Old 01-17-2012, 03:20 PM   #1276
Trader Rating: 88 (100%+)
Default Springs
Has anyone had any experience with the atomic spring sets for this car? Are the any good or are they junk?
Shane W.
Everything for Sale - out of hobby
tcdrvr2 is offline   Reply With Quote
Old 01-17-2012, 03:38 PM   #1277
Originally Posted by M-Technic View Post
With a gear diff the belt needs to be pretty tight. The center position should be perfect for a new belt.
I would have to disagree. The first time out with this car it handled like a turd in this position and moving it 2 back (looser) put me in 1st place the second time I driven the car at a big indoor event. If you're comparing the T2 009 for example, the middle position is much looser on that car.
maxg123456 is offline   Reply With Quote
Old 01-17-2012, 03:40 PM   #1278
Originally Posted by Skiddins View Post
If you can get away with more aggressive steering, try using front arm sweep with front wheel toe out, it's too much for sweeping tracks. but better on tracks with a few tight 180deg corners etc.
thanks for the advice! - I'd like to try that.
Old 01-18-2012, 01:05 AM   #1279
kakaroctt's Avatar
Originally Posted by bucketboy View Post
2 snapped belts, hot motor, noisey, think you have built something wrong fella
I run slack belts, with 64 dp gears and the car is all but silent.
Bb
nope...at first it was too tight on center position..loosen 2 point backward then it was awesome with no noisy noise and temp keep at +- 60c...then rear belt keep snappin..trying to tighten front belt like our buddy locked advised...now its fantastic...(even with my hard hand)
thanks to all...
LEGGERE LE ISTRUZIONI PRIMA DELL' USO !
kakaroctt is offline   Reply With Quote
Old 01-18-2012, 03:34 AM   #1280
I run with sweep (0.5mm difference between front and rear) and also 3.5mm spacers on bump steer - improves steering no end - makes the car much more precise!!
Mb3195 is offline   Reply With Quote
Old 01-18-2012, 08:46 AM   #1281
M-Technic's Avatar
Trader Rating: 15 (100%+)
In mod, if you run 2 spots looser in the rear, you will strip/snap rear belts frequently.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 01-19-2012, 12:07 AM   #1282
Zainy's Avatar
Exclamation T3'12 Rear Belt
Hi ,
I've snap my rear belt twice... finally change to YOKOMO BD5 rear belt. Result more long lasting , still not snap yet..playing 13.5 boosted...
Zainy is offline   Reply With Quote
Old 01-19-2012, 12:09 AM   #1283
Zainy's Avatar
Hi , actually Xray spring is Ok already... try use C2.6 in the front & Rear...
Old 01-20-2012, 05:18 AM   #1284
Default Setup help
Not sure what is happening but starting with the basic asphalt I'm getting a lot of neutral and on power oversteer. I have tried playing with the springs and shock positions to no success. Starting to wonder if I did something wrong with the build. My first X-ray but followed instructions quite close.
Any ideas what to possibly look for or try to improve be wise it's very nervous and undriveable especially at change of direction in technical areas.
Ps medium to low traction track.
emerge is offline   Reply With Quote
Old 01-20-2012, 05:23 AM   #1285
jake95's Avatar
Trader Rating: 27 (100%+)
try longer rear link
XRAY✯NOSRAM✯SANWA
jake95 is offline   Reply With Quote
Old 01-20-2012, 07:31 AM   #1286
gonzo416's Avatar
Trader Rating: 39 (98%+)
what's the best servo that fits. would a full size servo be better for weight? I read that guys were using certain servos to help balance the car.
gonzo416 is offline   Reply With Quote
Old 01-20-2012, 08:17 AM   #1287
ByteStream's Avatar
Best is often a matter of opinion and brand preference .. I use a full size Savox 1257TG for more weight on the radio side. I figure if I need more weight for balance I'll put that wegiht into a faster servo ~ 0.07 @ 6V. I still have plenty of room and still need to add more weight for balance. The Lipo's these days are getting heavier as their capacity increases.
RCAmerica | Xray | Hudy | KO Propo | Hobbywing HWNA | R1Wurks | BSR Tires
5280 Raceway - www.5280raceway.com
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
ByteStream is offline   Reply With Quote
Old 01-20-2012, 08:22 AM   #1288
M-Technic's Avatar
I like using a low profile servo for the electronics space. I do however have lead weight on the electronics side of the car. The upside to that, is when adding lead I get to dictate where the weight goes on the chassis. You can't move the servo fore-aft...
Old 01-20-2012, 08:59 AM   #1289
Michał Fedor's Avatar
I run with lo profile kopropo and it fits great.
Xray T3'12/LRP
Team Xray Poland
Michał Fedor is offline   Reply With Quote
Old 01-21-2012, 02:35 PM   #1290
Phil C's Avatar
https://twitter.com/teamxray/status/160642343236677632
Just in case you haven't seen this
| Team XRAY UK | HUDY | RC DisCo| LRP | Sanwa | SMD | Moorespeed | MB Models | Gingapaint | McLaren Racing |
Phil C is offline   Reply With Quote
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 12:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 05:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-16-2011 11:58 PM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 03:11 PM
