t3 car platform! any building tips?
Ariel Reds is offline   Reply With Quote
Old 02-03-2012, 05:06 AM   #1393
psr
psr's Avatar
follow the instructions
psr is offline   Reply With Quote
Old 02-03-2012, 06:27 AM   #1394
Meradin's Avatar
Trader Rating: 19 (100%+)
While this hint seems a little sarcastic and crass (sorry if I misinterpreted your intentions) it is very sound. I built up my T3 and being new to the on-road scene copied the build instructions as close as possible and they are simply the best out there. After the build I went through the car and setup it up from a setup sheet I got from a pro driver off the Xray site. Couldn't get the traction I needed and the car was difficult to drive.
I went back to the kit setup and the car came alive! It was well balanced and drove awesome. While it was short and a bit dismissive, following the instructions in this case is excellent advise!
Better than Randy, Adam said so!
Second thought...I don't trust Adams, they make up everything!
"Leave it to Steever", custom paint masks, decals, and paint.
Meradin is offline   Reply With Quote
Old 02-03-2012, 07:35 AM   #1395
ByteStream's Avatar
Put a setscrew in the un-used hole in the rear uprights. This will prevent the other screw from pulling out during a hard impact.
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 12:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 05:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-16-2011 11:58 PM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 03:11 PM
