Old 12-05-2011, 07:48 AM   #841
Regional Moderator
CarbonJoe's Avatar
Originally Posted by silvalis View Post
That servo saver is nasty. My fingers hurt.
Instead of building it as per manual on the small bit w/ the spline adapter, try building it onto the big bit where the ball end holes are. Much easier.
For me, it was easy to build the servo saver. Assemble the front and back halves, then push the "spring" parts up from the bottom, smallest to largest. They "snap" into place. Takes about 15 seconds to assemble that way.
*** The Gate - Celebrating 7 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 12-05-2011, 08:29 AM   #842
M-Technic's Avatar
Trader Rating: 15 (100%+)
Yep, very easy with this method.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 12-05-2011, 09:22 AM   #843
syndr0me's Avatar
Trader Rating: 32 (100%+)
This car is good.
syndr0me is offline   Reply With Quote
Old 12-05-2011, 11:59 AM   #844
orci77's Avatar
Originally Posted by Fred Hubbard View Post
Using any shim between the shock and tower in the front will reduce initial steering and generate more on-power steering. We normally only use the shim at the top and it also serves to make the shock as vertical as possible.
Tried the 2mm shims on tower and arm and it makes the car so drivable. Moves from "agressive and hard to handle" to "total control". Especially the better on-power-steering gives more convidence.
What I dont get: Why does this happen because of the shims?
Xray T3'012 + Nosram Pearl SpecRacing V2 + LRP X12 17,5T / X11 9,5T / X11 6,5T
Team Associated SC10 + Nosram Matrix Reverse + LRP X11 13,5T
3Racing F1-09 + LRP Sphere + LRP X11 17,5T
orci77 is offline   Reply With Quote
Old 12-05-2011, 12:40 PM   #845
morgoth's Avatar
Is the shim on the A arm really needed? I thought I read somewhere that a shim between the shock and the tower was enough.
I have an other question regarding the Ackerman. Does adding shims smooths out the steering and make the car steer a little less?
Serpent BeNeLux teamdriver // FX Engines // Nitrolux fuel
My blog: http://scrubbingspeed.wordpress.com
morgoth is offline   Reply With Quote
Old 12-05-2011, 12:47 PM   #846
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
When you lay down the shocks on the shock tower your changing the lateral angle of the shock, When you add shims to the shock tower your changing the longitudinal angle of the shock. So it also changes the spring and damping rates slightly.
Hope that makes sense.
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 12-05-2011, 01:04 PM   #847
No on both I believe, shocks are more upright when shimmed at the top, shim on the a arm stops this, although if you were to have say 3mm at the top and 1mm at the bottom, you will be making the car even easier to drive as you are increasing the distance the front and rear shocks are away from each other.
Regarding Ackerman, I believe it's increased if you reduce shims, this in turn smoothing out the steering.
Mb3195 is offline   Reply With Quote
Old 12-05-2011, 01:14 PM   #848
morgoth's Avatar
So I can add 1 or 2mm at the top, don't change the bottom and enjoy smoother steering?
I know that the more shims you add, the less ackerman effect you'll get. But I've actually never tested with this.
Old 12-05-2011, 01:33 PM   #849
Fred Hubbard's Avatar
Just between the top of the shock and the tower is what you want.
Yep.
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 12-05-2011, 01:43 PM   #850
liteweight's Avatar
Okay guys anyone have experience on 2012, after 2 days of races the rear toe change without changing the shims, here is the scenario, with the stock asphalt set up the rear toe are -3 deg both left and right , After 2 weekend of race now the rear toe are left -1.5 and right -2.5, I did check the long screws all four are straight, hinge pins both left and right are also straight.
John's Mobile R/C Raceway outdoor racing
"The New Coliseum Carpet Track"
"MRH" Carpet racing
"Xray T3 2012"
liteweight is offline   Reply With Quote
Old 12-05-2011, 02:35 PM   #851
Are you sure you had 3 degrees both sides to start with? Both mr cars have more toe on the right than the left, although it is only about 0.5 degrees different. I tried shimming them to make them the same but didn't notice any handling difference.
Old 12-05-2011, 03:07 PM   #852
liteweight's Avatar
Actually it is less than -3 deg both left and right, but my concern now is after 2 weekend the left is -1.5 and right is -2.5 degree, so you saying i have to put extra 1mm shimm on rear left to make to 2.5, are everyone doing this ?
"MRH" Carpet racing
"Xray T3 2012"
Old 12-05-2011, 03:42 PM   #853
haywood's Avatar
Trader Rating: 48 (100%+)
Did you break a rear hub and put on a 1 degree hub on one side?
Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 12-05-2011, 04:03 PM   #854
liteweight's Avatar
I dont break anything on the car, im still using the 0 deg that comes with the kit
"MRH" Carpet racing
"Xray T3 2012"
Old 12-05-2011, 04:09 PM   #855
liteweight's Avatar
I already put 1mm shimm on the left rear to make it 2.5 deg but it look ugly
"MRH" Carpet racing
"Xray T3 2012"
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 12:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 05:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-16-2011 11:58 PM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 03:11 PM
