Old 12-09-2011, 01:44 PM   #946
syndr0me's Avatar
Trader Rating: 32 (100%+)
Originally Posted by theatriks View Post
i got some tamiya anti wear grease left over u think that would work on my ecs shafts?
Yep. It's the stuff Tamiya uses on their CVD's.
syndr0me is offline   Reply With Quote
Old 12-09-2011, 01:56 PM   #947
M-Technic's Avatar
Trader Rating: 15 (100%+)
Originally Posted by syndr0me View Post
What do you guys do about wheels that want to rub on the front camber links? Grind the rim down on a truer?
I use a tool made for beveling or deburring plastic pipes. The one I have easily bevels the inside of the rim to make clearance.
Similar to this:
http://www.google.com/products/catal...ed=0CHEQ8wIwBg
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 12-09-2011, 02:04 PM   #948
haywood's Avatar
Trader Rating: 48 (100%+)
http://www.amainhobbies.com/product_...Joint-w-Hole-4
Roche Rapida P12 2015/2016/2017 / Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 12-09-2011, 02:18 PM   #949
syndr0me's Avatar
Similar to this:
Huh, I have one of those in my bag. I'll give it a try.
Originally Posted by haywood View Post
Yeah, I'm using those, they don't help.
Old 12-09-2011, 03:06 PM   #950
Fred Hubbard's Avatar
The tool is okay for club racing but keep in mind that at any control tire race you can't modify the rim in any way. Grinding any material off the rim will induce more flex into it and change the handling of the car. I have always told people when using our ball studs that even though the instructions for the VBC's state to use the round ball cups to use the stock ball cups instead that came with cars previous to the '12. This is because the non-rounded cups create a flat plane which allows you to run as much as 3mm worth of shims on the front hubs and 5mm or more on the rear hubs without rubbing the inside of the rim and violating any rules.
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 12-09-2011, 03:16 PM   #951
NO, don't use that stuff on the ECS's! The stiction rate is too high due to the constant angle change and movement of the ECS's. I use a high quality bearing lube made by Trackstarrc.com. I have found that grease attracts debris which can inhibit fluid movement of the joints of all drive shafts and it's time consuming to clean off. So the oil is nice and light and naturally has better coverage and is easy to clean off with motor spray / brake cleaner and doesn't attract debris like grease does.
Last edited by Fred Hubbard; 12-09-2011 at 06:29 PM. Reason: missing punctuation marks
Old 12-09-2011, 08:37 PM   #952
Team EAM
EAMotorsports's Avatar
Trader Rating: 75 (100%+)
Send a message via AIM to EAMotorsports
Originally Posted by Fred Hubbard View Post
The tool is okay for club racing but keep in mind that at any control tire race you can't modify the rim in any way. Grinding any material off the rim will induce more flex into it and change the handling of the car. I have always told people when using our ball studs that even though the instuctions for the VBC's state to use the round ball cups to use the stock ball cups instead that came with cars previous to the '12. This is because the non-rounded cups create a flat plane which allows you to run as much as 3mm worth of shims on the front hubs and 5mm or more on the rear hubs without rubbing the inside of the rim and violating any rules.
http://www.teamxray.com/teamxray/pro...20V2%20%288%29
Thats the 4.9mm open end for the outside upper camber links. Its what was used on the old car and like Fred said allows you to raise the outside a lot higher than the ball cups do.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID | Futaba.
EAMotorsports is offline   Reply With Quote
Old 12-09-2011, 10:26 PM   #953
dontfeelcold's Avatar
Trader Rating: 20 (100%+)
The correct think to say is that the viscosity of Tamiya AW is to great for that application. I wouldn't normally correct people but I'm not a fan of the word stiction. All in good humour
dontfeelcold is offline   Reply With Quote
Old 12-09-2011, 11:08 PM   #954
Sith Lord's Avatar
Trader Rating: 21 (100%+)
Originally Posted by dontfeelcold View Post
The correct think(g) to say is that the viscosity of Tamiya AW is too great for that application. I wouldn't normally correct people but I'm not a fan of the word stiction. All in good humour
Not another round of gramma bagging.......
Tamiya XV-01 Rally :: Tamiya FAV 2011 :: Proline Pro2 SCB
Sith Lord is offline   Reply With Quote
Old 12-09-2011, 11:14 PM   #955
mazmorbid's Avatar
Trader Rating: 9 (91%+)
Originally Posted by Sith Lord View Post
Not another round of gramma(r) bagging.......
Looks to be the case ..
Xray XB9 - Xray XB808 2011 - Novarossi - J.R. - Futaba - Ascendancy - Pro-Line
mazmorbid is offline   Reply With Quote
Old 12-10-2011, 12:24 AM   #956
Sith Lord's Avatar
I did that on purpose just to spike things up. Really..... I did.....
Betcha you read over your 5 words a thousand times before posting.
Old 12-10-2011, 07:55 AM   #957
haywood's Avatar
It's a running change so the part number is the same, do be sure and confirm that what you are getting are the blue ones. FYI I have orderd pins from mcmaster before and had the cut to lenth and a notch cut into them. The pin stock I got from them was junk and worse than our V2 pins, so caveat emptor!
ECS Drive Shaft Pin 1.5 x 8.5 - V3
ECS Drive Shaft Pin 1.5 x 9 - V3
Since it is a running change does anyone know what shops have the new v3 in stock?
Old 12-10-2011, 03:39 PM   #958
Trader Rating: 193 (99%+)
Fred to correct you a little on grease and lube oils. The purpose of grease is to stay in place to lubricate. The reason for different viscosity of grease has many factors such as pressure and speed of the item in need of lubrication along with the application method and operating temperatures to name a few.
The reason you do not see any debris on the LCD's with oil is because it has flung off, so nothing will stick to something that is not there. Yes the grease will attract debris however it will lubricate better and will need to be cleaned and replaced most often for ideal wear.
Grease is actually contains thickeners to hold/suspend the oil that is the lubrication properties. Of course there are other additives and anti-wear compounds in the grease for different applications.
What one should be looking for is a grease that would not change the amount of movement of force during angle change.
I am in the lubricant business so if you need further technical info I can get that.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 12-10-2011, 08:57 PM   #959
Heck no, no need to school me anymore, I believe, I stand corrected Do you have any recommendations on what we should use?
Old 12-10-2011, 09:35 PM   #960
ByteStream's Avatar
I've been using the the Hudy Black grease that comes with the kit for ECS's and have not had any issues with it at all. I heatshrink the ECS as well, so the amount of debris that actually gets in there is very minimal. Anything wrong with using that type of grease?
RCAmerica | Xray | Hudy | KO Propo | Hobbywing HWNA | R1Wurks | BSR Tires
5280 Raceway - www.5280raceway.com
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
ByteStream is offline   Reply With Quote
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 01:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 06:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-17-2011 12:58 AM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 04:11 PM
SEO by vBSEO 3.5.0
