Old 09-12-2012, 09:50 AM   #3706
Send a message via AIM to Matt W
Default Center servo mount
Hi,
I see a lot of people have been writing about the center servo mount and how crap it is. What causes the un even tweak, is it the the outer chassis screw? If it is the servo touching the chassis could you not use the standard mounts but place 1mm shims under them to raise the servo up slightly?
Any thoughts??
Matt W is offline   Reply With Quote
Old 09-12-2012, 10:08 AM   #3707
M-Technic's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Matt W View Post
Hi,
Any thoughts??
It's the pickup point on the outside, which keeps the chassis from flexing evenly. I don't think raising the servo would do much.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 09-12-2012, 10:51 AM   #3708
B00t13g's Avatar
Hi,
Any thoughts??
My issue was it moved. Servo tape is better for ME.
B00t13g is offline   Reply With Quote
Old 09-12-2012, 11:28 AM   #3709
MikeXray's Avatar
Trader Rating: 73 (100%+)
So much talk over a part that no one has even claimed to improved lap times, sure it may be "better" in theory, but no even claimed the obligatory "I gained .2ths and TQ'd for the FIRST time after installing it". If you car seems to steer a little more to one side, add camber to the other side, done.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 09-12-2012, 01:36 PM   #3710
haywood's Avatar
Trader Rating: 48 (100%+)
+1
I'm tired of the servo mount talk! I've never lost a race because of how my servo was mounted!
Calandra Racing Concepts/ Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 09-12-2012, 01:37 PM   #3711
Skiddins's Avatar
The mount can move back and forth by a certain amount, but to be honest that would probably protect the servo case in a crash.
If you power your car up with the mount, then force the steering against the servo saver the mount will not move.
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is online now   Reply With Quote
Old 09-12-2012, 01:47 PM   #3712
NolanP's Avatar
My mount only flexes up and down. I like my mount.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
Old 09-13-2012, 10:03 AM   #3713
Default Hagberg's rear mod on carpet!!
Hi, I know a lot of drivers have been running Alexander Hagbergs rear modification on asphalt, narrowing the rear track of the car. I was wondering have many people tested this on carpet and if they think it would be better than the kit setting? Also how will this setting affect the cars handling on carpet?
Old 09-13-2012, 10:34 AM   #3714
B00t13g's Avatar
Rotated too much on my low-medium traction carpet.
Old 09-13-2012, 11:31 AM   #3715
pchroma24's Avatar
Trader Rating: 79 (100%+)
I've run it since hearing about it in January.. bootleg is correct, makes the car rotate really fast in low , med conditions.. seems about right on high traction.. I found that the full 1mm works best on high traction and I will reshim each side +.5mm for low and medium... It works well for me..
If you can't explain it simply, you don't understand it well enough... Einstein
pchroma24 is offline   Reply With Quote
Old 09-13-2012, 11:38 AM   #3716
Skiddins's Avatar
Run it everywhere. trouble is, it's been on there so long I can't remember what it was like before
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 09-13-2012, 02:10 PM   #3717
artwork's Avatar
Trader Rating: 62 (100%+)
I have spent alot of time going back and forth between the narrow rear end (like the hagberg mod) and the standard rear end. The car rotates very well with the narrow rear, but makes the car hard to drive. I would say in high traction this would be a good change to make, but for club racing it is a mistake on carpet. Unless your club races have ultra high traction, and then if this is the case then maybe it would be a good option. In my testing mostly 17.5 and 13.5 I have found the standard rear settings to be the best...
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 09-13-2012, 02:21 PM   #3718
PhilipT32011's Avatar
helo guys, Ihave seen hagberg's modification and i wonder what if i let the rear standard end and make the front end i bit wider. You believe it will work on a low grip asphalt track?
PhilipT32011 is offline   Reply With Quote
Old 09-13-2012, 02:46 PM   #3719
M-Technic's Avatar
It doesn't have the same effect. However, a lot of people still run the front end wider.
Old 09-14-2012, 08:15 AM   #3720
Default Servo
Regarding the servo, why dont other people do what I did and move the servo FULLY inside the chassis?
Basically my inside lug on the servo has been cut off, a hole has been drilled on the outside of the chassis, so I now have one screw holding the servo in, as well as servo tape. As it only has one screw, there is no issue with uneven flex.
My COG is also now closer to the middle of the car, the servo is also better protected from any damage from impacts.
It is also much neater!!
The stupid nub has been cut off.
This was done PRIOR to even running the car for the first time.
Why this isn's the standard option I dont know?
Mb3195 is offline   Reply With Quote
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 12:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 05:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-16-2011 11:58 PM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 03:11 PM
