Old 01-26-2012, 07:00 AM   #1336
UrabusDenis's Avatar
Originally Posted by haywood View Post
Would I notice anything in handling going from 50's to 52's?
With 52mm the car is easier to drive but it understeers more than with 50mm. The car is more agressive with 50 mm.
JQRacing - eu.jqracing.com
Blue Bird - www.blue-bird-model.com
RW mods - www.rw-mods.com
Boca Bearings - www.bocabearings.com
UrabusDenis is offline   Reply With Quote
Old 01-26-2012, 07:10 AM   #1337
M-Technic's Avatar
Trader Rating: 15 (100%+)
Originally Posted by theatriks View Post
Hey guys newbie question here ....whats the difference when u adjust the rear toe-in at the legs with the shims or if u buy the rear aluminum uprites with the integrated toe in?
If you run a lot of rear toe like 4 degrees or so and and just keep adding spacers inboard it puts the hinge pin at a great angle and could bind. I run the 1 degree rear hubs most of the time as I race on low traction.
Also, when you run toe on the hubs, that toe is constant as the suspension compresses. With inboard toe, it continues to toe in more as the suspension is compressed. Having outboard toe versus inboard can help free up in the rear end in the corners.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 01-26-2012, 07:16 AM   #1338
annonymous's Avatar
Trader Rating: 21 (100%+)
Originally Posted by CarbonJoe View Post
PRS pinions, and either Xray or the Xray specific RW spurs. Yes, the '12 prefers the offset spurs.
Thanks!
I drive faster on the bench...
Orion - Futaba - Savox - RCAmerica
annonymous is offline   Reply With Quote
Old 01-26-2012, 09:01 AM   #1339
Originally Posted by Skiddins View Post
Then you have something set up seriously wrong, either with your ESC or in the car.
I run my belt in the central (kit) position
Hi Damian, what setting do you run on the front belt as i can never decide if mine is too loose.
stuartb is offline   Reply With Quote
Old 01-26-2012, 09:26 AM   #1340
I just recently added 1* on the outboard hubs, while running same amount of total toe as I previously did by just adding shims. It definately did free up the rear end, especialy in tight S curve sections of the track.
NPETRO is offline   Reply With Quote
Old 01-26-2012, 10:33 AM   #1341
Meradin's Avatar
Trader Rating: 19 (100%+)
How would adding the 1 degree hubs effect the handling in long high speed sweeper turns?
Our track is pretty tight and turny and I need to get some more rear side-to-side traction to hold more speed but I don't want to sacrifice turning speed either.
Better than Randy, Adam said so!
Second thought...I don't trust Adams, they make up everything!
"Leave it to Steever", custom paint masks, decals, and paint.
Meradin is offline   Reply With Quote
Old 01-26-2012, 12:13 PM   #1342
Skiddins's Avatar
One notch looser than kit
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 01-26-2012, 03:55 PM   #1343
Trader Rating: 29 (97%+)
Hi, I have a brandnew t3 2012 , and am currenctly running a s411, read this thread and everyone says the t3 is better, i am really liking the s411, and do not want to open the t3 box as it will be worth more sealed, my question is does the t3 2012 feel easier to drive then say your other car you may have owned in the past and where can I view setup sheets for high grip carpet thanks
zaraz is offline   Reply With Quote
Old 01-26-2012, 04:10 PM   #1344
Bigz84's Avatar
I feel the '12 is by far the easiest to drive. I had an '11, but I couldn't get the right feel. I think the stock set up is the best to use. The only thing I changed was going to a 1.5 front bar. I like a car w/ a little push. I have driven a fellow racer s411, and it felt very fast, but a tad loose in the rear for me. He didn't cut the top deck yet to plant the rear, but i'm sure once he did, the rear became planted. JMO
Radiopost : EA Motorsports : Orca : Reflex Racing/RSD : Wild Turbo Fans : Franchise Racing Products : RCAmerica : Hudy : Xray : Diggity Designs:
Bigz84 is offline   Reply With Quote
Old 01-26-2012, 07:29 PM   #1345
haywood's Avatar
Trader Rating: 48 (100%+)
Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 01-27-2012, 02:59 AM   #1346
Default 50mm rear shaft
Would you recommend using 52 in front and 50 in the rear? Would that create more understeer with more traction going to the rear?
emerge is offline   Reply With Quote
Old 01-27-2012, 03:46 AM   #1347
It's better in my opinion to have 52mm in the rear and 50mm in front, since you have the stability at the rear and agression in front You can combine it and drivers use different combinations. In general 52mm are better for large fast tracks and 50 mm are better for smaller, more technical asphalt tracks.
Old 01-28-2012, 03:47 AM   #1348
Have anyone try the modification rear suspension like Hagberg did on DHI cup? How does it feel? Will it works on asphalt? Thanks
mizah is offline   Reply With Quote
Old 01-28-2012, 06:29 AM   #1349
theatriks's Avatar
What do u guys mean by freeing up the rear end ?
theatriks is offline   Reply With Quote
Old 01-28-2012, 07:04 AM   #1350
I race at a fairly technical track, the rear end of my t3 was too planted causing the chassis to not properly rotate through the turns (s turn). When I went to 1* outboards (along with a longer rear link) the car really came alive in that particular section. I made both changes (outboard and longer rear link) at the same time. I feel that the longer link, combined with the outboard 1*, made more of a difference than if I would of just changed the outboards alone.
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 12:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 05:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-16-2011 11:58 PM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 03:11 PM
