Old 04-06-2013, 10:02 PM   #4081
Trader Rating: 57 (100%+)
Has anyone run the exotek conversion on carpet? I was wondering how this worked on carpet since it is 2.25mm vs the 2.5 that I have been running.
PROMODVETTE is offline   Reply With Quote
Old 04-09-2013, 09:18 AM   #4082
442paul's Avatar
I've got a bit of play in my steering and it seems to get worse at full lock.
Anybody got ideas on how to solve this, or should I just not worry about it?
I'm 15, I have time to improve on this lol.
442paul is offline   Reply With Quote
Old 04-09-2013, 09:37 AM   #4083
Skiddins's Avatar
How much play?
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 04-09-2013, 12:17 PM   #4084
442paul's Avatar
Originally Posted by Skiddins View Post
How much play?
It feels like quite a bit, maybe 3-4mm?
Old 04-27-2013, 09:23 AM   #4085
KREATOR1's Avatar
Send a message via Yahoo to KREATOR1
a bump
KREATOR1 is offline   Reply With Quote
Old 05-09-2013, 10:48 AM   #4086
rcguyfpr's Avatar
Trader Rating: 29 (100%+)
Question about the anti-roll bar. No matter what I do to the mounting set screws or adjusting the set screws by the end of the bar, left and right just have uneven reaction. All arms go up&down freely. However, when lift up left, right will come up; but life up right, left only moves a little (shocks off).
Front 1.4 and rear 1.2 bar, similar case. How do I fix it? thanks!
rcguyfpr is online now   Reply With Quote
Old 05-10-2013, 12:02 AM   #4087
Trader Rating: 20 (100%+)
Something is off with the suspension. One side has a slightly bent pin, a ball cup dragging, droop screw dug into the chassis, bent sway bar, something must be slightly off. It doesn't take much to have this happen at all and often the arms will look very free but if you look hard enough you'll find something just a bit off.
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 05-10-2013, 08:08 AM   #4088
Had the same problem, and when I was on the straight the car wouldn't go straight. Checked everything that day and couldn't find it, when I got home I was determined to find it. After 10-15 minutes and taking things apart the conclusion was the spool outdrives were loose, the screws were backing out and now it's fine
JOE SI is offline   Reply With Quote
Old 05-11-2013, 03:19 AM   #4089
Is there any upgrade from the T4 that you would recomend for the T3. It drives great but it might get even better. I was thinking about putting on the t4 steering.. So is it worth it and will it fit?
magnushedqvist is offline   Reply With Quote
Old 05-11-2013, 03:27 AM   #4090
Con
It won't fit...the rack is wider
Con is offline   Reply With Quote
Old 05-11-2013, 07:24 PM   #4091
Trader Rating: 72 (100%+)
Default shorty batt
Have any of you guys tried to rebalance your car with a shorty in the rear and the esc in the front?? Chris
btrukr is offline   Reply With Quote
Old 05-11-2013, 07:41 PM   #4092
I have been curious about this conversion too. Have not heard anything about it either.
racer robert is offline   Reply With Quote
Old 05-12-2013, 07:37 PM   #4093
veecee's Avatar
Trader Rating: 34 (100%+)
If you want an upgrade that gives a noticeable performance lift, try this.
SMOKEM --- HIRO SEIKO --- YOKOMO
veecee is offline   Reply With Quote
Old 05-12-2013, 07:55 PM   #4094
Josh-n-ya's Avatar
Have not tried it on carpet. I have drove rcguyfpr on pavement and was sold on it. It was the best handling car ever. I gave it throttle in turns trying to break it loose and it wouldnt. Arms move very free and no binding in suspension what so ever. Just put mine together and have coppied my friends set up. I will try it this weekend.
Josh-n-ya is offline   Reply With Quote
Old 05-12-2013, 09:58 PM   #4095
rcguyfpr's Avatar
someone mentioned my name? exotek '12 was good..... until you drove a T4. LOL
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 12:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 05:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-16-2011 11:58 PM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 03:11 PM
