Old 02-23-2015, 05:33 PM   #4201
Essnowyt's Avatar
Send a message via AIM to Essnowyt
Originally Posted by Troy Carter View Post
Essnowyt's setups will be solid and should be up to date. I believe he just moved from the 2012 car earlier this year.
Originally Posted by Cain View Post
I was advised to use some of the setups that Essnowyt had on xray's site and they look good in comparison to what I am using for USGT and VTA, my two setups there I beleive are close.
Who is this Essnowyt character? Oh, wait. Troy and Cain, thank you for the kind words.
I am glad you guys are looking to the setups I posted. Please note, the older ones for the T3'12 have X-Pattern tires. Those may not work so well with the Gravity tires. The only time I ran the 12 with those tires was at Summit last year, Feb 2014. Truth be told, I was not happy with the car. Cain messaged me a few weeks ago and asked the USGT question. After looking at the setups and thinking a bit, I made a new sheet of ideas. I think this would work well for both VTA and USGT. I have not tired this, but it is from my T4'14 USGT and I made it fit the 12.
http://forum.teamxray.com/xform/inde...&setup=t3_2012
If I can help, please let know.
Snowy.
Team XRay, RCAmerica, Motiv, Gravity RC, Schacht Design Works.
Drive it, Dont slide it!
Essnowyt is offline   Reply With Quote
Old 02-24-2015, 06:51 AM   #4202
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
how much do you think your setup would change if you made the vehicle legal for USVTA, especially if you left the vehicle weight at USVTA levels, but mainly did say a tire and motor swap?
As I use my daughters USVTA vehicle when its just me going to races, i turn my USVTA vehicle into a USGT one with a motor, tire, and body swap.
Also, what do you feel are the best spur gears to use to get access to that back motor screw?
Finally, one of my vehicles came with a floating servo setup, but it seems to just move all the time to the point hat I got tired of it and in combo with the floating servo I servo taped it to the chassis, as my daughters uses the two posts on the chassis my chassis and some spares don't have that "outer post" location.
I wonder if I am doing something wrong with how I got it together but I don't see another location to the inner mount point to secure it to, just the steering arm location and the servo post location on the inside, thats it, but you can see it flexing around enough that my steering would be all messed up on any impacts.
Any ideas?
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 02-24-2015, 07:03 AM   #4203
Trader Rating: 20 (100%+)
The floating mount on the 2012 car was a bit "flexible" and would move in a big impact. I found I had to run a servo saver with it and had to be sure it was tight, really tight. Once it was set it stayed pretty well but it's definitely something to watch.
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 02-24-2015, 07:17 AM   #4204
Tech Legend
Cain's Avatar
cool thanks for the heads up. Yeah personally with it moving like it was would just prefer it to stay lol.
Old 09-23-2015, 11:17 PM   #4205
Question for you T3/T3R owners, is this a competitive mode model against the new T4 model, i bought a T3 when it first came out and I was gonna upgraded with the carbon fiber item and shocks to make it a T3R but life happen and my RC fun had to be put on hold.
vochito is offline   Reply With Quote
Old 09-24-2015, 07:46 AM   #4206
Your T3 can be competitive, with the proper set-up and good driving.
Goal Achieved....Not Dead Last.
mooby64 is offline   Reply With Quote
Old 09-24-2015, 09:20 AM   #4207
So am assuming it's not that out dated
Old 09-24-2015, 06:24 PM   #4208
nova2015's Avatar
I'm using my T3'12 in VTA, and found it responded well to removing both sway bars and using a very soft setup. It gives good weight transfer particularly to the front during cornering.
nova2015 is offline   Reply With Quote
Old 09-25-2015, 11:23 AM   #4209
Tech Legend
Cain's Avatar
yeah, I really liked how the car felt and its pretty durable too.
I am thinking of making the switch to 1/12 so if anyone wants one or two of these ready to go feel free to hit me up.
Old 10-12-2015, 04:32 AM   #4210
Fast XXXS's Avatar
Trader Rating: 48 (100%+)
Hi guys, Just picked up a T3'12. Looking at running in 21.5 and then moving to 13.5. Question i have are- To get the low gearing for 21.5 blinky, what aftermarket spur gears will fit the T3'12? also I'm looking at getting around a 3.0 FDR, is it possible to fit a 65 spur with a 40 pinion? Also does anyone know if the T4 bumper will fit the T3.
Fast XXXS is offline   Reply With Quote
Old 10-12-2015, 04:17 PM   #4211
Brokin Racing's Avatar
Trader Rating: 68 (100%+)
Hi,
Yes, you can go that low but then the problem is doing up the back motor screw, no biggie though
RW do an excellent Xray compatible spur, I have a 64t 48p if you'd like to try it, no charge.. PM me you address (we've traded before)
T4 bumper should fit but why? there is no benefit & gives you less protection
Xray - LRP - PF - Futaba -
Brokin Racing is offline   Reply With Quote
Old 10-12-2015, 05:05 PM   #4212
Fast XXXS's Avatar
Originally Posted by Brokin Racing View Post
Hi,
Ok awesome no worries. I'll send you a PM. As for the T4 bumper only reason is where I'm ordering all my bits from (not just xray bits) they only have the T4 bumper in stock. So saves doing just an order for a bumper from somewhere else.
Old 10-13-2015, 07:59 AM   #4213
Tech Legend
Cain's Avatar
yeah finding spur gears that have big openings can be a godsend when trying to get the motor screws tightened down.
other than that, great car.
Old 10-13-2015, 10:21 AM   #4214
An easy work-around, for the motor screw issue, is to make a slot, on the lower side of the motor mount. Google the Associated TC6 motor mount. With this, I am able to run as small as 82t 64p
Old 10-19-2015, 12:39 AM   #4215
Yes, similar to an early ARC
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 12:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 05:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-16-2011 11:58 PM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 03:11 PM
