Old 01-25-2012, 09:00 AM   #1321
pcar951's Avatar
Trader Rating: 19 (100%+)
Originally Posted by rdlkgliders View Post
Has anyone driven both the t3 2012 and the serpent s411 le? I need a unbiasd comparison. I am down to those 2 as I shop for a new car to replace my xray t2 I have been racing for a couple years.
If you're interested, right now I'm running the S411 and the T3/2012 back to back. I've found setups that I like for both cars, lap times are very similar although each car gets it done differently.
For me, the S411 has a very planted feel with tons of steering, likes to be driven hard into and out of corners. The T3/2012 has more method in the drive, feels less raw and is more forgiving. Right now my T3 is 1 - 2 tenths faster for me on average. Quality is similar with a slight edge to Xray.
Hope this helps.
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy | Reds Racing
pcar951 is offline   Reply With Quote
Old 01-25-2012, 09:31 AM   #1322
rdlkgliders's Avatar
Trader Rating: 21 (96%+)
Thanks,
All info helps. How is the ease of setup and durability factors in comparison to one another?
Serpent, KO Propo, Viper, Savox, ProTek
Team Waldorf Racing
Your not lapping me, you just caught up to me again!!!
rdlkgliders is offline   Reply With Quote
Old 01-25-2012, 10:20 AM   #1323
pcar951's Avatar
Thanks,
Both cars are very durable and easy to setup, the Xray "holds" it's settings (droop, camber, toe, ect.) a little better than the Serpent run after run. The steering mechanism is better on the Xray out of the box.
Jim Chapman
Old 01-25-2012, 10:55 AM   #1324
Great info.
Team Waldorf Racing
Old 01-25-2012, 02:05 PM   #1325
haywood's Avatar
Trader Rating: 48 (100%+)
Default Ecs
Would I notice anything in handling going from 50's to 52's?
Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 01-25-2012, 02:52 PM   #1326
Skiddins's Avatar
Originally Posted by maxg123456 View Post
Maritime Raceway UK (4th place on the grid in the video.)
http://www.youtube.com/watch?v=vP9leQdWcJk
Ahh, Maritime.
I've done Carpetwars a few times.
I always seem to struggle on carpet.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 01-25-2012, 04:29 PM   #1327
theatriks's Avatar
Hey guys newbie question here ....whats the difference when u adjust the rear toe-in at the legs with the shims or if u buy the rear aluminum uprites with the integrated toe in?
theatriks is offline   Reply With Quote
Old 01-25-2012, 04:37 PM   #1328
what cassis protector are you guys running outdoors? (palstic protective film)
Team Waldorf Racing
Old 01-25-2012, 05:11 PM   #1329
haywood's Avatar
If you run a lot of rear toe like 4 degrees or so and and just keep adding spacers inboard it puts the hinge pin at a great angle and could bind. I run the 1 degree rear hubs most of the time as I race on low traction.
Old 01-25-2012, 07:03 PM   #1330
annonymous's Avatar
Trader Rating: 21 (100%+)
what brand of pinion and spur are you guys using? been a while sense i ran 64p gears, and i also understand the 2012 uses a narrow/offset gear?
quiet = better in my book
I drive faster on the bench...
Orion - Futaba - Savox - RCAmerica
annonymous is offline   Reply With Quote
Old 01-26-2012, 04:05 AM   #1331
Regional Moderator
CarbonJoe's Avatar
PRS pinions, and either Xray or the Xray specific RW spurs. Yes, the '12 prefers the offset spurs.
*** The Gate - Celebrating 7 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 01-26-2012, 04:28 AM   #1332
Default Tweak
Wondering if anyone has experienced this and fixed it.
I've picked up a tweak at the rear somewhere where I have 2 dEgrees toe in on left and 3 degree on the right. The chassis is brand new as I was using the zeppin chassis when I first picked up the tweak. ThE blocks arms etc are all straight with all plastics replaced just in case.
Any ideas where to look as at the moment I've had to add shims to left side to correct.
emerge is offline   Reply With Quote
Old 01-26-2012, 04:43 AM   #1333
NR
NR's Avatar
Trader Rating: 52 (100%+)
Can anyone show / send me a link for the kit stop sheet for the 12? I have lost it
Cheers
Nathan
NR is offline   Reply With Quote
Old 01-26-2012, 04:49 AM   #1334
Regional Moderator
CarbonJoe's Avatar
Cheers
Nathan
I assume you mean the blank setup sheet.
http://www.teamxray.com/teamxray/sho...p?file_id=8124
Old 01-26-2012, 05:41 AM   #1335
jake95's Avatar
Trader Rating: 27 (100%+)
I have this problem sometimes I normally just losen the rear blocks abit and there's normally alittle bit of play in it. So I normally just hold to the side with more toe and tighten it and it's fixed you normally get 2.5degree each side with kit setup so it would only need alittle moving.
Jake
XRAY✯NOSRAM✯SANWA
jake95 is offline   Reply With Quote
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 12:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 05:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-16-2011 11:58 PM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 03:11 PM
