Old 11-22-2011, 07:21 PM   #631
dr_hfuhuhurr's Avatar
Trader Rating: 70 (100%+)
Originally Posted by starrx View Post
is this blake??
if not im sorry
Sure is.
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is online now   Reply With Quote
Old 11-22-2011, 07:27 PM   #632
mazmorbid's Avatar
Trader Rating: 9 (91%+)
Originally Posted by theatriks View Post
You still woundnt have that number would you lol just in case
Check your Inbox
Xray XB9 - Xray XB808 2011 - Novarossi - J.R. - Futaba - Ascendancy - Pro-Line
mazmorbid is offline   Reply With Quote
Old 11-22-2011, 07:47 PM   #633
entitymugenmtx's Avatar
Trader Rating: 81 (100%+)
Send a message via AIM to entitymugenmtx
Anyone using silver HPI springs for there 2012 T3 ?
SPONSORS.....MY CHECKBOOK....
entitymugenmtx is offline   Reply With Quote
Old 11-22-2011, 10:00 PM   #634
nerdling's Avatar
Originally Posted by dr_hfuhuhurr View Post
I can understand all of these but Rear Belt? Really?
Yes, I snapped a belt at FEMCA a few weeks ago and a mate has gone through several. Caviet though, we are running mod.
I'm in the process of slowly building my kit. Oh how I missed sanding and sealing graphite. It's been too long!
Me too. I'll sanding and gluing bits to myself on Friday
--XRAY--NOSRAM--PROTOFORM--MUCHMORE--
www.teamxray.com -- www.hudy.net -- www.hobbyexpress.com.au
nerdling is offline   Reply With Quote
Old 11-22-2011, 11:01 PM   #635
pcar951's Avatar
Trader Rating: 19 (100%+)
Drove the 12 for the first time at our carpet track tonight. It brought back memories of the first time I drove my T2... Smooth, stable and predictable, like everyone says, the kit carpet setup is very close too. Good job Xray!
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy | Reds Racing
pcar951 is online now   Reply With Quote
Old 11-22-2011, 11:41 PM   #636
Zainy's Avatar
Default Rebound Set
Hello guys,
I'm new in using Xray kit, for asphalt track how you guys set the absorber
rebound ? 100% , 50% , 25% or 0%.
Need to drill 1mm hole at the absober cap ?
Zainy is offline   Reply With Quote
Old 11-23-2011, 03:26 AM   #637
Sure is.
wow! its been along time..this is von..if you remember me
starrx is offline   Reply With Quote
Old 11-23-2011, 07:14 AM   #638
yokemad's Avatar
100% Agree with you!
yokemad is offline   Reply With Quote
Old 11-23-2011, 07:20 AM   #639
Hi All
Quick, and probably basic question about this car (and also other cars). When you remove shims from underneath the ball stud on the inside of the camber link (so the bit that screws into the bulhead clamp) are you lowering or raising the roll centre?
Mark
Bony85 is offline   Reply With Quote
Old 11-23-2011, 07:23 AM   #640
Originally Posted by Bony85 View Post
Hi All
Mark
Lowering the ball studs on the clamps will raise the roll centre.
Mb3195 is offline   Reply With Quote
Old 11-23-2011, 07:24 AM   #641
Mr. MR4's Avatar
Hi, lately i have been using hpi (front) pink or silver and (rear) blue. The car felt better with these on asphalt.
The xray springs feel like that the car has more grip though.
Xray T4'16 HobbyWing Xerun 120A V3.1
Xray X1'16 HobbyWing Justock
Yokomo R12C3 HobbyWing Xerun V3.1
Mr. MR4 is offline   Reply With Quote
Old 11-23-2011, 07:32 AM   #642
pretty common here in the uk now, pretty much what most people run on carpet also.
Old 11-23-2011, 07:41 AM   #643
Before I go too crazy, building the front end, the arms front and rear are not dropping freely. I have only the arms on now. When the screws are tightened they bind up. Now the arms move freely on the hinge pins so that is good, there's just some binding between the hinge pin holders and the arms. My building experience tell me to lightly sand (2000 grit) the ends of the arms till they move freely. Any other methods? or am I doing something wrong?
Sorry for the newbie-ish question...just been a while.
Old 11-23-2011, 08:02 AM   #644
HarryLeach's Avatar
Send a message via AIM to HarryLeach
I had a similar issue building my 2011. Before you start sanding anything, try loosening each screw until the arm drops freely, then slowly tighten each screw a half turn at a time, making sure the arm holder doesn't twist. Might take a few attempts to get the feel for it, but you should be able to get everything tightened up with all the suspension arms moving freely.
Seems like once the car gets a bit of track time on it, removing the arm holders to adjust shims and such either make any binding less of an issue, or just go easier because you can do it without thinking about it.
Privateer racing lots of stuff.
Remember kids, racing isn't fair!
HarryLeach is offline   Reply With Quote
Old 11-23-2011, 08:17 AM   #645
ChrisP's Avatar
Send a message via Yahoo to ChrisP
You may also try the build tip of tapping the arms lightly with a screwdriver handle in order to ensure that the holders are seated properly square to the arm....
http://forum.teamxray.com/viewtopic.php?f=8&t=2872
TeamXray.com
Team Tekin
ChrisP is offline   Reply With Quote
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 12:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 05:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-16-2011 11:58 PM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 03:11 PM
