Old 11-29-2011, 06:58 PM   #766
ghoppa's Avatar
Trader Rating: 48 (98%+)
Originally Posted by R3VoLuTiOn View Post
I have almost no side to side play with the battery, just front to back.
the xray alum battery holders dont bend like the composite, and then you can just add some foam servo tape between the holder and lipo to eliminate the play front to back.
the aluminum lipo holders are dialed, I suggest a lil piece of fuel tubing on the ends of them if you have "east/west" play at all, I have no "north/south" play with the aluminum lipo pieces..
DIALED!
RCAmerica - Team Trinity - Xray - Revtech - Jgo Paintz
Hobbywing - Hudy - Futaba - P-1 Brand - 702 RC Raceway - ActivRC
ghoppa is offline   Reply With Quote
Old 11-29-2011, 07:03 PM   #767
Bigz84's Avatar
Trader Rating: 15 (100%+)
Originally Posted by zaraz View Post
anyone
according to the manual, yes, you might need to add spacers for certain Lipos
Radiopost : EA Motorsports : Orca : Reflex Racing/RSD : Wild Turbo Fans : Franchise Racing Products : RCAmerica : Hudy : Xray : Diggity Designs:
Bigz84 is offline   Reply With Quote
Old 11-29-2011, 07:17 PM   #768
Bigz84's Avatar
for the front do you use 50 or 52 mm ecs units, about to order the shafts so just want to make sure
either. I'm running the 52s. you can run the 50s, but add a 1mm spacer between the adapter and the axel. running the 50s can cause the adapter to break because the ecs pin is not sitting far enough in the adapter. I went thru countless adapters until i read about this mod of the 1mm spacer, OR you can run the alum adapters and not worry about the plastic adapter breaking
Old 11-29-2011, 07:26 PM   #769
entitymugenmtx's Avatar
Trader Rating: 81 (100%+)
Send a message via AIM to entitymugenmtx
DIALED!
Nice I like that
SPONSORS.....MY CHECKBOOK....
entitymugenmtx is offline   Reply With Quote
Old 11-29-2011, 07:29 PM   #770
hanulec's Avatar
Trader Rating: 23 (100%+)
or you can just buy some serious outdrives instead -- Side Piece Racing Nikita Outdrives
http://sidepieceracing.com/products/nikita/
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 11-29-2011, 07:56 PM   #771
Bigz84's Avatar
huh, nice.....
never seen or heard of these before....
look good, if i go back to a spool, i might look into these
Old 11-29-2011, 08:38 PM   #772
I just got a set of nikita outdrives. Running fairly narrow, 1.5 spacers, 52mm ESC drive shafts and still have room in the outdrives to go narrower.
Also the large diameter is less wear and tear on the blades, have two races days on mine and the blades still look new.
Definitely a high quality product.
malkiy is offline   Reply With Quote
Old 11-29-2011, 10:12 PM   #773
Send a message via AIM to ruknd
what is the pinion range people are using for indoor carpet with the stock 84/48 spur and 17.5 blinky. Thanks.
Kip-Back from the Hiatus
TLR 22 Tekin RS Pro/XXX-T/MF2 CRC conversion Tekin RS/XRay T3 2012/Tamiya M06 S-Spec/HPI Savage big block/Mini-zs/helis and planes
Futaba 4pks Spektrum DX7
ruknd is offline   Reply With Quote
Old 11-29-2011, 10:30 PM   #774
orci77's Avatar
Originally Posted by FLAT OUT View Post
Ive been running the kit 750 cst oil so far. Im racing 13.5 on carpet at the moment. Im wondering what every one else is using. So far the car has been hard to drive consistantly.
I started with the 700cst too. My friend runs 1000cst and last weekend I tried 2000cst. Works also but I must admit I didnt feel the difference because we were on a different track.
Xray T3'012 + Nosram Pearl SpecRacing V2 + LRP X12 17,5T / X11 9,5T / X11 6,5T
Team Associated SC10 + Nosram Matrix Reverse + LRP X11 13,5T
3Racing F1-09 + LRP Sphere + LRP X11 17,5T
orci77 is offline   Reply With Quote
Old 11-30-2011, 01:58 AM   #775
Jeez, how hard are you crashing I've done thousands of laps, had quite a few heavy hits, only ever broken or bent one thing on the Xray (rear hub carrier and that was only because a track fixing had come loose and caught the rear axle nut) never had a problem with the batteries moving or retainers bending.
Perhaps you guys need some better quailty tape?
Bb
bucketboy is offline   Reply With Quote
Old 11-30-2011, 02:04 AM   #776
I run 1000 or 2000 depending on track conditions, lighter makes the back end rotate faster, heavier calms it down.
BUT unless you put exactly the same amount of oil in the diff you may not notice any difference (too much thin oil make it feel thick, too little thick oil makes it feel thin)
Bb
Old 11-30-2011, 09:29 AM   #777
Thanks for the picture of the fuel tubing on the battery brackets. That along with larger nylon nuts took all the battery movement out of the car.
Old 11-30-2011, 09:33 AM   #778
pcar951's Avatar
Trader Rating: 19 (100%+)
Bb
+1
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy | Reds Racing
pcar951 is offline   Reply With Quote
Old 11-30-2011, 10:58 AM   #779
Warren Weaver's Avatar
Trader Rating: 43 (100%+)
Originally Posted by Fred Hubbard View Post
I thought I read a short while ago that the Corally motor wasn't made to the same specs as other 17.5 motors? I know it's not on the ROAR approved list. Someone correct me if I'm wrong.
What up Warren, good man and you?
Iam doing great love the car cant wait to race it again.
talk to you soon
warren
R1 WURKS-AWESOMATIX USA-LRP-TQ WIRE-PROTOTYPE RACING-MCFACTORY MOTORSPORTS-SWEEP RACING-TXDSKINGRAPHIX-HOBMAX-THE RUG-TEAM EZDUZIT
R.I.P. MY FRIEND JDUB MISSED BUT NEVER FORGOTTEN
Warren Weaver is offline   Reply With Quote
Old 11-30-2011, 11:09 AM   #780
Xpress's Avatar
These are another option...
flyingfoxrc.com
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 01:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 06:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-17-2011 12:58 AM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 04:11 PM
SEO by vBSEO 3.5.0
