Old 01-02-2012, 11:21 AM   #1111
Marek Gadomski's Avatar
Originally Posted by nerdling View Post
Hi Marek,
The belt napping is probably related as much to driving technique as it is setup. I've not managed to snap a belt since September, racing is similar high grip environments and just being careful with throttle applications.
What sort of motor/track conditions do you race in?
X12 5.5 modified rubber sorex 28 high grip carpet / medium asphalt
____________________________________________________
Tamiya TRF 417X-Speed Passion-Thunder Power-KoPropo
marcgadomski@gmail.com
http://www.facebook.com/marc.gad
Marek Gadomski is offline   Reply With Quote
Old 01-02-2012, 11:29 AM   #1112
haywood's Avatar
Trader Rating: 48 (100%+)
Originally Posted by Duzgit View Post
hey guys,
I also finished my new t3 '12 last week, now everything is setup but didn't have a chance to test the car yet. However the parts quality is awesome and booklet is clear, I really liked it.
I have only one question, the rear small AL. bulks which gives the toe in.. During the assambly of it when I screwed these small bulks, I recognized that they move a little which changes the rear toe angle..After the assambly I found out that the rear right toe in is 3mm and rear left toe in is 2.5mm ..I am sure that I assambled everything correct way double checked already.. There is some variation I guess, have you guys seen such issue or is it normal?
Many thanks in advance.
What is the deal with the 2012 rear toe issues? I have seen this time and time again! I have never had this problem on my 2011.
Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 01-02-2012, 11:39 AM   #1113
Originally Posted by Skiddins View Post
Can't find the video you mentioned.
I also found the problem with the rear toe using Integy's system which I had before.
yes we have checked the issue with the setup board which has ruler and other equip connected to shafts without wheels.
actually it is not the measuring issue, when assambling the small bulks, if you rotate it a bit and screw like that it is kept pointing different toe angle..when you unscrew and screw again, it is different toe angle ...it is the bulk itself.
check out the xray instruction manual page 10, top picture it says "the rear aliminum holders have integrated rear toe in" as you can see the red line angle changes everytime you unscrew these bulks and screw again...weird.
[URL="https://www.facebook.com/cakercshop/?fref=ts&ref=br_tf"]TEAM SHEPHERD TURKEY[/URL]
Duzgit is offline   Reply With Quote
Old 01-02-2012, 11:41 AM   #1114
entitymugenmtx's Avatar
Trader Rating: 81 (100%+)
Send a message via AIM to entitymugenmtx
This is my first Xray I didn't have any problems with the rear toe both show 3
SPONSORS.....MY CHECKBOOK....
entitymugenmtx is offline   Reply With Quote
Old 01-02-2012, 11:42 AM   #1115
Originally Posted by j dogg View Post
Hi make sure u have the rear hinge pin holders on right if u look at them the flat side should b facing the bulk heads .my buddy had the same problem and that was it.
thanks jeff.
hi mate, thanks for your information, I have double checked , they are correct, as I have mentioned in my above post, they are directly realted with the Al. bulks itself.
Old 01-02-2012, 12:05 PM   #1116
morgoth's Avatar
Originally Posted by Emil View Post
Did you check this with setup wheels and a ruler? If you search youtube you can see Collari pointing out a minor imperfection in the HUDY setup system which gives an inaccurate reading of toe-in. I have heard other top drivers state the same.
Just my two cents.
- Emil
Do you have a link of that video?
Serpent BeNeLux teamdriver // FX Engines // Nitrolux fuel
My blog: http://scrubbingspeed.wordpress.com
morgoth is offline   Reply With Quote
Old 01-02-2012, 12:12 PM   #1117
haywood's Avatar
If I want 1.5 of negative camber I set it at 2 on the Hudy. Not sure on toe.
Old 01-02-2012, 04:47 PM   #1118
Skiddins's Avatar
I have also noticed before that there is a small difference in the rear single piece block, it seems very slightly offset to one side when measured against the main rear bulkheads.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 01-02-2012, 06:41 PM   #1119
Send a message via MSN to Emil
Sorry it was Salven not Collari but here is the link:
Try http://www.youtube.com/results?searc...1135l0.6.1l7l0.
- Emil
Emil is offline   Reply With Quote
Old 01-02-2012, 07:38 PM   #1120
http://www.vbcracing.com/Main.html#/tuning_kits.html
Hum... the T32 both "F" and "S" looks slick. Ordered both and can't wait to try it.
http://www.gpm-parts.com
gpm-parts.com is offline   Reply With Quote
Old 01-03-2012, 04:18 AM   #1121
morgoth's Avatar
- Emil
Do you mean this one? I've seen it last week, but he doesn't explain why it's wrong unfortuately. Mine reads 3 on each side of my T3, but I haven't tried it with a ruler.
http://www.youtube.com/watch?v=ILFfD...&feature#t=436
Old 01-03-2012, 01:07 PM   #1122
Send a message via AIM to Matt W
Default Turnbuckle positioning!!
Hi guys,
One of the more common setup changes on the xray is altering the upper turnbuckle position and therefore affecting the cars rollcenter and camber change. Could someone please give a detailed explanation of how altering the height and angle of the turnbuckle using shims affects the cars handling?
thanks!!
Matt W is offline   Reply With Quote
Old 01-03-2012, 01:28 PM   #1123
Trader Rating: 30 (97%+)
Originally Posted by Matt W View Post
Hi guys,
thanks!!
+1. Just need an understanding on the following issuse as well, and if someone can explain it to me like I am a two year old, my english in not good,
Making the top links longer in front does what ?
Making the top links longer in rear does what ?
Adding shims to the front inner link on bulk head does what?
Adding shims to the outer front link on the c hub does what?
Adding shims to the inner rear ling on the bulk head does what?
Adding shims to the outer rear link on the hub does what?
Making the front wider then the rear does what?
Making the rear wider then the front does what?
I read the triple x setup guide, and it was gibberish to me, so thanks in advance for helping with these questions
zaraz is online now   Reply With Quote
Old 01-03-2012, 01:46 PM   #1124
artwork's Avatar
Trader Rating: 59 (100%+)
OK here we go...
Longer links lowers the roll center, also less camber gain and typically decreases traction
Flatter links lowers the roll center, also less camber gain and typically decreases traction
More angled links will raise the roll center, provides more camber gain and typically increases traction
Increasing the track width will make that end of the car more stable and will typically generate less lateral grip.
Flatter links in general are considered stiffer and angled links are considered softer...
Remember whatever change you do will effect the overall balance of the car, so you are not just effecting one side or end of the car!
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 01-03-2012, 01:58 PM   #1125
mutley001's Avatar
Originally Posted by artwork View Post
OK here we go...
Great discription thanks very much
Also on the subject I ran across this on the xray site - also very useful
ARC R11 2017
ARC R10 2013
EA Motorsports www.teameamotorsports.com
Team EAM
mutley001 is offline   Reply With Quote
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 12:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 05:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-16-2011 11:58 PM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 03:11 PM
