Old 12-07-2011, 05:44 AM   #886
Thanks much for the replies guys. Well it is already done really. My question is, can I tame the motor down 'for now'? I take it that boost is the same as a mod motor? Trying to get used to the acronyms. I plan on really racing around the tennis courts, going to some smooth parking lots etc - that's it for now until I could figure out how she drives.
angelblade is offline   Reply With Quote
Old 12-07-2011, 05:51 AM   #887
morgoth's Avatar
You'll never get it as smooth as a 17.5T. You're car will be a flying projectile with that motor, even with the lowest settings in the ESC. And the stress/wear will be also bigger on you're drive train than with a 17.5t or 10.5t motor
I'd say don't use any timing, set the current limiter to 70% or maybe lower (I don't know if that's an option on the 1/10 ESC's, but I think so).
Use expo on you're throttle channel and turn down the EPA. But I think it's more difficult to gear correctly with a turned down motor than with a normal motor.
I have no clue why the guy of you're LHS suggested a 4.5T for a beginner.
Serpent BeNeLux teamdriver // FX Engines // Nitrolux fuel
My blog: http://scrubbingspeed.wordpress.com
morgoth is offline   Reply With Quote
Old 12-07-2011, 05:57 AM   #888
M-Technic's Avatar
Trader Rating: 15 (100%+)
Originally Posted by RC.Jon22 View Post
Any tips on bleeding the shocks? I've built TRF/AE shocks and they were very simple, but I'm having a hard time building the ones on my 12..And has anyone noticed a huge difference with the aluminum shocks or are the plastic ones preferred?
Drill a tiny hole in the plastic part of the shock cap, then leave the foam out of the cap (between the bladder and the cap). Then you can build the shocks just like Tamiya shocks.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 12-07-2011, 05:59 AM   #889
ByteStream's Avatar
Does the 2012 come with the upper shock caps that have a hole pre-drilled for easier rebound adjustment.
http://www.teamxray.com/teamxray/pro...Name=Composite Shock Parts - Rebound Hole - Short
RCAmerica | Xray | Hudy | KO Propo | Hobbywing HWNA | R1Wurks | BSR Tires
5280 Raceway - www.5280raceway.com
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
ByteStream is offline   Reply With Quote
Old 12-07-2011, 05:59 AM   #890
Thank you. I guess I'm a little surprised too. I think because they know I have been 'over the top' with my other cars, they tried to match my personality. I will have to gather more info from the group on how to tame this thing down big time and go from there. Thanks for all of your help thus far.
Old 12-07-2011, 06:01 AM   #891
M-Technic's Avatar
No, those don't come stock with the 2012. But you can just use the smallest drill bit you have and drill them yourself.
Old 12-07-2011, 06:11 AM   #892
Bigz84's Avatar
Default pistons
Originally Posted by Fred Hubbard View Post
You're welcome
what's the benefit of running larger holed pistons? 1.0 to 1.1
Radiopost : EA Motorsports : Orca : Reflex Racing/RSD : Wild Turbo Fans : Franchise Racing Products : RCAmerica : Hudy : Xray : Diggity Designs:
Bigz84 is offline   Reply With Quote
Old 12-07-2011, 06:59 AM   #893
Fred Hubbard's Avatar
A tad bit more traction in the front and rear.
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 12-07-2011, 07:06 AM   #894
locked's Avatar
I have to ask. Angelblade, what do you plan to use the car for mainly?
By the way.. Boost refers to advanced timing. Blinky refers to zero ESC timing.
Mod motors are motors with less than 10.5 turns.
A 4.5 is very fast and draws a ton of power. It will tend to overheat a Tekin if you run it for more than a few minutes at race pace. Using 2 or more capacitors is recommended to lessen the likelihood of thermalling your ESC. Tekins are awesome for boosting a higher turn motor like a 17.5. They are not an ideal choice for a mod motor. Despite this they offer combos down to 2.5. I never understood why they do that.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 12-07-2011, 07:15 AM   #895
Locked - at first I plan to just run speed runs, etc on the asphault and was hoping I could seriously tame the motor down so I can learn how the xray handles. If you are telling me this thing will overheat the esc out of the box and they sell it as a combo, I am at a loss as well! Do you know if I can tone down the motor big time with this combo? Thanks so much for your explanation of the acronyms. I am doing my best to learn this stuff and it is people like you that are helpful!! If you have any 2 stroke questions, I am happy to return the favor :-).
Old 12-07-2011, 07:26 AM   #896
locked's Avatar
You can tone it down with lowering the endpoint as was suggested above and if you are really gentle on the trigger, you'll be fine. I'm guessing you have a temp gun. Keep it handy if you are going to do a few speed runs. Both the motor and ESC will warm up pretty fast. check the temps often.
a Tekin could probably be used for mod 2wd buggy with a low turn motor and be totally fine. That's probably why they sell those mod combos. 4wd TC tends to be a bit harder on the equipment though.
Dave Locke
Old 12-07-2011, 07:41 AM   #897
got it...so basically lower the throttle endpoint control. Thanks a bunch. I will also add another capacitor just in case and get a few pinions to try out. I do have a temp gun since I use it with my 2 stroke stuff. Thanks a bunch.
Old 12-07-2011, 09:59 AM   #898
Meradin's Avatar
Trader Rating: 19 (100%+)
Running a reduced endpoint will reduce the power sent to the motor making it slower. Not sure if you are prepared to spend more money, or if Tekin even offers them, but you may be able to put a 17.5 stator in the can making it a 17.5 motor. You could then put the 4.5 in for the times you want to open it up and go crazy fast.
Better than Randy, Adam said so!
Second thought...I don't trust Adams, they make up everything!
"Leave it to Steever", custom paint masks, decals, and paint.
Meradin is offline   Reply With Quote
Old 12-07-2011, 10:14 AM   #899
well at this point being about 1500 bucks in, maybe I will just buy a 17.5 ?
Old 12-07-2011, 10:19 AM   #900
My '12 came with the rebound holes in the caps.
Lycan is offline   Reply With Quote
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 12:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 05:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-16-2011 11:58 PM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 03:11 PM
