Old 01-03-2012, 06:12 PM   #1126
Could anyone help to give me some advice?
The current layout of the track I'm playing contains lots of short straights then U-turns.
My T3 2012 is lacking mid-corner steering and also experiencing on-power push. Seems the rear is dialed too much.
I'm using basic asphalt setup except with 3000t rear diff oil and 1mm inner camber link shim both front & rear. Have tried using smaller deg of diff oil but push even hard.
yokfans is offline   Reply With Quote
Old 01-03-2012, 06:55 PM   #1127
Suspended
Trader Rating: 35 (91%+)
Try 5000 in the dif and long camber links in the rear that should free up the rear end.
Jeff.
Sponsors team c usa. .t8t. -t8 futaba 3pk- jc tires-savox servos-power master fule.
jeff stanford
j dogg is offline   Reply With Quote
Old 01-03-2012, 07:53 PM   #1128
Jeff.
Thanks! In other words I should try to lower the rear roll center, right?
Old 01-03-2012, 07:58 PM   #1129
stankulas's Avatar
longer link = less camber gain, thicker oil should free up rear or make it drift a little and a longer link
RC America
Xray
Hudy
stankulas is offline   Reply With Quote
Old 01-03-2012, 08:00 PM   #1130
KHoff7's Avatar
Ive never been so happy with a touring car before. This is an amazing car.
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Old 01-03-2012, 08:05 PM   #1131
Suspended
Correct.
jeff stanford
Old 01-03-2012, 08:06 PM   #1132
syndr0me's Avatar
Trader Rating: 32 (100%+)
After the light blue nightmare, I swear I hear angels sing every time this car touches the track.
syndr0me is offline   Reply With Quote
Old 01-03-2012, 08:08 PM   #1133
KHoff7's Avatar
You know it, two years wasted for me haha. I ran a TC6 the last 6 months or so and that was better, but then the 2012 came along and WOW.
Karl Hoffmeister
Old 01-03-2012, 08:21 PM   #1134
syndr0me's Avatar
I want a mulligan on Snowbirds '11. I never knew a car could traction roll going in a straight line.
Anyway, the '12 is great. Mine's actually got too much grip right now, and doesn't seem to roll enough. I'm gonna put the XRay shocks back on for racing this week, and then start trying to figure that out.
Old 01-03-2012, 09:16 PM   #1135
Default racing car blog
Many of new versions are yet to come and the excitement is everywhere now see which would be the best one ..do you have any idea about the price?
kris2020 is offline   Reply With Quote
Old 01-03-2012, 10:17 PM   #1136
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by artwork View Post
OK here we go...
Making the top links longer in front does what ?
Longer links lowers the roll center, also less camber gain and typically decreases traction
Making the top links longer in rear does what ?
Adding shims to the front inner link on bulk head does what?
Flatter links lowers the roll center, also less camber gain and typically decreases traction
Adding shims to the outer front link on the c hub does what?
More angled links will raise the roll center, provides more camber gain and typically increases traction
Adding shims to the inner rear ling on the bulk head does what?
Adding shims to the outer rear link on the hub does what?
Making the front wider then the rear does what?
Increasing the track width will make that end of the car more stable and will typically generate less lateral grip.
Making the rear wider then the front does what?
Flatter links in general are considered stiffer and angled links are considered softer...
Remember whatever change you do will effect the overall balance of the car, so you are not just effecting one side or end of the car!
Can you explain how changing the link length changes the roll centre if the angle stays the same?
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 01-03-2012, 11:49 PM   #1137
mdwaeracer's Avatar
Trader Rating: 19 (100%+)
It makes the camber gain slower. numbing that end.
TEAM ASSOCIATED Rc10, rc10B6D ,FUTABA , TEAM ORION, KYOSHO RB6.
mdwaeracer is offline   Reply With Quote
Old 01-04-2012, 12:45 AM   #1138
scoyle's Avatar
Shortening the wheelbase is also something that I try on tight tracks - may not always suit but is worth a try.
Web Site: http://www.rcracingreviews.net
Sponsors: Schumacher UK | XFactoryUK | Zen Racing
scoyle is offline   Reply With Quote
Old 01-04-2012, 01:42 AM   #1139
Skiddins's Avatar
How soft did you go with the rear diff oil?
Most of the indoor setups I've seen seem to like 450 oils in the shocks.
You could also try softer front springs.
My experience on Friday while talking to better drivers was to make the front shocks more vertical to get the front tyres to bite to prevent understeer.
Not sure if that's better just for corner entry.
Also make sure you are running the shortest top links at the front.
Perhaps lengthen the rears and reduce rear toe to free the back end up.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 01-04-2012, 02:11 AM   #1140
Skiddins
I've tried softer front spring but that only leads to more push during corner entry in a U-turn. Harder front spring seems better.
For sure I'm running the shortest top links at the front since it's the default asphalt setting.
Thanks!
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 12:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 05:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-16-2011 11:58 PM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 03:11 PM
