Old 05-19-2013, 08:23 PM   #4111
Josh-n-ya's Avatar
Trader Rating: 75 (100%+)
Originally Posted by PROMODVETTE View Post
Got to run mine yesterday. Didn't do so well.... my rear toe with the 2.5 degree mounts come to 0 degrees. Why? I have no idea. Everything is put together correct. I'm fairly sure both arms/hubs aren't bent to make this thing off exactly the same on both sides. Summer semester starts tomorrow so I will just have to deal with it when I can.
Were you running on carpet or asphalt? Care to put a setup sheet up on xray or whatever of what you ended up with?
Sounds like you did what he said! I am running on asphalt! I am also running another C mount in rear and using the xb i think holders in front. It makes the whole rear end narrow. Play around with the mounts and you will get it to work. I blew a motor today also got bumped around. Wasnt such a great racing day but still so much better with exotek chassis!
Originally Posted by CarbonJoe View Post
Sounds like you have the left and right mounts on the wrong sides, so that the 2.5 degrees undoes the built in toe from the bulkheads/shims.
Josh-n-ya is offline   Reply With Quote
Old 05-20-2013, 08:54 AM   #4112
Trader Rating: 57 (100%+)
Yep you guys were right. The instructions werent very clear! The XB is supposed to be on the inside.
PROMODVETTE is offline   Reply With Quote
Old 05-20-2013, 04:54 PM   #4113
Josh-n-ya's Avatar
Instructions!!! Thats your problem. You were reading instructions!!!
Old 05-20-2013, 08:28 PM   #4114
Haha thats a fact.
Old 06-04-2013, 08:04 PM   #4115
Hey Guys I wanted to try and give the front wheels more power than the rear wheels. So I purchased the 16T pulleys and I was going to put them on the layshaft for the rear to give the rear wheels less power .... but this wouldn't work will it because the rear wheels will just be spinning as they wont be travelling at the same speed as the front wheels? I would be right in assuming this wouldn't I.
Pulpetti is offline   Reply With Quote
Old 06-04-2013, 08:25 PM   #4116
Josh-n-ya's Avatar
Why do you want to do this?
Old 06-05-2013, 05:33 AM   #4117
I want to send more power to the front wheels than the back wheels
Old 06-05-2013, 05:56 AM   #4118
Skiddins's Avatar
Yes, you've said that already, but what people are asking is why?, what are you trying to achieve?
More power out of corners, drift car etc?
People used to achieve overdrive or underdrive by making the pulleys 1 tooth different either at the spool or diff, not 4 teeth at the centre pulley.
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 06-05-2013, 10:37 AM   #4119
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Pretty sure belt fitment would be an issue. I'd try solving whatever problem you're having some other way.
Old 06-05-2013, 12:25 PM   #4120
I would try adjusting a little more tension to the front belt and less to the rear for more "pull".
nubie-wan is offline   Reply With Quote
Old 06-05-2013, 07:41 PM   #4121
Thanks for all the reply's. There wasn't really any reason I just wanted to try it and see how it went. I'm pretty new to the competitive touring cars. Thanks for your comments ill try tensioning them differently that seams like the more logical approach
Old 06-11-2013, 05:43 AM   #4122
Has anyone tried the progressive springs 308383? They come with the T3R. I thought progressive springs were supposed to be better? the T3 progressive springs are $11 a pair these are $11 for 4. Should I just buy the 308372's?
Thanks in advanced
Old 06-24-2013, 10:25 PM   #4123
tormentus's Avatar
Hi Guys,
Can anyone please help with a CRC carpet setup sheet as I am running at the AOC in 2 weeks and really need to find a good starting point. Its the 1st time I'll be racing on carpet and really would like to get my hands on a good starting point.
Really appreciate it if you guys can help?
Cheers
Wainbow.
tormentus is offline   Reply With Quote
Old 06-25-2013, 01:25 AM   #4124
Skiddins's Avatar
Originally Posted by tormentus View Post
Hi Guys,
Cheers
Wainbow.
Might want to try the CRC thread
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 07-28-2013, 12:14 PM   #4125
Bigz84's Avatar
Trader Rating: 20 (100%+)
Default more flex
if I remember correctly, were people removing the screw that connects the motor bulkhead and the motor bulkhead holder? it is the counter sunk head screw that is on the motor side of the bulkhead.
this gives the car more rear flex, correct?
were people removing the screw for the stock class, or is it wise to do it in 13.5 or in mod class.
I have a 4.5 in the car now, w/ 48 pitch gears. i'm kinda of thinking w/ 48p gears, the extra flex would be OK.
I thought I would ask before I tested.
thanks for any input.
Airtronics/Sawna : EA Motorsports : Orca : Reflex Racing/RSD : Wild Turbo Fans : RCAmerica : Hudy : Xray : Diggity Designs : Team Scream Racing
Bigz84 is offline   Reply With Quote
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 12:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 05:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-16-2011 11:58 PM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 03:11 PM
