Old 01-07-2012, 04:57 AM   #1156
jake95's Avatar
Trader Rating: 27 (100%+)
6front 5rear
XRAY✯NOSRAM✯SANWA
jake95 is offline   Reply With Quote
Old 01-07-2012, 06:14 AM   #1157
NR
NR's Avatar
Trader Rating: 52 (100%+)
Originally Posted by jake95 View Post
6front 5rear
Cheers Jake
NR is offline   Reply With Quote
Old 01-07-2012, 12:05 PM   #1158
UrabusDenis's Avatar
Any ideas on how the kit setup will work with foams on asphalt? I know foams aren't used almost anywhere except here so I wonder how good/bad the setup will be
JQRacing - eu.jqracing.com
Blue Bird - www.blue-bird-model.com
RW mods - www.rw-mods.com
Boca Bearings - www.bocabearings.com
UrabusDenis is offline   Reply With Quote
Old 01-07-2012, 03:56 PM   #1159
theatriks's Avatar
Hey guys im having a little trouble with my t3 2012 ....ive tripled checked my install of the spur gear and its correct per manual but for some reason my front belt keeps flipping upside down so teeth facing up....what else could itg be ....tighten the belt even more? any thoughts would be appreciated ...Thanks
theatriks is offline   Reply With Quote
Old 01-07-2012, 04:25 PM   #1160
pcar951's Avatar
Trader Rating: 19 (100%+)
I had some similar belt issues with my T3/12, found that the top deck was broken! Hope it's not the case for you but...
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy | Reds Racing
pcar951 is offline   Reply With Quote
Old 01-07-2012, 05:17 PM   #1161
theatriks's Avatar
No top deck is fine ......i moved my pinion back a touch just in case and i tighten the front belt a bit more and backed my battery as far away as possible ..quadrupple checked my spur setiings sooo we will find out tommrow if its good or not.
Old 01-07-2012, 09:37 PM   #1162
303slowdown's Avatar
I would tighten the belt more. My car did the same thing so I tightend the belt til it stayed the right way.
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 01-07-2012, 09:57 PM   #1163
XRAYGIZMO's Avatar
Hi
Are your spur mounting screws facing the rear the rear belt? If they are not the front belt can catch in the gaps in the little plastic guide, as the front belt is a lot longer it flops around a fair bit. A good idea also is to run the optional belt tensioner 303071. It tends to stop the front belt twisting after a while.
Regards
Todd
Xray T4...T3... T2... T1...
Tekin ESC...Trinity Motors...Futaba Servo...Interllect Batteries...
Protoform Bodies... Muchmore Tyres...Futaba Radios...
Tamworth Radio Control Car Club (Retired Racer)
XRAYGIZMO is offline   Reply With Quote
Old 01-07-2012, 10:20 PM   #1164
Jay7's Avatar
Send a message via AIM to Jay7
Make sure the Eccentric holders (bearing carriers) are in the same exact position left and right. Carpet track, is with the pointer pointing towards the top upper deck.
Jay7 is offline   Reply With Quote
Old 01-07-2012, 10:47 PM   #1165
XRAYGIZMO's Avatar
Originally Posted by zaraz View Post
hi, I do not like taping in my batteries, and was looking at the xray lipo battery graphite strap part number 306163-K, any one have one intalled on their car, how does it work, it says it will not tweek the chassis no matter how tight you screw it in, so those who have it is this a true statement, as it would be a great option for me but not sure about the claim, thanks
The secret to using the strap, is don't clamp the battery tight, or your chassis will be tweaked badly. Make sure you space the posts correctly so you can move the battery freely. Once you do this and with a battery in, and the screw done up tight then twist your chassis and you will see at the screw end, the strap will move back and forth as it is slotted. The other end will pivot on the ball. Its also a good idea to use the Xray alloy battery backstops.
I hope this helps.
Todd
Old 01-07-2012, 10:56 PM   #1166
kakaroctt's Avatar
Originally Posted by CraigM View Post
There's some great reading on roll centre here
http://users.telenet.be/elvo/3/3.html
hey..what a usefull info...+1..
thanks,,
LEGGERE LE ISTRUZIONI PRIMA DELL' USO !
kakaroctt is offline   Reply With Quote
Old 01-08-2012, 03:48 AM   #1167
I have it and found out that if you adjust it (using shims) so that it holds the battery in place it tweaks the chassis so I stopped using it.
If you adjust it not to tweak the chassis then the battery can move ca. 1mm front - rear.
I now use hudy tape to strap down my battery. Lighter, easier and faster. One piece of tape will get you through a whole day on the track.
taz00 is offline   Reply With Quote
Old 01-08-2012, 09:43 AM   #1168
RC MARKET's Avatar
A+ & CSO Released upped bulkhead
A+ lower 1 mm
CSO lower 1mm w/ hard coated
RC MARKET is offline   Reply With Quote
Old 01-08-2012, 03:32 PM   #1169
Trader Rating: 26 (96%+)
thanks, I guess the battery tape is the best method, finding the hudy tape is impossible, it is sold out every where, any other tape that is just as good, I have the top stuff and it is total garbage, so really at a loss to find a good method to keep the batteries in right now
zaraz is offline   Reply With Quote
Old 01-08-2012, 04:18 PM   #1170
RobS's Avatar
The top tape is probably the best tape I have used. Never had an issue with battery movement running 17.5 boosted and modified. One piece of tape front to back, and one piece through the battery slots going left to right and it won't move.
Rob Say
Action Hobbies Kingsville
"In racing you never really lose. You either win, or learn."
RobS is offline   Reply With Quote
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 01:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 06:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-17-2011 12:58 AM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 04:11 PM
SEO by vBSEO 3.5.0
