Old 11-16-2011, 04:36 AM   #511
Originally Posted by entitymugenmtx View Post
I just added the rear upright to the lower arm and contected it the rear diff, when I pull up the lower arm it only goes up half way, I don't know if this is nomal for a Xray?
i think you will find it is the ball joints on the camber links that are binding up. Although it could also be your driveshafts binding against the cups. THe easiest way to find out is to take the driveshafts out and see if it still does the same.
Mb3195 is offline   Reply With Quote
Old 11-16-2011, 04:46 AM   #512
dr_hfuhuhurr's Avatar
Trader Rating: 70 (100%+)
Just getting back into TC after a LONG absence from 10th scale. My last TC was a T1FK05. Thanks to the new track in New Rochelle, NY I'm VERY happy to be getting back to carpet racing.
I have a few questions about building and setup of the new car.
Which 64p spur gear for 17.5 Blinky class?
Which servo? Futaba and KO servos is what I've always used, but it looks like there are a few new players out there now. I was thinking the Futaba BLS551 (Mid Profile). Would a mid profile servo or standard servo be better for the car?
Sorry for the basic questions...SO glad to be back with an XRay though. The kit quality can't be beat!
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 11-16-2011, 05:26 AM   #513
Futaba S9551 is as good as any out there, standard size servos are a bit of a no no now in touring cars.
Why 64dp? Not really needed, especially in blinky class.
Old 11-16-2011, 05:34 AM   #514
jgraham37128's Avatar
Trader Rating: 24 (100%+)
The rear has 3 degree toe and the camber I don't know yet Im going by the manual book setting.
The rear drive shafts are too long. You'll need to add a spacer to the front of the rear arm or change the axles out to 50mm (which is what I did).
JG
jgraham37128 is offline   Reply With Quote
Old 11-16-2011, 05:36 AM   #515
74VWTECH's Avatar
Trader Rating: 19 (100%+)
I'm currently using a 96 tooth 64 pitch in blinky 17.5 with a 43 tooth pinion. my track size is 100ft x 40ft. hope that helps. you may have to shave alittle of the top plate near the motor to get the proper gear mesh depending on the motor.
Fantom Racing * CB's Custom Cut Gears * 92zero Designs * Stiky Liks Racing Concepts * Leisure Hours Raceway * Trackside * Race'em RC
SC5M, B6, T5M, T4'15 & X1
74VWTECH is offline   Reply With Quote
Old 11-16-2011, 06:04 AM   #516
M-Technic's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Con View Post
Did anyone drill a hole in the shock caps? Or just left them alone.
I drilled a hole in the cap and left the foam out. Then when you build the shocks like they were Tamiya style shocks, you can get 0 rebound easily.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 11-16-2011, 06:28 AM   #517
Riketsu's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to Riketsu
Hey guys, what battery pack you guys running???
I am coming back to electric TC after a few years and after doing some little research, I have only seen Team Orion with a 90C.
I'll be running 17.5 with a Tekin ESC. Should I bother with the 90C or will a 60C be more than enough??
eBay user id: riketsukirai
Selling all my MTX4 parts, bodies, radio and everything!
Riketsu is offline   Reply With Quote
Old 11-16-2011, 06:31 AM   #518
Con
Thank you
Con is offline   Reply With Quote
Old 11-16-2011, 06:44 AM   #519
Default binding rear dogbone...
Your issue is expected. The arm will never travel that far when you drive because the shock cannot compress that much. If you have the recommended 1.5mm aluminum spacer between the aluminum bulkhead and the rear hinge pin mount, you should be fine. As long as you have toe in from the rear tires. Without the toe, you need the 50mm axles, otherwise you don't.
BTW, ran the 2012 last night. Im so impressed. I have spent months tuning my other touring cars and this baby was so balanced and locked in that I don't think Im changing the set-up. UNREAL
photopro is offline   Reply With Quote
Old 11-16-2011, 06:56 AM   #520
303slowdown's Avatar
Don't let the orion 90c fool you. It meens 90c burst most other batteries don't list their c as burst they list as constant. I'm using both revtech 65c and thunder power 65c and really like them both
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 11-16-2011, 06:58 AM   #521
Team EAM
EAMotorsports's Avatar
Trader Rating: 77 (100%+)
Send a message via AIM to EAMotorsports
The Orion packs say 90C but are no where near that. When you go to a large on-road race you rarely see Orion packs. In off road you see them a bit but its because thats mostly where all their paid factory drivers run.
Personally I would stick with the ReVtech, OHP, SMC, CRC, TP packs. Those are some of the best and most reliable in the industry.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID.
EAMotorsports is offline   Reply With Quote
Old 11-16-2011, 07:12 AM   #522
Riketsu's Avatar
Thanks for all the quick responses guys, really appreciate it.
Usually when something seems too good to be true, its because its not and theres probably a catch. And this wasn't the exception, just didn't know what it was.
Old 11-16-2011, 09:11 AM   #523
sham55's Avatar
Default hello all ... ^_^
just wondering if u guys have the same problem as mine ... the problems is that the rear toe is not the same left & right, the right i got 3 deg. toe in and left i got 3.5 deg. toe in, is anyone have the same problem as i in the t3'12 ??
sham55 is offline   Reply With Quote
Old 11-16-2011, 09:43 AM   #524
R3VoLuTiOn's Avatar
Trader Rating: 26 (100%+)
now that you mention it, my right was 3.5 and left at 4 degrees lol.
i should look into that...
John Tsang 🏁 VBC Racing 🚗 ORCA RC 🚗 GripworksRC 🚗 MotivRC 🚗 GravityRC 🚗 RC America
http://www.facebook.com/VancouverRRR 🏁 http://www.facebook.com/OvergearedRacing
R3VoLuTiOn is offline   Reply With Quote
Old 11-16-2011, 09:44 AM   #525
Con
Yep me too. I put a 1.10 shim in the left side intsead of the 1.50 shim to compensate.
Seems to have been a problem since the T3 '10.
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 12:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 05:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-16-2011 11:58 PM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 03:11 PM
