Old 03-14-2013, 04:29 PM   #4066
Thanks, the LHS doesn't have those parts in stock either, but they did say that they have a good selection of steel and brass tubing in stock that people use for modelling projects and a temporary substitute should be doable.
Rufus2010 is offline   Reply With Quote
Old 03-31-2013, 10:08 PM   #4067
Josh-n-ya's Avatar
Trader Rating: 72 (100%+)
What are some tips to get more rear side bite and rear traction on pavement. Out track kind of gets dusty from the constant construction of the near by off road track but it gets sprayed on race day. This is 17.5 blinky class. I am running 3mm rear toe, 1.75rear camber, I keep playing with shock position and dont know what to do. I have Tamiya shocks 3.0springs in front w/45wt, 2.6springs in rear w/35wt . The hinge blocks have little hole on bottom( dont know what those do)? LTCR light weight body. Any help would be nice! thx
Josh-n-ya is offline   Reply With Quote
Old 04-01-2013, 07:42 AM   #4068
Trader Rating: 27 (100%+)
Try laying the shocks down one hole at a time until you find enough traction.
In general, in the rear, Down = more side traction, Up = Tighter steering
If that doesn't help, you can go softer on the oil and shocks.
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 04-01-2013, 04:48 PM   #4069
Josh-n-ya's Avatar
When you say (softer) oil do you mean lighter like 30wt?
Old 04-01-2013, 05:00 PM   #4070
Trader Rating: 57 (100%+)
Yes that is what he means. I'm not sure what the tamiya shocks/spring would work like, but looking at Paul LeMieux's setup from the Asphalt nats, he was running Xray 2.4/500cst up front and 2.2/400 in the rear. You can try setting your car up like this http://forum.teamxray.com/xform/inde...&setup=t3_2012 and see how it works for you as a baseline and change droop to fit the 17.5.
PROMODVETTE is offline   Reply With Quote
Old 04-01-2013, 07:12 PM   #4071
Josh-n-ya's Avatar
Thanks! Tamiya shocks are really really smooth. The springs are Xray. I will try to soften it up and see what happens. What does changing the plastic arm blocks do with the little dots? I believe there roll center blocks.
Old 04-01-2013, 08:37 PM   #4072
erchn's Avatar
Josh,
Generally a higher roll center (dot) provides less traction at that end of the car. I would try mid roll centers in the rear, -.75mm block will make that end feel a bit lazy and definitely give you a pushy feeling at NorCal. Stop by this weekend, we can talk in person.
Ethan
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
erchn is offline   Reply With Quote
Old 04-01-2013, 10:43 PM   #4073
Josh-n-ya's Avatar
Originally Posted by erchn View Post
Josh,
Generally a higher the roll center (dot) provides less traction at that end of the car. I would try mid roll centers in the rear, -.75mm block will make that end feel a bit lazy and definitely give you a pushy feeling at NorCal. Stop by this weekend, we can talk in person.
Ethan
Cool Ethan, Just looking to see what changes I can make. My current setup works great on a very clean and freshly prepped track. After a few days of near by offroad racing and leaf blowing dirt around its over.
Old 04-02-2013, 06:42 AM   #4074
vivo quevas's Avatar
Trader Rating: 18 (100%+)
Josh I have Tamiya TRF shocks shocks on my T2 Xray with rsd pistons they were a upgrade the car handles great I ran it in modified Saturday.
Awesomatix A800 USGT, Awesomatix 800 VTA, , Tamiya Euro Truck, CRC WTF1
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
vivo quevas is offline   Reply With Quote
Old 04-02-2013, 07:00 AM   #4075
Josh-n-ya's Avatar
Mod! Wow, I love my tamiya shocks too. I always get bubbles in Xray shocks every time! lol I think I am ready to take it to the next level and try new set ups. We will see!
Old 04-03-2013, 10:48 PM   #4076
Josh-n-ya's Avatar
I just set my car up like this. It seems like an odd set up but im open for new things to learn. I went with 2.8 springs up front and 2,4 in rear w/35wt oil all around. Thats the softest I have. Also went with only 3degree toe out in front. 5degrees seems much for me. Sunday will be interesting!
Old 04-03-2013, 11:04 PM   #4077
erchn's Avatar
If I remember correctly Paul's car was mostly a T4 at that race. 2.8/2.4 will probably work but might be a bit lazy. That said, Paul's setup has .5 degrees toe out in front, not 5 degrees.
If things aren't working on Sunday, don't hesitate to stop by.
E
Old 04-04-2013, 05:46 PM   #4078
Josh-n-ya's Avatar
E
5 degrees! OOPS. Lol
Old 04-04-2013, 06:01 PM   #4079
This you?
Old 04-04-2013, 07:37 PM   #4080
Josh-n-ya's Avatar
You almost couldnt tell which was the front of the car when I did that!
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 12:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 05:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-16-2011 11:58 PM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 03:11 PM
