Old 01-09-2012, 07:06 AM   #1186
M-Technic's Avatar
Trader Rating: 15 (100%+)
Originally Posted by zaraz View Post
thanks, I guess the battery tape is the best method, finding the hudy tape is impossible, it is sold out every where, any other tape that is just as good, I have the top stuff and it is total garbage, so really at a loss to find a good method to keep the batteries in right now
The black tape from Nexus Racing is WAY better than the TOP Racing tape.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 01-09-2012, 03:39 PM   #1187
gonzo416's Avatar
Trader Rating: 39 (98%+)
Originally Posted by CraigM View Post
Not meaning to sound like a jerk, I wanted to understand why you said that - now you have answered because the link angle changes slightly, unless you compensate
There's some great reading on roll centre here
http://users.telenet.be/elvo/3/3.html
Can you post the link to the complete guide? It looks like some good info
gonzo416 is offline   Reply With Quote
Old 01-09-2012, 03:44 PM   #1188
locked's Avatar
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 01-09-2012, 04:00 PM   #1189
gonzo416's Avatar
Originally Posted by locked View Post
Thanks.
I really need to learn to setup a car and understand all of it. I can drive pretty good, just need to get that setup edge so I can make the car do what I want to get better lap times. Instead of using other peoples setups.
Old 01-09-2012, 04:05 PM   #1190
locked's Avatar
One of the local racers here wrote the "M-powered touring car setup guide". This became the "xxx-main setup guide". He has all this now in an app for android and iPhone, called "RC car setup workbench"
Highly recommended.
Dave Locke
Old 01-09-2012, 04:18 PM   #1191
gonzo416's Avatar
Highly recommended.
I purchased it
Old 01-09-2012, 05:09 PM   #1192
gonzo416's Avatar
Should I go with the box setup for a med to low traction track (70x40)?
Old 01-09-2012, 08:18 PM   #1193
what does it do to shorten or lengthen the front wheelbase?
ioxqq is offline   Reply With Quote
Old 01-09-2012, 09:34 PM   #1194
nerdling's Avatar
I would as a starting point.
--XRAY--NOSRAM--PROTOFORM--MUCHMORE--
www.teamxray.com -- www.hudy.net -- www.hobbyexpress.com.au
nerdling is offline   Reply With Quote
Old 01-09-2012, 09:36 PM   #1195
nerdling's Avatar
All things being equal, moving the front wheels towards the middle of the car will induce understeer, moving the away will allow for more weight transfer to the fron wheels, possibly casue oversteer.
Old 01-10-2012, 07:05 AM   #1196
Default Spur help
First time I ever purchased and built an x-ray. Just noticed that all my spur gears do not fit the standard mount. Also that the lowest spur I can get is a 78t 48p. Thus my question is - I run spurs in the vicinity of 68-72t - is there an adaptor that would allow non standard X-ray gears to be used or is there a brand that will fit the t3 2012 other tha x-ray in the low 70's
emerge is offline   Reply With Quote
Old 01-10-2012, 07:15 AM   #1197
ByteStream's Avatar
RW Racing ..
48P Xray Spurs from 45T - 105T
64P Xray Spurs from 80T - 136T
http://www.rwracing.co.uk/cars.html
RCAmerica | Xray | Hudy | KO Propo | Hobbywing HWNA | R1Wurks | BSR Tires
5280 Raceway - www.5280raceway.com
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
ByteStream is offline   Reply With Quote
Old 01-10-2012, 08:22 PM   #1198
See what the post man bring me today. Packaging looks good and the materials seems good as well. Can't wait to try it.
Xray T3 2012-imag0368.jpg   Xray T3 2012-imag0369.jpg   Xray T3 2012-imag0370.jpg   Xray T3 2012-imag0371.jpg
http://www.gpm-parts.com
gpm-parts.com is offline   Reply With Quote
Old 01-11-2012, 03:12 AM   #1199
kakaroctt's Avatar
Default droop & downstop
hello guys..i need help..
been asking paul lemiux in the xray website but there's argument between ppl there..and makes me even lost..my question quite simple..is droop=downstop?t3 12 manual n setup sheet doesnt mention about how to adjust droop..what is droop and what so importan about it?
LEGGERE LE ISTRUZIONI PRIMA DELL' USO !
kakaroctt is offline   Reply With Quote
Old 01-11-2012, 05:14 AM   #1200
pchroma24's Avatar
Trader Rating: 79 (100%+)
According to Martin Crisp's definition, droop is simply the vertical distance the chassis travels from the point it is sitting at rest to the point the wheel lifts off the ground, usually measured with a ride height gauge. Typically around 2mm is a good starting point. It controls weight transfer by limiting the amount the chassis rolls when transitioning through a corner. It is adjusted by the grub screws located towards the inside of the arms. Small adjustments go a long way here... I cannot answer with absolute certainty if downstop=droop but I (imo) view them the same.... I do hope this is helpful...
If you can't explain it simply, you don't understand it well enough... Einstein
pchroma24 is offline   Reply With Quote
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 12:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 05:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-16-2011 11:58 PM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 03:11 PM
