Old 12-07-2011, 03:14 PM   #916
M-Technic's Avatar
Trader Rating: 15 (100%+)
Originally Posted by angelblade View Post
thanks syndr0me. Tehnic - are you being sarcastic? Seriously? I would love (one day) to get into on track racing. I just wanted to get a good car and setup to do speed runs, turns (not tight like you guys at the trac)...but I heard the 4.5/esc tekin combo will overheat too fast all of the time. I don't mind if it is a beast...I just won't attempt to take her in small places at first etc...
Not being sarcastic at all. A 4.5t, especially if you are not running any boost, is not as fast as people are making it out to be. Especially when you are doing speed runs in an open parking lot. My point was, if people race with boosted 4.5t on tight tracks, then it can be handled for bashing in an open parking lot.
A 17.5t for "speed runs" would be pretty boring.
A Tekin RS Pro can handle a 4.5t turn motor and it will not overheat. At worst you will have to add a second cap and maybe a fan. The Pro is made to handle mod, and although it's not commonly used for mod touring car because of it's poor throttle feel, it will work in your application.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 12-07-2011, 03:54 PM   #917
locked's Avatar
Yeah, I forgot about the first time I put a 5.5 in one of my cars and had my ESC in blinky mode. It felt slower than my boosted 13.5 until I added a bit of boost and turbo. Then it really woke up.
I would still worry about the Tekin getting too hot if just doing constant speed runs back and forth with a 4.5 or if racing on a large flowing track with a big straight. Especially on a hot summer day. Yes, it can do it, but keep an eye on the temps.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 12-07-2011, 04:59 PM   #918
theatriks's Avatar
hey guys im putting my ecs shafts together and it calls for hudy graphite grease............what are my alternatives anybody know of anything perhaps something from a hardware store?
theatriks is offline   Reply With Quote
Old 12-07-2011, 05:35 PM   #919
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
I guess you could use some Molybdenum grease from the automotive store(black grease). But I would suggest using Mugen Super grease which a lot of hobby shops stock. I would also suggest using 3/8 inch shrink wrap. I have seen a lot of people try to overtighten the grub screws and bind up the assembly.
Cheers
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 12-07-2011, 05:50 PM   #920
haywood's Avatar
Trader Rating: 48 (100%+)
Cheers
I use Hudy grease then loctite assemble and wrap with heat shrink like rx7 stated!
Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 12-07-2011, 06:41 PM   #921
entitymugenmtx's Avatar
Trader Rating: 81 (100%+)
Send a message via AIM to entitymugenmtx
Why does everyone heat shrink there ecs
SPONSORS.....MY CHECKBOOK....
entitymugenmtx is offline   Reply With Quote
Old 12-07-2011, 06:47 PM   #922
Davin's Avatar
Trader Rating: 43 (98%+)
So the screw and pins dont fall out
Davin is offline   Reply With Quote
Old 12-07-2011, 06:48 PM   #923
syndr0me's Avatar
Trader Rating: 32 (100%+)
Speaking of, what's the part numbers for the strongest replacement pins? Anything else in the ECS ever break?
syndr0me is offline   Reply With Quote
Old 12-07-2011, 06:50 PM   #924
haywood's Avatar
Exactly! Those pins are expensive and if they start coming out can also damage the caster block!
Old 12-07-2011, 06:53 PM   #925
rx7ttlm's Avatar
The diameter of the pins are 1.5mm, so it doesn't take much torque to bend them. So to ensure they don't back out you use some shrink wrap to make sure they don't come out and you have 3 wheel drive... not fast I can assure you.
If I recall that was a rolling change so the part should be the same number but with v2 on the package.
Old 12-07-2011, 06:54 PM   #926
rx7ttlm's Avatar
Double post
Old 12-07-2011, 07:05 PM   #927
Thank guys this is my first Xray. Coming from a Tamiya just learning
Old 12-07-2011, 07:19 PM   #928
hanulec's Avatar
Trader Rating: 23 (100%+)
Go to mcmaster.com. find 1.5mm dia pins... you'll have to grind them to length but that is it. Use heat shrink. Again mcmaster.com. 3/8" dia pre shrink.
Use a ton of grease. Buy an extra ecs.. there are parts u cannot buy as replacement (stub axle).
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 12-07-2011, 07:22 PM   #929
hanulec's Avatar
Oh yeah.. get my Nikita outdrives at www.sidepieceracing.com/products/nikita/
Old 12-07-2011, 07:37 PM   #930
Bigz84's Avatar
this is a great idea. I just rebuilt my ecs and did this.
Now the pins will not move and snap.
Radiopost : EA Motorsports : Orca : Reflex Racing/RSD : Wild Turbo Fans : Franchise Racing Products : RCAmerica : Hudy : Xray : Diggity Designs:
Bigz84 is offline   Reply With Quote
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 12:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 05:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-16-2011 11:58 PM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 03:11 PM
