Old 05-12-2013, 10:20 PM   #4096
Josh-n-ya's Avatar
Trader Rating: 72 (100%+)
Originally Posted by rcguyfpr View Post
someone mentioned my name? exotek '12 was good..... until you drove a T4. LOL
I will drive yours this weekend!
Josh-n-ya is offline   Reply With Quote
Old 05-13-2013, 05:48 AM   #4097
Trader Rating: 57 (100%+)
I ended up getting the conversion. I hope to run it Wednesday! There were some issues between the conversion and the stock '12. The servo mount on the conversion is in the wrong (old?) place. So I had to redrill/countersink a new hole for the floating mount to work. The instructions also asked for the rear pivot pins to be moved to the front, but again this was not the case and the stock front pins worked fine. The tamiya style mounts are great though! Maybe xray will look into these into the future designs. Seems to make it easier, stronger, and much more free than the stock version.
PROMODVETTE is offline   Reply With Quote
Old 05-13-2013, 09:02 AM   #4098
Has anyone not sponsored by Smokem tried the Smokem MX T3 chassis? I want to know if it's worth the money. What was your experience with it?
Thanks,
Oliver
DOTMAN is offline   Reply With Quote
Old 05-13-2013, 10:28 PM   #4099
Josh-n-ya's Avatar
Had some issues myself with the kit! The battery terminals sit to close to the top plate ( I got the Exotek one) so i had to order the Exotek battery brace. I hope it pushes the battery out a bit more. Its still in the mail. Stock carbon fiber xray floating servo does not fit( I made my own for right now). I ordered a CSO floating servo holder. I hope that fits now that you said that. In all I still like the kit. I am happy I dont have to deal with those plastic pin holders and the screws I was bending and breaking. I was always wandering why my car felt tweaked untill teardown and finding screws bent and arms binding.
Old 05-13-2013, 10:46 PM   #4100
I went straight with the exotek battery brace. I believe I have it out all the way and its still very close, not touching but close! I found it funny though, the center brace that comes in the battery kit doesn't fit on the exotek chassis!
Old 05-13-2013, 10:55 PM   #4101
Josh-n-ya's Avatar
My friend whos car I was copying had the exotek battery brace. I just thought the stock ones would work but not happening. So you havent tried yet? I am going this weekend.
Old 05-13-2013, 11:16 PM   #4102
No haven't got to try the car yet. If my ESC comes early enough on Wednesday I will be trying it then, if not I will go up on Friday and give it a go!
My issue (reason for switching) was breaking the xray chassis. I broke 1 on a pretty hard hit where the tire cought a corner and just ripped it apart. At the rear where the alignment hole is for the rear 1 piece hangers (the one we don't use) it spit right there. Then got a brand new chassis, sealed it polished it etc. Less than 3 runs later that one was splitting in the same place! NO major hits either!
Old 05-14-2013, 07:01 AM   #4103
Josh-n-ya's Avatar
Wow! havent heard of any people in my area breaking any chassis, not even top plates. High speed pavement!
Old 05-16-2013, 10:34 PM   #4104
Josh-n-ya's Avatar
PROMODVETTE: So whats the word? How did it go? I got the exotek battery holders and it worked fine and yes my center battery support had wrong holes. It says that those braces are for the 2011 model. Also got my CSO floating servo holder. I got the T4 light weight version and drilled another hole behind the last hole. It made it alot more solid than using the elongated hole in front, but I did put a screw in fist hole too. So three screws! Its been a long week waiting to run this thing.
Old 05-17-2013, 01:04 PM   #4105
Default flex chassis
Guys, What do you think about the VBC-CRC chassis kit? I was looking at that or the Exotek flex chassis. I'm converting my 11 to east west steering like my 12 and am thinking I should go to the chassis kit and cure several problems of Kansas sun on pavement
btrukr is offline   Reply With Quote
Old 05-17-2013, 02:17 PM   #4106
Wasn't able to make it Wednesday something else come up and I wasn't able to get by in time I have something to do tomorrow afternoon, but I'm hoping to get to the track in the morning as soon as it opens at 10am! I really don't have anything to compare it to, my last attempts were still on a fairly green track and 10.1 was quick. Now 9.7 is quick. If I'm close to that I would say this thing works
Old 05-18-2013, 10:23 PM   #4107
Josh-n-ya's Avatar
Ran mine in practice today for first time. I like it alot! Ran it short with all spacers placed in front hinge pins and rear hinge pins. Had to get a new body cause wheel wells would be cut way back and would look funny. In all car was very smooth. Tomorrow is race day and will get to see how it does. All the guys racing Reedy are here so there will be more competition than normal guys.
Old 05-19-2013, 01:08 PM   #4108
Got to run mine yesterday. Didn't do so well.... my rear toe with the 2.5 degree mounts come to 0 degrees. Why? I have no idea. Everything is put together correct. I'm fairly sure both arms/hubs aren't bent to make this thing off exactly the same on both sides. Summer semester starts tomorrow so I will just have to deal with it when I can.
Were you running on carpet or asphalt? Care to put a setup sheet up on xray or whatever of what you ended up with?
Old 05-19-2013, 02:04 PM   #4109
Regional Moderator
CarbonJoe's Avatar
Sounds like you have the left and right mounts on the wrong sides, so that the 2.5 degrees undoes the built in toe from the bulkheads/shims.
*** The Gate - Celebrating 7 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 05-19-2013, 04:11 PM   #4110
Bigz84's Avatar
Trader Rating: 15 (100%+)
Default asphalt set up
curious to see anyones setup on a semi-prepped asphalt setup, running mod rubber. running at toledo ohio
the car felt ok, and i have made adjustments since my 1st run. i really didn't have rear traction, (maybe too much front traction?). my next race is this weekend and if i could see some others setups, i'd like to see if i'm in the right direction.
i started w/ the base setup, and have gradually moved away
to help the rear, i have gone to the 2nd hole for the link, laid down the rear shocks, and added a spacer under the rear inside link. i also have put on the thinner top deck. i plan on running new Sorex ashaplt 32s, which i hope this setup makes a huge difference in traction.
set me see what others have run...
thanks
Radiopost : EA Motorsports : Orca : Reflex Racing/RSD : Wild Turbo Fans : Franchise Racing Products : RCAmerica : Hudy : Xray : Diggity Designs:
Bigz84 is offline   Reply With Quote
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 12:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 05:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-16-2011 11:58 PM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 03:11 PM
