Old 12-22-2011, 07:25 AM   #1021
pcar951's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Skiddins View Post
You could also add to the list of things to try;
Wider shims at the wishbone
-0.75 rear hexes
And don't rule out trying softer springs
Also, a lightweight bodyshell can help remove a lot of weight from higher up!
My steering expo is always at -15-20%
If it's happening on corners that aren't that tight, try limiting your end points to 70-80%
Thanks, I haven't tried softer springs but, it's likely my next step if the problem still exists on race night when the grip comes up.
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy | Reds Racing
pcar951 is offline   Reply With Quote
Old 12-23-2011, 07:32 AM   #1022
Originally Posted by fpart View Post
Anyone know when the next batch of T3 2012 versions will be in. I see most people have them out of stock!
I picked mine up on Tuesday so they should have started flowing in. Just opened the box last night, can't wait to start building her.
angelblade is offline   Reply With Quote
Old 12-23-2011, 04:19 PM   #1023
entitymugenmtx's Avatar
Trader Rating: 81 (100%+)
Send a message via AIM to entitymugenmtx
Does anyone use these
305137 - Optional Solid Axle Driveshaft Adapter - HUDY Spring Steel
305136 - T2'008 Optional Alu Solid Axle Driveshaft Adapters (2) - Hard-Coated
SPONSORS.....MY CHECKBOOK....
entitymugenmtx is offline   Reply With Quote
Old 12-23-2011, 06:36 PM   #1024
mikel33's Avatar
Trader Rating: 2 (75%+)
Originally Posted by pcar951 View Post
I tried a ton of different setups last night trying to limit traction rolling. I ended up with: CST 463 front oil, CST 425 rear oil (1.0 X 3 pistons), angled front sway bar links (rearward), +75 front hexes, -10 steering expo. The rest of the setup is still pretty much basic carpet. Still not 100% but, much improved.
I copied this from a thread on traction rolling. This always works for me.
Originally Posted by Greg Sharpe View Post
I couldn't disagree more. Softening up suspension delays the maximum cornering load, thus delaying the traction roll. I won't bore everyone with a rehash of the Type-R thread, but my traction rolling issue is well documented over there and the things we did to cure it worked quite well.
Your suggestion to stiffen the suspension assumes that the tire's traction can be breached at some point during the corner. However, B18C Turbo lives in New England, land of spec rubber tire touring cars on CRC carpet and odorless traction compounds. The bite there is literally sticky, and breaching that is next to impossible.
Letting the car roll is also key to preventing the outside tires from reaching maximum loading, so adding roll stiffness is completely backwards.
Guys, consider this. What does a touring car do in the moment right before it traction rolls? It bicycles. That two wheeled circus stunt places the entire weight of the car on the two outside tires. With weight comes traction. That traction spike flips the car over. Doing anything that reduces droop, constricts suspension movement, or otherwise quickens tire loading is counterproductive.
Some of the more important things I did to cure my traction roll (and win) on carpet with rubber tires:
-lay the shocks down
-reduce camber
-reduce roll stiffness (springs and swaybars)
-adjust dampening to delay maximum loading (in my case, I had to increase front dampening to get through the sweeper without traction rolling, used a ton of rebound to improve transitional response)
-lower roll centers
-reduce caster (Paulie's trick)
-add droop to all four corners (thanks Fairtrace)
Michael Larson.
Village Idiot Racing - Now accepting driver applications.
mikel33 is offline   Reply With Quote
Old 12-23-2011, 11:08 PM   #1025
morgoth's Avatar
No. I've only tried mid and long, figured that the increased camber gain with short links would only make things worse. What's you experience with short links?
It makes the car more forgiving and it's easier to drive. I'd say that it's worth trying it. Try the short links all around and also short front and mid rear.
Serpent BeNeLux teamdriver // FX Engines // Nitrolux fuel
My blog: http://scrubbingspeed.wordpress.com
morgoth is offline   Reply With Quote
Old 12-23-2011, 11:34 PM   #1026
pcar951's Avatar
Thanks for all your input. Raced 6 qualies and 2 mains without a single traction roll tonight. Rubber side down is good! If anyone wants to know, heres what I changed:
- 463 CST front shocks / 3.0 springs
- 425 CST rear shocks / 2.6 springs
- +75 front wheel hexes
- lower roll center / +1mm inner front camber links
- -10% steering expo
- laid the front shocks down one hole from kit setup
Jim Chapman
Old 12-26-2011, 01:14 PM   #1027
Default What is eccenter
Seen it on the setup sheets but only says standard and 1 any idea but points to the diff was told on the xray forum it was the use of the excentric diff holders but dont seen right as car comes with them?????
Quietman is offline   Reply With Quote
Old 12-26-2011, 01:33 PM   #1028
Johnny Wishbone's Avatar
The 1 excentrics are a option part that can either raise or lower your diff 1mm from what the stock items locate the diff at. The 1's don't come with the stock kit.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 12-26-2011, 11:39 PM   #1029
morgoth's Avatar
Hey Guys,
Just bought a 10.5T. Does anyone know a good starting ratio for boosted indoors?
Old 12-27-2011, 02:08 AM   #1030
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Originally Posted by morgoth View Post
Hey Guys,
Really depends on the size of the track and the motor. I would start around 7.0-7.5 if you already have a lot of timing / ramp in the esc. Run about 2 min check temp, then check temp every 2 min after that for 5 min. For reference non boosted 10.5 is 5.5 starting ratio.
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 12-27-2011, 08:28 AM   #1031
oldrcr's Avatar
Trader Rating: 44 (100%+)
Jonny is correct. The standard set that comes with the kit, is eccentric, and gives you .5mm of offset. Either put the nib that locates the bearing holder up or down to get .5mm up or down of diff offset, for a total of 1mm of movement. It is why the belt tension adjustment notches are on both the bottom bulkhead piece as well as the top piece that the shock towers mount to. Make sure the nib points the same direction on both sides. They make an optional set that gives you 1mm of offset up or down, for a total of 2mm of movement. Part #302077
Alxd - Seattle RC Racers - AWESOMATIX - Having Fun :-)
oldrcr is offline   Reply With Quote
Old 12-27-2011, 08:29 PM   #1032
syndr0me's Avatar
Trader Rating: 32 (100%+)
What CVD that fits this car is least likely to bend? Any brand.
syndr0me is offline   Reply With Quote
Old 12-28-2011, 04:06 AM   #1033
orci77's Avatar
Hudy Spring Steel.
You normally need a very heavy crash to bend them.
Xray T3'012 + Nosram Pearl SpecRacing V2 + LRP X12 17,5T / X11 9,5T / X11 6,5T
Team Associated SC10 + Nosram Matrix Reverse + LRP X11 13,5T
3Racing F1-09 + LRP Sphere + LRP X11 17,5T
orci77 is offline   Reply With Quote
Old 12-28-2011, 04:28 AM   #1034
morgoth's Avatar
I forgot to say that the track is about 30m*14m. Thanks for your input!
Old 12-28-2011, 05:52 AM   #1035
M-Technic's Avatar
Trader Rating: 15 (100%+)
Haven't seen any CVD in any car stronger than Hudy Spring Steel.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 12:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 05:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-16-2011 11:58 PM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 03:11 PM
